Potentially snapped Timing Belt
Discussion in '1st Gen Tundras (2000-2006)' started by thefish712, Jun 21, 2021.
  1. Jun 26, 2021 at 8:03 PM
    #121
    15whtrd
    15whtrd Mr. Blonde
    My condolences. I was rooting for you.
    thefish712[OP] likes this.
  2. Jun 26, 2021 at 8:34 PM
    #122
    Toyoda Tundra
    Toyoda Tundra Boxing and Tundras
    2WD 2004 AC Tundra. V8 strong
    This what mine looks like. Sucks that going to college is so expensive otherwise I would of replaced it as soon as I bought the truck.
  3. Jun 26, 2021 at 8:36 PM
    #123
    That needs replacing.
  4. Jun 26, 2021 at 8:40 PM
    #124
    Toyoda Tundra
    Yes it does
  5. Jun 26, 2021 at 9:13 PM
    #125
    TheSilentObserver
    TheSilentObserver New Member
    2001 Tundra 4.7 RWD
    Would suck worse going to college, and not being able to afford fixing your truck if that belt snaps.
    If you can't afford to take it to a shop, then I'd recommend getting the Aisin kit, hitting up YouTube, and tackling the sucker yourself. OP provided a great example of what could happen if you put it off.
    Or find a cheap car to daily, and park the truck until you do have the money to get the belt done.
  6. Jun 27, 2021 at 10:10 AM
    #126
    SouthPaw
    SouthPaw The headlight guy
    2000 Limited 4x4 AC
  7. Jun 27, 2021 at 11:44 AM
    #127
    snomoman
    snomoman New Member
    North Aurora, IL
    2020 Cement SR5 4WD Tundra
    Bed liner, truxedo tonneau cover, Westin step rails, cover king seat covers
    Which kind of raincoat are you talking about? the kind that saves your timing belt on your tundra or the kind that saves you hundreds of thousands of dollars in childbearing costs and college? Ha Ha
    Sirfive likes this.
  8. Jun 27, 2021 at 11:50 AM
    #128
    2mchfun
    Yes, you nailed it, I was indeed making the point that an ounce of prevention is better than a pound of cure.
  9. Jun 27, 2021 at 1:30 PM
    #129
    jimf909
    jimf909 Battery almost dead...
    Washington or Idaho
    '03 Tundra SR5 AC 4.7 TRD w/LSD
    Dead stock with oem 16" starfish wheels. We'll see how long that lasts. :) Topper of unknown origin.
    Sorry to hear about this, OP.
    Not directed at the OP...
    There are different approaches to maintenance, two of them are: preventative and run-to-fail. Each work and each has pros and cons. Preventative maintenance makes sense for a timing belt on an interference engine, oil changes, etc. while run-to-fail works great for light bulbs, shock absorbers, etc.
  10. Jun 27, 2021 at 2:52 PM
    #130
    N84434
    N84434 In the Frozen Tundra
    Milwaukee WI.
    2001 Limited TRD
    Like all the others.. I hate to hear of this, but try to keep it in perspective. The investment now will reap the benefit of many years of worry free driving. :thumbsup:
  11. Jun 27, 2021 at 3:05 PM
    #131
    thefish712
    thefish712 [OP] New Member
    Fish
    2005 Toyota Tundra 4.7L V8 4WD Double Cab
    Yeah, exactly. Not super thrilled about having to buy a "new" engine for my truck; but the thought of getting an engine with 100K less miles and another 10 year lifespan is a nice payoff.
    Btw, the guys at the shop found bits and pieces of the original timing belt - they don't think it was EVER replaced. Wtf. Thought my neighbor (guy I bought it from) took care of his truck. Live and learn
  12. Jun 27, 2021 at 3:18 PM
    #132
    TheSilentObserver
    2001 Tundra 4.7 RWD
    Never take anyone's word for it without proof. That's why I went ahead and had mine done. Sure was expensive, but I paid $7k for the truck. Would've sucked for that $7k to wind up down the train over some rubber.
    But hey, sounds like you're making the best out of a rough situation. Hoping that, when the day comes that I'm faced with a similar situation, I'm able to do the same.
  13. Jun 27, 2021 at 3:20 PM
    #133
    thefish712
    Fish
    Well, it definitely sucks, but I just don't know how else to handle it I suppose. No use in getting all bent out of shape about it. Good learning experience, albeit the hard way haha, and now my truck will have a sweet newish engine!
  14. Jun 27, 2021 at 3:25 PM
    #134
    TheSilentObserver
    2001 Tundra 4.7 RWD
    And now you know how to avoid this down the line. Can't wait to see what you do with the truck once you've got it back!
