Towing problems- No transmission cooler on 2020 TRD Pro
Discussion in 'Towing & Hauling' started by RIck729, Jun 16, 2020.
  1. Jun 23, 2021 at 10:36 AM
    #211
    Oey12
    Oey12 New Member
    Joey
    New York
    2020 SR5 TRD OFFROAD
    How fast were you driving, were the roads hilly, and what kind of trailer were you pulling?
    Cpl_Punishment likes this.
  2. Jun 23, 2021 at 10:58 AM
    #212
    hagrid
    Spraynard
    Pittsburgh
    K1600GTL ZX-14R
    paynuss stretchers
    I dunno... I have access to 4 pallets of copier paper and 58 toner cartridges.
  3. Jun 23, 2021 at 11:14 AM
    #213
    realprotundra
    realprotundra Always Skeptical
    Gilbert, AZ
    2021 Lunar Rock TRD Pro DC
    Around 4k lbs (including trailer). Lets call it 4500. Steel deck dual axle car hauler.
    75mph, very hilly roads.
  4. Jun 23, 2021 at 11:20 AM
    #214
    blanchard7684
    blanchard7684 New Member
    I noticed on hilly sections the converter is unlocked way more than on flatter sections. Usually right when going up or going down.
    it will resume lock up when truck is steady on incline or decline.
    Terndrerrr likes this.
  5. Jun 23, 2021 at 11:28 AM
    #215
    That is one nice setup you have. Crawler is bad ass too.
    Oey12 likes this.
  6. Jun 23, 2021 at 11:54 AM
    #216
    Oey12
    Oey12 New Member
    Joey
    New York
    That definitely is a nice setup! Beautiful trucks! I don’t mean to be a d$&! but with that setup, speed, and those conditions I would argue that 266 is on par. Those trailers for whatever reason are like anchors. Or at least the few I’ve pulled…
  7. Jun 23, 2021 at 12:07 PM
    #217
    realprotundra
    Gilbert, AZ
    Thanks! Crawler will be frame stretched 20" here shortly and the front will be linked before it cools down enough here in AZ to actually go wheeling again. That and all of our national forests are 100% closed until September anyway due to fires.
    I think that on par for a vehicle without an external trans cooler is probably right. The issue is that 266 is just too hot for trans fluid without very frequent flushes. There is no doubt that the external cooler is necessary if you actually tow with the truck but like many people have said, the vast majority of Tundra owners are just driving to the mall and throwing their kid's football gear in the bed.
    I think that an appropriate solution would have been to make the external trans cooler an option rather than eliminate it all together. It could have been port/dealer installed and would have kept the overall assembly line and production costs the same without making it impossible for those of us that actually use our trucks like......trucks......to install a cooler and maintain our factory warranty.
    For me.....trading it in on a 3/4 ton or 1 ton when the lease is up.
  8. Jun 23, 2021 at 12:34 PM
    #218
    PWMDMD
    PWMDMD New Member
    Worcester, MA
    2020 Tundra Platinum
    Crazy idea here...if the cooler can go on...it can come off. It might be a PITA but if you need a new transmission or are having catastrophic transmission symptoms take off the cooler. If you go in for warranty work for anything other than the transmission or radiator I guarantee the Toyota tech knuckleheads would not even notice the cooler and even if they did if it wasn't directly related to what they were doing that day not care.
    jordoncloutier and farm&forest like this.
  9. Jun 23, 2021 at 12:58 PM
    #219
    Kinda doing the same right now. Roll cage and back half.
    7A2ADE36-9DF8-4E78-94EF-B8C1A982F88F.jpg 87A8A83E-B619-4632-89F8-6560144E6BE1.jpg
    realprotundra[QUOTED] likes this.
  10. Jun 23, 2021 at 1:11 PM
    #220
    realprotundra
    Gilbert, AZ
    Nice!
  11. Jun 23, 2021 at 1:20 PM
    #221
    GODZILLA Ask me about my hot doc
    This is why you heated up so badly. Drop the speed down 10 MPH. The manual on every 2019+ recommends not towing over 60 or 65 MPH.
  12. Jun 23, 2021 at 1:24 PM
    #222
    No kidding? Would you take a screen shot of that for me Adam?
  13. Jun 23, 2021 at 1:37 PM
    #223
    Lifer
    Lifer New Member
    Vince
    2000 Ltd 4x4 2008 SR5 4x4 LB 2021 SR 4x4 LB
    Fab tech on the 2000
    They never listen!!!
  14. Jun 23, 2021 at 1:42 PM
    #224
    Clemsonman14
    Clemsonman14 New Member
    2020 SR5 Crewmax 4x2
    Here is what it says in my 2020 manual
  15. Jun 23, 2021 at 1:47 PM
    #225
    Thank you.
