North West BS Thread
Discussion in 'North West U.S.' started by JAMMDOGG, Jan 6, 2014.
  1. Jun 17, 2021 at 12:01 AM
    #3661
    point08
    point08 New Member
    Kyle
    2014 Toyota Tundra 5.7L SR5 4WD DC
    AirLift LoadLifter 5000 Ultimate Plus, AirLift Wireless One 2nd Gen, TRD Rear Sway Bar, Bakflip G2 Tonneau Cover, Running Boards, Tint, Power Tailgate Lock, Hike-It X9 Throttle Controller, Tekonsha P3 Brake Controller with Custom In-Dash Housing, Method 701 Wheels, Toyo Open Country III Tires, 3WLiner Window Mod, External Fuse Box, Dash Cam, Pioneer DMH-1500NEX
    YouTube is usually my go to. Pop n lock? Oem?
  2. Jun 17, 2021 at 6:44 AM
    #3662
    Dsptundra
    Austin TX Area
    2021 Silver Limited CM
    I used the OEM directions available from the Sparks Parts website.
  3. Jun 17, 2021 at 6:44 AM
    #3663
    Dsptundra
    Austin TX Area
    Replacement caps are easy to source if you want to get paintable or black instead of chrome.
  4. Jun 17, 2021 at 7:16 AM
    #3664
    adamreinhardt
    adamreinhardt Blk 17 Platinum 4x4
    Seattle
    2017 Platinum in Midnight Black Metallic
    Pop n lock
  5. Jun 17, 2021 at 7:29 AM
    #3665
    point08
    point08 New Member
    Kyle
    I put one in recently, sourced the directions from YouTube. They’ve fixed the reverse polarity on the new versions, at least when I spliced it in. I had to get different wire splicers from O'Reilly because what it came with didn't close.
  6. Jun 17, 2021 at 7:45 AM
    #3666
    adamreinhardt
    Seattle
    Thanks! I’ll try YT and go with it. Not adept at wrenching on anything, but maybe owning a truck will change that! Can’t wait to slap this on. Also have fender flares and a rear sway bar to install as well
  7. Jun 17, 2021 at 8:43 AM
    #3667
    Blue Thunder
    Washington
    The OEM requires you to run a wire harness from the right front kick panel, along the frame back to the tailgate. Does the aftermarket plug in the same way or is the splicing allow you tie in to wiring near the back of the truck?
  8. Jun 17, 2021 at 10:54 AM
    #3668
    point08
    point08 New Member
    Kyle
    The PopNLock instructions also had me do this. Easy enough on a creeper and just punch through a rubber seal on the bottom of the front passenger footwell. Unless Casey knows another way, I don't think you get a lock/unlock signal rear of the cab
    This is easy enough, just take your time. I recommend picking something like this up as the splicers that came with mine didn't want to close. Rear Sway Bar is also super easy. Just make sure you have a Torque Wrench to set the nuts at the right amount. If you don't have one, Harbor Freight has one pretty cheap @ $20 or so.
  9. Jun 17, 2021 at 12:57 PM
    #3669
    adamreinhardt
    Seattle
    Awesome, thanks man. Will pick em up today and hope to be done before the weekend starts. Heading to the TCs for youth baseball tourney and will be blessed with 8am games both days on days that’ll hit close to if not 100. Would be great to have my truck chores done and get out to play, wanna drive to the Potholes maybe.
    point08[QUOTED] likes this.
  10. Jun 17, 2021 at 6:09 PM
    #3670
    Dsptundra
    Austin TX Area
    Made it. Time to level it up and then crack a beer.
  11. Jun 18, 2021 at 8:12 AM
    #3671
    NWPirate
    Zach
    WA
    Picked up this sweet girl from a shelter yesterday, 2 y/o Terrier mix. Our 10 y/o lab isn't sure what to think yet. :D
  12. Jun 18, 2021 at 9:39 AM
    #3672
    Rabidllamas
    Rabidllamas New Member
    Phil
    WA
    2019 Cement Crewmax TRD OffRoad
    My build- https://www.tundras.com/threads/rabbidllamas-old-man-build.80802/
    From the TC area and temps in the morning are usually nice. Good thing you play early.
