Rock Slider Suggestions
Discussion in '2.5 Gen Tundras (2014-2021)' started by pvn.beluga, Feb 3, 2021.
  1. Jun 23, 2021 at 6:42 PM
    #91
    MadMaxCanon
    MadMaxCanon New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
    Finally got the email last night that my Cali Raised Trail sliders are ready for pickup. Super stoked, probably pick them up after work Friday.
  2. Jun 23, 2021 at 7:11 PM
    #92
    pvn.beluga
    pvn.beluga [OP] New Member
    Phuc (Phooc)
    Connecticut
    Oh hell yeah! Post it up on here for everyone to see!
  3. Jun 24, 2021 at 5:53 AM
    #93
    MadMaxCanon
    Definitely. I am hoping to do the install pretty soon. I will be installing them with the Valhallas sheild so I will try to get some detailed pics.
  4. Jun 24, 2021 at 5:55 AM
    #94
    Squatting Pigeon
    Holden
    North Texas
    4Runner | GR Corolla
    You won’t be disappointed!
  5. Jun 24, 2021 at 6:03 AM
    #95
    MadMaxCanon
    Looks awesome! You have the trail editions right? Doesnt look wide enough to be the step edition. I went with the rhino lining to help the family with grip. I am also hoping the install goes smoothly with my smaller gas tank. That seems to be the area most people have issues with their larger tanks.
  6. Jun 24, 2021 at 6:08 AM
    #96
    Squatting Pigeon
    Holden
    North Texas
    Yes, these are the trail edition ones, I wanted them to be a little tighter to the body. My six year old son uses them as a step with zero issue :thumbsup:
    I do have the 38 gallon tank and it’s a tight squeeze to get in between there for sure.
  7. Jun 24, 2021 at 7:12 AM
    #97
    MadMaxCanon
    Did you drop the tank or just used the bracket handle tools that they provide? I wonder if it would be easier with the 26 gallon.
  8. Jun 24, 2021 at 7:17 AM
    #98
    Squatting Pigeon
    Holden
    North Texas
    The guys at caliraised put them on but they said they were able to get it without dropping the tank.
  9. Jun 24, 2021 at 7:26 AM
    #99
    MadMaxCanon
    Got it. If i didnt have the Valhalla plates I would have them do it, but i have a feeling they would run into snags and want to charge me for the minor tweaks it would need.
  10. Jun 24, 2021 at 7:45 AM
    #100
    Squatting Pigeon
    Holden
    North Texas
    I saw on the Valhalla thread that caliraised sliders are a confirmed fit, so hopefully they wouldn’t need to adjust or change anything but I don’t know :notsure:
  11. Jun 24, 2021 at 10:17 AM
    #101
    BigAl
    BigAl New Member
    2014 SR5 Magnuson SC
    So jelly! These are the very next thing on my list. NEED them! Share a picture with us when you get them on.
  12. Jun 24, 2021 at 10:55 AM
    #102
    te37_daniel
    te37_daniel New Member
    Lunar Rock TRD Pro
    18 TE37 large PCD, KM3s
    Just want to say thanks for posting about Explore overland- I had never heard of them. I almost bit the bullet on WKOR, but I never liked how sudden the kick out is. I just looked at explore overland sliders and really like the gradual bend on the kick out. I'll be placing an order soon and report back.
    pvn.beluga[OP] likes this.
  13. Jun 25, 2021 at 7:59 AM
    #103
    Tundra18overland
    Tundra18overland Traversing the million mile road
    Jesse
    GA
    2018 SR5 CM Expedition Build
    RCI powder coated sliders with top tread plate. Install took about 4 hours total. Used a floor jack and 2x4 to hold the sliders in place and get them into position. Takes 5 bolts on each side, but currently only have 3 bolts installed on the driver’s side slider. The driver’s side is tough because the frame of the truck is next to the gas tank (38gal). It is going to make those last 2 bolts hard to install. Dropping your tank would make it easiest but I’m trying to avoid that. You will also need to unclip your brake lines on passenger side in order to tighten one of the bolts, but the 5 bolts on the passenger side are all way more accessible than the driver’s side. Overall very happy with the fit and finish. I like the “low profile” kick out but also wouldn’t have minded a wider kick out either. Also got RCI’s full aluminum skid set. Would recommend their stuff to anyone looking for solid armor that is all bolt on!
  14. Jun 26, 2021 at 7:16 AM
    #104
    YotaBro
    YotaBro This forum will make me broke
    Calvin
    FL
    2017 Cement Grey Tundra TRD PRO
    Lots of shenanigans.
    @pvn.beluga how're you liking the WKOR rock sliders? I'm still debating on WKOR or RCI. There is about 200$ difference (shipping, taxes included) between them. Seems like WKOR offers a bit more coverage but the RCI is direct bolt-on.
  15. Jun 26, 2021 at 7:24 AM
    #105
    TRDFerguson
    Jake
    Southeast Greater Basin, AZ
    2018 MGM CrüeMax
    I took a look at the RCI instructions and it doesn’t look like they are any more “bolt on” than the WKOR sliders. Same 5 bolts on the side of the frame (but WKOR uses .5” bolts instead of 7/16”). WKOR doesn’t list the bottom drilled holes as optional though, but it’s the same concept.
    YotaBro[QUOTED] likes this.
