Potentially snapped Timing Belt
Discussion in '1st Gen Tundras (2000-2006)' started by thefish712, Jun 21, 2021.
  1. Jun 22, 2021 at 8:16 PM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    You will need an engine from an 05-06 tundra, 05-07 sequoia or if you transfer everything an 07-09 tundra 4.7 will work.
    Older ones do not have VVTI and will not work
    The key difference to notice is the plastic intake manifold vs aluminum. Plastic is the VVTI manifold
  2. Jun 22, 2021 at 8:19 PM
    thefish712
    thefish712 [OP] New Member
    Fish
    2005 Toyota Tundra 4.7L V8 4WD Double Cab
    Okay, so that should be good news, right? The plastic intake manifold is cheaper?
  3. Jun 22, 2021 at 8:20 PM
    empty_lord
    05 rollover special
    For total engine? Price will vary based on mileage.
  4. Jun 23, 2021 at 7:14 AM
    Sirfive
    Sirfive Master Procrastinator
    ‘02 Limited AC TRD
    Bassani cat-back
  5. Jun 23, 2021 at 7:34 AM
    thefish712
    Fish
    Won't know until later this afternoon. They're taking a look at the engine today. I'm in PST time so it's still early. Needless to say, I'm on pins and needles here lol
    Sirfive[QUOTED] likes this.
  6. Jun 23, 2021 at 7:56 AM
    2mchfun
    Never have fully understood why they don't design belt drive engines with two belts. I mean come on, add a half inch to the engine length for the secondary and a belt broken sensor to kill ignition for the primary. Yes, I know maintenance schedule blah blah blah. Just sayin, redundant systems are not always a bad thing.
  7. Jun 23, 2021 at 8:12 AM
    rock climber
    rock climber New Member
    2001 Sequoia 4X4, 2000 AC 4X4
    If the engine is shot, I'd go the junkyard route. I see a lot around here for $1,000 with less than 125,000 miles. So $1,000 for the engine, $1,500 for the the swap and $500 for other random stuff.
    I'd also take a hard look at replacing the alternator and starter while you're in that deep.
    Take a look at the Hewitt secondary air injection bypass kit, or consider getting all of those parts replaced at the same time (It's like $1,500 just in parts though)
    FirstGenVol likes this.
  8. Jun 23, 2021 at 8:28 AM
    jerryallday
    jerryallday New Member
    Jerry
    Pasadena, Ca
    2006 DC SR5 V8 Grey
    Sequoia engine might be your best bet they are pretty cheap and more common in LA then a 05-06 tundra. Hopefully no damage was done.
    my buddy drove from LA -Vegas this weekend in a 07 sequoia. Truck over heated after Barstow the whole way, He just kept driving. Coolant blew up out of the res and had the lines all sucked in.
    Walked him thru how to check for issues, they put coolant back in 2 gallons (it was empty empty). Drove it back no issues. I looked at it yesterday and couldn’t find any issues. Taking it to a shop this week for a full look. Anyways these engines have a lot of give.
    any photos? We like phots
  9. Jun 23, 2021 at 8:34 AM
    Since you didn't report hearing any carnage I'm still hoping you get lucky like the other guys. I would think if anything, VVTI might be a bit more since there were less made with VVTI therefore there might be fewer engines to pick from. :fingerscrossed: for you though.
    2mchfun likes this.
  10. Jun 23, 2021 at 8:35 AM
    2mchfun
    Might suggest to change the thermostat, also I wouldn't ever be loaning any ride to that buddy if I were you!
    jerryallday[QUOTED] likes this.
  11. Jun 23, 2021 at 8:37 AM
    TexAggie
    TexAggie New Member
    Eric
    2017 CM
    :eek2:
    FirstGenVol and 2mchfun like this.
  12. Jun 23, 2021 at 8:46 AM
    jerryallday
    Jerry
    Pasadena, Ca
    2006 DC SR5 V8 Grey
    Hahahaha agree.
    I told him to do the water pump, thermostat and timing belt.
    2mchfun[QUOTED] likes this.
  13. Jun 23, 2021 at 8:49 AM
    2mchfun
    Add an oil change to that list, at minimum.
  14. Jun 23, 2021 at 8:57 AM
    jerryallday
    Jerry
    Pasadena, Ca
    2006 DC SR5 V8 Grey
    Funny thing, he did a oil change and had someone give it a look before heading out earlier in the week.
