Does anyone have any photos of their 1st Gen Tundra's with leveling kits?
Discussion in '1st Gen Tundras (2000-2006)' started by PizzaRatzzzz, Jun 23, 2021.
  1. Jun 23, 2021 at 9:22 AM
    PizzaRatzzzz
    PizzaRatzzzz [OP] New Member
    2003 Toyota Tundra SR5 Access Cab RWD
    Can y'all post pictures of your tundra's with lift/leveling kits on them. If you post can you put down the amount of lift for both the front and the rear? Trying to get a good idea of how much lift/leveling I want to do on the truck when it's here.
    YardBird likes this.
  2. Jun 23, 2021 at 9:39 AM
    Welcome to the forum. As you could imagine, this is one of those topics that's been beaten to death. Do a search on leveling kits and check some already existing posts to get an idea of what you are looking for. Cheapest route is some spacers for your existing coils, many companies make them. 2-2.5" is most common. Most popular option is probably Bilstein adjustable 5100's for the front to level it using your existing coils. From there on up you can spend as much money as you want for the same look, with higher end more capable parts, just depends on what your gonna do with the truck as to whether you wanna go big $$.
  3. Jun 23, 2021 at 9:46 AM
    Sirfive
    Sirfive Socially feral
    ‘02 Limited AC TRD
    Bassani cat-back
    155451870_10158940436125275_460627186309_4dd240d4ba3a3135f47d56b4eaf37a9f6b69e3fc.jpg
    i couldnt install longer shocks without preload. And it seems like uca’s and diff drops are a good idea up to 2.5”.
  4. Jun 23, 2021 at 9:49 AM
    2bak
    2bak Thanks
    M
    Bellingham WA
    2018 CM
    Bilstein 5100 all around. Front on 3rd notch up.
    bmf4069, abcinv and Glock 40 like this.
  5. Jun 23, 2021 at 9:49 AM
    Have to separate some of the suspension components to get the longer shocks in. Need to droop the lower A arm all the way down. And diff drops for anything OVER 2" is a good idea. Also sturdier CV boot clamps if 4WD, believe the OP is 2WD so he will need neither.
    des2mtn and Sirfive like this.
  6. Jun 23, 2021 at 9:58 AM
    Toyoda Tundra
    Toyoda Tundra Boxing and Tundras
    2WD 2004 AC Tundra. V8 strong
    That’s a nice looking truck! Did you have to do anything else after replacing the shocks? Diff drop?
  7. Jun 23, 2021 at 9:59 AM
    YardBird
    YardBird Native San Diegan
    Jonesy
    2005 RCLB
  8. Jun 23, 2021 at 10:07 AM
    toyofan87
    toyofan87 Beer thirty
    Seth
    Gettysburg, Penna
    Welcome
  9. Jun 23, 2021 at 10:30 AM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
  10. Jun 23, 2021 at 11:21 AM
    Legender
    Legender New Member
    Carlton
    DFW
    2006 Tundra DC Limited 2WD
    None yet.
    That's exactly what I'm looking for and just ordered the Bilsteins all around. What delta did you have between the front/rear when you put it on the third notch? I have 2.5 inch delta front to rear and was thinking I needed to max out the front? Perhaps not based on yours.
  11. Jun 23, 2021 at 11:43 AM
    Too much front induces the dreaded "Bro-lean" not to be confused with Olean, the fake fat that they pulled from the market because it caused the raging shits. Level or darn close was my goal. I think I have about 2 1/4 - 2 1/2" lift from the 4th notch on TRD coils on an AC. Sat just below level in the front when first applied, now the rear has begun to sag. Gonna put some HD rear leafs to correct it.
    bmf4069 and Darkness like this.
  12. Jun 23, 2021 at 4:10 PM
    assassin10000
    assassin10000 New Member
    Andrew
    Northern CA
    '05 SR5 AC
    Those look more like 2nd gen shocks.
    Darkness likes this.
  13. Jun 23, 2021 at 5:29 PM
    Sirfive
    ‘02 Limited AC TRD
    Bassani cat-back
    Theyre from a 3rd gen taco.
