  1. Jun 24, 2021 at 1:20 PM
    Fuck that. I would definitely go right back to the shop and have them order replacement parts for that crap. This is why I hate letting other people work on any of my anything. No one gives a crap about your stuff. Also, pretty sure modifying the factory braking system isn't something shops do on the regular, for liability reasons alone.
  2. Jun 24, 2021 at 1:24 PM
    Professional Hand Model
    Fred
    Hand Protectors
    Question is: How do you prove something that isn’t there wasn’t there when you didn’t know if it was there?
    Otherwise, I agree with you.
    oscardog86 and Glock 40 like this.
  3. Jun 24, 2021 at 1:26 PM
    See the " I had a picture from a month ago....." part
  4. Jun 24, 2021 at 1:30 PM
    Fred
    Hand Protectors
    Ah. I see now!
  5. Jun 24, 2021 at 1:35 PM
    Trailscape
    Trailscape Zip Tie Wizard
    Alabama
    2006 Tundra SR5
    Yeah, I took these after doing the swaybar. I had to trim the exhaust to get the right side bracket in place.
  6. Jun 24, 2021 at 1:36 PM
    Unfortunately not visible in that pic.
  7. Jun 24, 2021 at 1:36 PM
    Glock 40
    Glock 40 I'm here to break shit
    Yukon Cornelius
    Way up thar
    2000 AC Limited 4X4 4.7L
    Deadpool Edition
    I still want that Hellwig.
  8. Jun 24, 2021 at 1:40 PM
    Fred
    Hand Protectors
    You loving that Rear Sway Bar?
    Looks like they ziptied your broken end of the Proportioning Arm into the fully up (bed loaded with weight) position in that other pic.
  9. Jun 24, 2021 at 1:40 PM
    I can see the LSPV in both pictures.
    I don't understand how they could snap that off. Seems like it would take a fair amount of force. What brake work were they doing?
  10. Jun 24, 2021 at 1:43 PM
    Fred
    Hand Protectors
    It’ll totally change the truck for the better. Faster, stronger, better looking...:rofl:
  11. Jun 24, 2021 at 1:44 PM
    Trailscape
    Alabama
    2006 Tundra SR5
    Yes, for sure on the sway bar. I have a fair bit of weight all the time and a taller utility topper. It helped quite a bit. Thinking of upgrading the front too now.
    I'm puzzled why they did that. They installed a new carrier bearing with a drop kit, stainless brake lines and all new brakes. Even welded up a new tail pipe.
  12. Jun 24, 2021 at 1:46 PM
    I can see the lower bracket for the LSPV. I cannot see the actual valve or any of the transverse arm that connects the lower bracket to the valve itself. Am I missing it?
  13. Jun 24, 2021 at 1:49 PM
    I think we can see enough to prove it was there.
    Darkness likes this.
  14. Jun 24, 2021 at 1:51 PM
    Trailscape
    Alabama
    2006 Tundra SR5
    Yeah. I have another I took right when I got home and it's clearly missing.
  15. Jun 24, 2021 at 1:59 PM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    Not to mention putting a zip tie on a brake line is beyond hack moves.
  16. Jun 24, 2021 at 2:08 PM
    gcholmes1
    gcholmes1 New Member
    2006 Tundra SR5
    Update on the clunking sound from the front end, it was a sway bar link after all. Everything appeared fine visually, but I took the driver's side link off completely and found it was pretty chewed up, but I couldn't see it when installed. Probably over-torqued and wore out over time. Went for a quick drive around the block with that link removed and the bad sounds were gone, so I got a new Moog replacement put in, it's been silent since.
    Thanks all for the input!
    tacoguybill, bmf4069, NUDRAT and 6 others like this.
  17. Jun 24, 2021 at 2:21 PM
    Trailscape
    Alabama
    2006 Tundra SR5
  18. Jun 24, 2021 at 6:05 PM
    Desert Dog
    2001 SR5 AC 2WD 4.7l
    Finally pulled the trigger on replacing the passenger side exhaust manifold with an OEM one. Got it for $295 with a promo code from Larry Miller Toyota in Murray, UT. I considered the Thorley's and JBA's but the truth is I probably won't keep the truck long enough to see the new OEM one go bad again and I
    m not looking for performance gains and really just wanted ease of installation on this job more than anything. Lol. Bought all new OEM hardware for the job too.
    Also bought gear oil for the rear diff to change it out when I have a little more time. Working 6-7 days a week hasn't helped me accomplish much of what I want to on the truck but it does give me the $$$ for the toys. Haha!
    oh, I found a reputable machine shop close by to weld a bead inside the new manifold flanges and plane it, so that should help it last a little longer than the original one that I'm sure is on the truck now.
  19. Jun 24, 2021 at 6:13 PM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    Tried red loctite?
    oscardog86 and bmf4069 like this.
  20. Jun 24, 2021 at 6:16 PM
    empty_lord
    05 rollover special
    Uh… looks like they did that because it wasn’t bleeding right..
    I’d be raising a bitch fit
  21. Jun 24, 2021 at 8:06 PM
    assassin10000
    assassin10000 New Member
    Andrew
    Northern CA
    '05 SR5 AC 2wd
    ^ this.
    If an accident happens they could be held liable for part of all of it. Should never have done that.
    onesojourner likes this.
  22. Jun 24, 2021 at 8:35 PM
    Sirfive
    Sirfive Socially feral
    ‘02 Limited AC TRD
    Bassani cat-back
    Go in there as karen’d as possible. Bobbed highlighted wig and all.
  23. Jun 24, 2021 at 11:23 PM
    Sirfive
    ‘02 Limited AC TRD
    Bassani cat-back
    ITS MA’AM!
    I got a new battery today. Put the tundras battery in the sequoia.
    Tundra2 and onesojourner like this.
  24. Jun 25, 2021 at 5:11 AM
    I thought we were brothers? :(
  25. Jun 25, 2021 at 8:05 AM
    Orange devil likes this.
  26. Jun 25, 2021 at 1:49 PM
    1genjunky
    1genjunky New Member
    04 tundra DC
    Had some dead space under my grill that was a pain to access. Problem solved. Some before and after.
  27. Jun 25, 2021 at 1:50 PM
    onesojourner
    SW MO
    06 DBLcab LTD 4x4
    I like that stove.
  28. Jun 25, 2021 at 1:52 PM
    1genjunky
    04 tundra DC
    Thanks. This setup has changed my camping life. Lol
  29. Jun 25, 2021 at 3:59 PM
    Stove is a classic. Many a camp meal served up off of a green Coleman
    oscardog86 and Dannydirtyfingers like this.
  30. Jun 25, 2021 at 4:03 PM
    Kool. A drawer within a drawer.
    NUDRAT likes this.
