Coolant seep
Discussion in '1st Gen Tundras (2000-2006)' started by shoe07, Jun 26, 2021.
  1. Jun 26, 2021 at 7:24 PM
    shoe07
    shoe07 [OP] New Member
    Ohio
    2004 Tundra Double-cab SR5 Tow pkg
    I noticed this while checking fluid levels this evening. It appears that coolant has been seeping out around this fitting. What would be the best way to seal this? Is there a gasket p/n somewhere?
    not even sure what it would be called.
    right in front and under the black plastic cover over the intake tube. Right behind the serpentine belt. I believe it is the coolant return fitting.
  2. Jun 26, 2021 at 7:27 PM
    shoe07
    Ohio
    Further back
  3. Jun 26, 2021 at 7:59 PM
    carsonchunk
    carsonchunk New Member
    That looks like your water pump.
  4. Jun 26, 2021 at 9:03 PM
    jerryallday
    jerryallday New Member
    Jerry
    Pasadena, Ca
    2006 DC SR5 V8 Grey
    That’s your water pump
    15whtrd likes this.
  5. Jun 27, 2021 at 6:07 AM
    shoe07
    Ohio
    Thanks. I thought the water pump was down lower than that.
    would this just be removing that and replacing the gasket?
  6. Jun 27, 2021 at 6:18 AM
    Professional Hand Model
    Fred
    Hand Protectors
    Yeah. Was thinking WP was lower, too. I think that leak is on the Thermostat housing to block assy. Might need a new gasket or buy some Toyota Green FIPG for Coolant and make your own ($33 on fleebai).
    15whtrd likes this.
  7. Jun 27, 2021 at 6:20 AM
    shoe07
    Ohio
    looks like it’s coming from between the us manifold and what I assume is the water pump.
    15whtrd likes this.
  8. Jun 27, 2021 at 6:24 AM
    Fred
    Hand Protectors
    Hard to tell. My years ago WP leak seemed lower than that as there is a manufactured slot for the leaky coolant on the bottom of the Assy for such purpose.
    You’ll need to start pulling shtuff off and fix it whatever its coming from. :annoyed:
  9. Jun 27, 2021 at 6:28 AM
    Fred
    Hand Protectors
  10. Jun 27, 2021 at 6:39 AM
    shoe07
    Ohio
    I do t think so, it sits more at a 45’ angle rather than parallel with the face of the engine
  11. Jun 27, 2021 at 6:42 AM
    Fred
    Hand Protectors
    Yeah. This is the only diagram they provided. Ours is more 45° and rectangle shaped, but same principle.
  12. Jun 27, 2021 at 6:43 AM
    Fred
    Hand Protectors
    Here is from another site. Do your own research before buying parts etc.
    shoe07[OP] likes this.
  13. Jun 27, 2021 at 6:45 AM
    Fred
    Hand Protectors
    Wooooo price shot up from $33 last year.
  14. Jun 27, 2021 at 8:32 AM
    jerryallday
    Jerry
    Pasadena, Ca
    2006 DC SR5 V8 Grey
    Update
    that is your thermostat housing, it the part right after the the thermostat that meets up to the water pump. Below are some photos of when I had mine off. You can see the orange gasket
    MS22 likes this.
  15. Jun 27, 2021 at 4:07 PM
    shoe07
    Ohio
    Thanks for the info fellas. I’ll get parts and really want to get this done before our big road trip in 2 weeks time. Doesn’t look like it will be too terrible to get off.
    jerryallday likes this.
  16. Jun 27, 2021 at 4:26 PM
    P-Factor
    P-Factor New Member
    2018 Tundra Limited Double Cab
    TRD Sway Bar, TRD Exhaust, TRD Cold Air Intake
  17. Jun 27, 2021 at 4:44 PM
    shoe07
    Ohio
  18. Jun 27, 2021 at 4:50 PM
    P-Factor
    P-Factor New Member
    Just another process of elimination...
  19. Jun 27, 2021 at 4:51 PM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    Remove t-stay housing with 2 bolts. Clean old gasket off throughly, put new FIPG on, tighten, let cure for 20minutes to an hour, add coolant, bleed and likely be leak free. Someone probably did a rush job
    Cleaning the surface when doing the t-belt
  20. Jun 27, 2021 at 5:01 PM
    jerryallday
    Jerry
    Pasadena, Ca
    2006 DC SR5 V8 Grey
    Not pictures but you might want to buy a new o-ring to where it connects to the bypass. My o-ring was shot.
    This should be the part number - 96761-35035. Double check
    KNABORES and shoe07[OP] like this.
  21. Jun 27, 2021 at 5:55 PM
    shoe07
    Ohio
    Anything to get other than that o-ring and sealant?
  22. Jun 27, 2021 at 5:56 PM
    shoe07
    Ohio
    Is Toyota fipg that much better than blue coolant rtv such as permetex or loctite?
  23. Jun 27, 2021 at 6:37 PM
    I used Permatex gasket maker when I did mine. My truck hasn't exploded or pissed all of it's coolant out. Yet.
  24. Jun 27, 2021 at 6:44 PM
    jerryallday
    Jerry
    Pasadena, Ca
    2006 DC SR5 V8 Grey
    Same
  25. Jul 10, 2021 at 1:52 PM
    shoe07
    Ohio
    Thanks for the help. I ended up trying threebond 1186? Sold as Honda/yamabond 4.
    it was like water coming out of the tube, not at all what I was expecting and the next day the leak was worse.
    I then bought permatex the right stuff. Now it’s been two days and no leaks.