  16. Jun 26, 2021 at 7:27 AM
    #106
    YotaBro
    Calvin
    FL
    Yeah, after doing more and more research Im leaning towards WKOR
  17. Jun 26, 2021 at 10:57 AM
    #107
    pvn.beluga
    Phuc (Phooc)
    Connecticut
    I actually haven’t received mine yet, but @TRDFerguson could chime in on his experience with it so far.
    Mine should be arriving this upcoming week. It’s raining quite a bit this upcoming week so I may not be able to install it until the following week after.
    Will post photos of installation and give a review of what I think about it!
  18. Jun 27, 2021 at 7:20 PM
    #108
    MadMaxCanon
    So went yesterday to pick the sliders up and sure enough there was like 8 separate gashes and holes in the rhino lining. They are sending the sliders back for blast and recoat, just my luck.
  19. Jun 28, 2021 at 3:19 PM
    #109
    TravisJr
    TravisJr New Member
    2001 AC SR5 4WD, 2010 DC SR5 4WD
    Lots o’ mods
    So my WKOR sliders shipped today, almost 10 weeks to the day from order, exactly as promised. I expect they won’t arrive until next week, but I’ve got everything ready for install. Can’t wait.
  20. Jun 28, 2021 at 3:34 PM
    #110
    pvn.beluga
    Phuc (Phooc)
    Connecticut
    Mine are currently in Pennsylvania. Should be another day or two before it arrives at the local hub!
    TRDFerguson and TravisJr[QUOTED] like this.
  21. Jun 29, 2021 at 5:14 PM
    #111
    YotaBro
    Calvin
    FL
    Ordered the WOKR rock sliders today! Just a heads up. Prices have increased another 100$. Fortunately I did my quote before the increase so they honored the original quote.
    pvn.beluga[OP] and TRDFerguson like this.
  22. Jun 29, 2021 at 5:21 PM
    #112
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    I also found an old code on IH8MUD for 5% off that they honored. I just remembered this. Check for it on Google and see if they’ll tack it on.
  23. Jun 29, 2021 at 5:52 PM
    #113
    pvn.beluga
    Phuc (Phooc)
    Connecticut
    Damn! $1380 base for .188 DOM, PC, no plates. Luckily I got it for $1500 total!! Glad you’re jumping onto WKOR!
    Oh yeah! I totally forgot to mention this. Told them I was on the forums and they added on the forum discount!
  24. Jun 30, 2021 at 8:46 AM
    #114
    pvn.beluga
    Phuc (Phooc)
    Connecticut
    AND IT’S HERE!!! Ordered on Apr. 7th, arrived today (Jun. 30th).
    Will open after I’m done with work!
  25. Jun 30, 2021 at 8:58 AM
    #115
    YotaBro
    Calvin
    FL
    Did you get a moving blanket with it too?
  26. Jun 30, 2021 at 9:38 AM
    #116
    itsmerh85
    itsmerh85 New Member
    Gilbert, AZ
    2020 Black TRDPro
    Westcott is finally coming out with tundra sliders soon. Can't wait to see those
  27. Jun 30, 2021 at 9:47 AM
    #117
    pvn.beluga
    Phuc (Phooc)
    Connecticut
    Yeah I see it! I haven't opened it yet... but working at Amazon gives me the leisure of having free moving blankets :)
    YotaBro[QUOTED] and TRDFerguson like this.
  28. Jun 30, 2021 at 9:56 AM
    #118
    hdattitude
    hdattitude New Member
    I ordered the WKOR sliders last December during their sale. Received them mid February as promised. Natalie at WKOR responded to my numerous questions during a time when I know they were swamped with orders. She was very polite and had a ton of patience with me. I received the sliders and they took great care in packing these. Not a single scratch or blemish in the powder coat. That was unexpected as they were shipped to the East Coast. If I recall the shipping weight was close to 250Lbs! Because my truck is new, under warranty, and I am concerned about giving rust a head start, I didn't want to drill any holes in the frame. I don't plan on sliding these on rocks anytime soon. I just wanted a step and a barrier for door-dings. So I simply bolted them on with the 5 bolts per side in the existing factory holes in the frame. They're super sturdy and do not flex at all when I bounce on them. Unflattering pictures are attached. I can't say enough about the quality of the workmanship and their customer service. I highly recommend them and their slidersWKOR1.jpg WKOR2.jpg WKOR3.jpg WKOR4.jpg .
  29. Jun 30, 2021 at 10:48 AM
    #119
    Genuine Cooling Systems
    Genuine Cooling Systems New Member Vendor
    I'd recommend having multiple drill bits as
    Drill your holes and coat each hole with rust bullet. That's what I did and it is hard as a rock. I'm not concerned about the holes rusting.
    jewsNbrews and pvn.beluga[OP] like this.
  30. Jul 11, 2021 at 10:19 AM
    #120
    pvn.beluga
    Phuc (Phooc)
    Connecticut
    FFS, this install was straight forward, but difficult. I was only able to knock out the top frame bolts, so still have to drill out the holes for the remaining bottom frame bolts.
    Tried to drill out the frame holes this morning, but I ended up smashing my left eye with the drill battery. Took a chunk of skin and was bleeding every where...
    @YotaBro take a photo of your rear driver side cab mount. I'm not sure if it's similar to my 2021, but it was a PITA to get to (had to borrow my fiance's small hands in order to get the mounting plate w/ the rod). It's just a really awkward position behind the gas tank. Also, a socket will not fit in that tight space next to the driver's side rear cab mount. My 19mm wrench can only fit at certain angles. I was using a long pair of needle nose pliers to turn the bolt until it tightened the sliders against the frame.
    YotaBro and TRDFerguson like this.