  15. Jun 27, 2021 at 3:35 PM
    #135
    ToyotaJim
    ToyotaJim New Member
    Whatever engine you do get, I'd also just get that used engine caught up on all replacement parts needed before the reinstall.
  16. Jun 27, 2021 at 4:38 PM
    #136
    snomoman
    snomoman New Member
    North Aurora, IL
    Especially the timing belt & water pump, it will be worth the great feeling you will have once your back on the road
  17. Jun 27, 2021 at 5:03 PM
    #137
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
    I call BS on the shop, most Toyota use hydraulic valves. It use engine oil to keep the valves open, once timing belt is broke, no engine oil to keep the valves open, so it spring shut. My friend snap a timing belt on his Camry, I help him put a timing belt back and it ran like nothing happened.
    Toyoda Tundra likes this.
  18. Jun 27, 2021 at 5:05 PM
    #138
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
    Rebuild is better than used engine. Toyota engine is known to run 1mil miles, that engine is just broken in with 200k.
  19. Jun 27, 2021 at 5:07 PM
    #139
    jerryallday
    jerryallday New Member
    Jerry
    Pasadena, Ca
    2006 DC SR5 V8 Grey
    Have you checked for another opinion from another shop?
  20. Jun 27, 2021 at 5:50 PM
    #140
    Bent valves are not an opinion. Whether or not the block and heads are serviceable (block maybe, heads less likely) is another story. If the block is good, re-piston and new heads would get you going again.
  21. Jun 27, 2021 at 5:54 PM
    #141
    Roborob70
    Roborob70 New Member
    Robert
    18 Toyota Tundra TRD
    Sorry, but this thread is almost as bad as the ridgeline.....
  22. Jun 27, 2021 at 9:11 PM
    #142
    thefish712
    Fish
    Guys, it sounds like a engine replacement is the smart thing to do. Rebuilding the engine wouldn't save me much money... if any
  23. Jun 27, 2021 at 9:11 PM
    #143
    N84434
    Milwaukee WI.
    2001 Limited TRD
    Booney, jpink, bmf4069 and 4 others like this.
  24. Jun 27, 2021 at 9:15 PM
    #144
    Sirfive
    Sirfive Master Procrastinator
    ‘02 Limited AC TRD
    Bassani cat-back
    money isnt everything. Cussing and throwing tools will teach you more about the importance of maintenance and inspection than a shops bill.
  25. Jun 27, 2021 at 9:16 PM
    #145
    thefish712
    Fish
    Totally with you on this. But I'm not touching rebuilding the engine myself
    07 Tundie, jpink, WBW and 2 others like this.
  26. Jun 27, 2021 at 9:17 PM
    #146
    ToyotaJim
    I would not pay for a 2nd opinion. I'd just go to the first shop and ask to see the damage. It's going to be readily apparent with bend and damaged parts.
    I'd have to agree. For the cost of a rebuild on a high miles engine, if a low miles engine is available for a similar cost that would be the way to go IMO.
  27. Jun 27, 2021 at 9:19 PM
    #147
    Sirfive
    ‘02 Limited AC TRD
    Bassani cat-back
    Its not for everyone. I understand. I wouldnt try open heart surgery on myself.
  28. Jun 28, 2021 at 3:35 AM
    #148
    I asked before how much you trust this shop. Do some research as this is a great opportunity to get other work done while the engine is out. There are a lot of parts that are easier to get to when it's out. I think I'd go the same route as you and just find a used engine.
  29. Jun 28, 2021 at 3:55 AM
    #149
    DanielDD
    DanielDD Too Old to Rock and Roll and Too Young to Die
    2001 TRD Tundra
    Unless I missed something here, why in the world do you need to replace or rebuild the engine? IF what they indicate is correct, that you only suffered bent valves, then just get both heads rebuilt. Thats all that is needed, other than replacement of the water pump and timing belt. As long as there is no damage to the top of the pistons, you're fine. Why go to the expense of rebuilding the short block? Its simply not needed. I would get a 2nd opinion.
  30. Jun 28, 2021 at 4:19 AM
    #150
    If the valves are bent, then there's likely other associated damage as well. Some may even be hard to see. If it were my engine and the belt snapped and the valves were bent from piston contact, it would be a full tear down and rebuild. Replacing just the heads, reassembling and firing it back up just to find that one or more of your connecting rods is also bent (even slightly so), or one or more piston is cracked and then have to tear it back down and do it again is a bad plan. Could be main bearing damage, could be piston wall damage. If it happened at idle, I'd be more optimistic. It happened at 65mph in gear. Lot of inertia left in the motor.