    It was 115 in Vegas this weekend. I told him to be cautious after Baker on the 15 because I have over heated there many many years ago in a 07 Camry ( ac full blast, fully loaded down with luggage and ppl, going 90+) he confirmed he was doing the same :).
    everytime I drive that that section I cut the ac now or anytime I see signs that say “cut ac to prevent overheating”
    One more photo
    Darkness and des2mtn like this.
  15. Jun 23, 2021 at 9:12 AM
    N84434
    N84434 In the Frozen Tundra
    Milwaukee WI.
    2001 Limited TRD
    Jeepers! It gets so hot they put signs up? Yikes!
    I assume Baker on the 15 is a hill?
    Darkness likes this.
  16. Jun 23, 2021 at 9:28 AM
    des2mtn
    SW
    2004 Black DC Limited 4x4
    Tonto cover
    Not as common now, but you could also find spigots on the side of the road and at truck stops that would say something like "Non-potable water - radiator use only".
    N84434[QUOTED] and Darkness like this.
  17. Jun 23, 2021 at 9:37 AM
    jerryallday
    Jerry
    Pasadena, Ca
    2006 DC SR5 V8 Grey
    Yup it’s uphill 20 miles
    sign looks like this
    Darkness, bmf4069, 15whtrd and 2 others like this.
  18. Jun 23, 2021 at 12:32 PM
    OP, if you do have to get a new motor, I would recommend doing headers at the same time if that's something you would want. It would be the perfect time.
  19. Jun 23, 2021 at 6:52 PM
    assassin10000
    assassin10000 New Member
    Andrew
    Northern CA
    '05 SR5 AC
    I see anything like that and its time to act like I'm towing. O/D off, slow down from 80-90 and take it easy for a bit. (O/D off raises engine rpm, which will both increase fan speed and lighten load on engine.)
  20. Jun 23, 2021 at 6:56 PM
    #50
    Good lord who drives 90!?! And stay off my lawn!!
  21. Jun 23, 2021 at 9:00 PM
    #51
    Jdtuned
    Jdtuned New Member
    01 AC sr5 4.7 2wd
    No mods besides regular maintenance and up keep.
    I could have sworn I read this motor was non-interfering I guess all signs point toward that being inaccurate. Fingers crossed it’s not too bad.
  22. Jun 23, 2021 at 9:04 PM
    #52
    Roborob70
    Roborob70 New Member
    Robert
    18 Toyota Tundra TRD
    Forget the belt just use a chain.
    Jack McCarthy and bmf4069 like this.
  23. Jun 23, 2021 at 9:06 PM
    #53
    empty_lord
    05 rollover special
    Chains are common place again these days. Belts were used to reduce noise and easier to replace. Older chains weren’t nearly as reliable as modern ones.
    the UZ originally came out in 89.. so shes dated
    Darkness and tvpierce like this.
  24. Jun 23, 2021 at 9:09 PM
    #54
    Roborob70
    Robert
    All the vehicles I have had with a chain, never a problem...done a few belts pain in the ass lining up two cams and a crank....
  25. Jun 23, 2021 at 9:10 PM
    #55
    empty_lord
    05 rollover special
    Chains are great. This engine just missed the start of Toyota’s chain switch over. My 06 corolla had over 800k miles on its original chain. That being said, Chevy v6s are famous for chains failing at or around 100k.
  26. Jun 23, 2021 at 9:12 PM
    #56
    Roborob70
    Robert
    Yeah my buddy lost his in his f150 only 132 on clock
    empty_lord likes this.
  27. Jun 23, 2021 at 11:06 PM
    #57
    ToyotaJim
    ToyotaJim New Member
    So, if I understand right, OP has a truck with 218,000 miles and no records of a belt replacement. And keeps piling on miles driving on the highway... putting on 9k miles. Good gravy....
    This is a 90k or ~10 year maintenance item. It should be almost due for it's 3rd belt, by the way. A truck with that mileage should have IMMEDIATELY been put in for belt service if it wasn't known... live and learn.
    OP, I hope you didn't destroy the motor. Keep us posted.
    onesojourner and 2mchfun like this.
  28. Jun 23, 2021 at 11:09 PM
    #58
    ToyotaJim
    Eh, chains of their own problems. They can snap, or more commonly their tensioners fail. That's often far more expensive than a belt replacement on a schedule. And some designs (Audi) put the chain in the back of the engine requiring the entire engine removal for maintenance.
    I sort of prefer belts. Just service them on their schedule.
  29. Jun 23, 2021 at 11:12 PM
    #59
    Sirfive
    ‘02 Limited AC TRD
    Bassani cat-back
    do it right the first time.
  30. Jun 23, 2021 at 11:14 PM
    #60
    2mchfun
    Fuel mileage???? Yeah