    Oey12 and Clemsonman14[QUOTED] like this.
  16. Jun 23, 2021 at 1:57 PM
    #226
    Oey12
    Oey12 New Member
    Joey
    New York
    Did not get a chance to respond until now but that is my thoughts as well. IMHO if the Tundra is driven at that speed or less in severe conditions like mountains and high temps that it will be just fine without the cooler. Consistently above…than maybe you will need a cooler?
  17. Jun 23, 2021 at 1:58 PM
    #227
    AZBoatHauler
    So.Arizona
    To be fair, that warning / tip was in the manual before they pulled the ATF cooler. From my 2017 manual -
    GODZILLA, Oey12 and Cpl_Punishment like this.
  18. Jun 23, 2021 at 2:16 PM
    #228
    Oey12
    Oey12 New Member
    Joey
    New York
    Very true but I think that is in both manuals for good reason. That while towing the Tundra should not exceed 65 mph. User be warned in a sense…. Now if the transmission fails while strictly adhering to the manual than I feel there is a legitimate gripe with Toyota. It basically says what how the truck should be used in conjunction with the maintenance guide.
  19. Jun 23, 2021 at 2:23 PM
    #229
    Kanobi13
    Kanobi13 New Member
    Bravo bravo!!!
  20. Jun 23, 2021 at 2:58 PM
    #230
    3rdTundra
    3rdTundra Hay Hauler
    Central Texas
    2017 Tundra SR5 Double Cab TSS 4x4
    FRAC harness / camera & Full set of Valhalla plates
    OK. I read that differently. I read this to mean "use S4, not D, in order to maintain engine braking efficiency and charging system performance", i.e. not to say "use D unless you need engine braking or more charging performance".
    Clemsonman14 and AZBoatHauler like this.
  21. Jun 23, 2021 at 3:08 PM
    #231
    glowblue
    glowblue From time to time
    VA
    Speaking of what does the OM say, the Tundra is designed primarily as a passenger and load-carrying vehicle. This is from the 2021 OM.
    GODZILLA and Cpl_Punishment like this.
  22. Jun 23, 2021 at 3:12 PM
    #232
    AZBoatHauler
    So.Arizona
    You and me both.
    Clemsonman14 likes this.
  23. Jun 23, 2021 at 3:20 PM
    #233
    Kanobi13
    Kanobi13 New Member
    When do you guys use engine braking going 90 on freeway or use the engine instead of brakes down a hill?
  24. Jun 23, 2021 at 3:26 PM
    #234
    AZBoatHauler
    So.Arizona
    This - but only if you call 8% grades a hill. Brakes pads and rotors don’t last long riding the brakes down a huge grade especially when towing a heavy load.
    JLS in WA likes this.
  25. Jun 23, 2021 at 3:40 PM
    #235
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    Black Boxes Matter
    Bakershack and Lifer like this.
  26. Jun 23, 2021 at 4:02 PM
    #236
    glowblue
    VA
    The box isn’t black, it just doesn’t reflect any light in the visible color spectrum.
    hagrid[QUOTED] likes this.
  27. Jun 23, 2021 at 4:09 PM
    #237
    Would have, but I was a sleep. Naps on days off are righteous! :D
    I originally thought the same, but wound up being convinced otherwise. Might have been you, Chris, that convinced me. I'm old and forget, but I remember learning... I think.
  28. Jun 23, 2021 at 4:15 PM
    #238
    Ruggybuggy
    Ruggybuggy Seasoned Veteran
    Dave
    NW ON, CANADA
    2016 Tundra OR
    Why dont you give them a call and find out for yourself? :thumbsup:
  29. Jun 23, 2021 at 4:29 PM
    #239
    Melikeymy beer
    Melikeymy beer No cooler for you!
    Muscogee Nation
    2019 Platypus Tundra
    So maybe I'll just shove it in D and t/h and let it rip. I was only using S4 because members that monitor temps reported lower temps when they went to S4. Back to trying to fry this thing.
  30. Jun 23, 2021 at 4:49 PM
    #240
    Lifer
    Lifer New Member
    Vince
    I have a 2008 that I have towed many things many places. I never read any manual on how to drive it. Pulling heavy I start in S1 and shift manually burping the throttle to let it.
    Don't lug the trans, using the proper RPM range of the beasty 5.7 takes the load off the trans. Same with our 4.7 2000. I would and still do manually shift it, it does not hurt them.
    I will be honest without the cooler on the new 21 I feel I will be adding it. I prefer the cooler the 08 has. I too learned the hard way years ago,
    4 banger automatic 4runner pulling a heavy boat into a strong wind in OD. Smoked it.