  13. Jun 18, 2021 at 11:09 AM
    #3673
    adamreinhardt
    Seattle
    Grew up there (go Braves!) but always wanted to head west. I return dozens of times a year, often just for the heat. Went to Chelan for Memorial Day (shout out for the awesome water slide park Slidewaters and their new wave pool with surfing) then headed to Salmon La Sac on the way home to play by the water and do some cliff jumping. Never understood why anyone is an East vs west kind of person, I luv it all, gimme variety
  14. Jun 18, 2021 at 12:02 PM
    #3674
    Rabidllamas
    Phil
    WA
    Ha! Brave here too. Wife a Lion, kids were Suns. But secretly the kids wanted to be Braves! Have a good trip.
    gosolo likes this.
  15. Jun 18, 2021 at 7:02 PM
    #3675
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    Plans for Father’s Day? The son and family (8 of us) will be eating out under the BIG apple tree. Going with a Mediterranean theme; Will cut about 16 artichokes and grill the hearts. Making a couple bowls of humus, grilled octopus, focaccia bread, miscellaneous olives and cheeses, grilled mackerel, salad and home brewed beer.
  16. Jun 18, 2021 at 7:38 PM
    #3676
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    Damn!
    I’m doing elk steaks on the grill tonight with sautéed fresh green beans and creamed dinosaur kale and some fresh chimichuri on the side. Still haven’t decided in Sundays plans - my youngest graduates HS tomorrow so it’s her day tomorrow
  17. Jun 18, 2021 at 7:51 PM
    #3677
    jewsNbrews
    Jewiston Idaho
    2019 TRD PRO
    Bolt on
    Venison steak for me. Mashed potatoes and green beans.
  18. Jun 18, 2021 at 7:52 PM
    #3678
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    It’s so amazing how much food we’ve been getting from volunteer reseeding. The kale, potatoes and cherry tomatoes are growing everywhere! Almost invasive, lol
  19. Jun 18, 2021 at 7:53 PM
    #3679
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    Give her congratulations!
    point08 and RainMan_PNW[QUOTED] like this.
  20. Jun 18, 2021 at 9:47 PM
    #3680
    NWPirate
    Zach
    WA
    I'll eat all that up except those nasty olives. :D
    Burgers, brats and oysters are on the menu! Plenty of other sides an adult beverages as well.
  21. Jun 18, 2021 at 10:21 PM
    #3681
    Blue Thunder
    Washington
    We are up in Birch Bay with my parents. Nice to get out of the rat race. No clue what’s on the menu this weekend…
    …but next weekend:0341D7C8-6AC1-4AF0-9714-476A8C882181.jpg
  22. Jun 18, 2021 at 10:23 PM
    #3682
    NWPirate
    Zach
    WA
    Nice spread! What's the occasion next weekend?
  23. Jun 18, 2021 at 10:30 PM
    #3683
    Blue Thunder
    Washington
    Just another Saturday. The brisket is an IOU from Father’s Day two years ago. I was told to order one from Snake River Farms and never got around to placing the order. When I saw Mountain Primal had elk, I just decided to go for it.
  24. Jun 18, 2021 at 11:17 PM
    #3684
    point08
    point08 New Member
    Kyle
    This weekend is the 38 gallon swap and tritip and homemade fried shrimp. :cheers:
  25. Jun 18, 2021 at 11:31 PM
    #3685
    BuckWallace
    BuckWallace Ball don't lie.
    Oregon
    Sierra 3500 AT4 L8T
    Just wrapped up my first trip back to Ft. Stevens in over 20 years. Fun to see the kids enjoying what I did as a kid. Makes me feel old...
  26. Jun 19, 2021 at 8:04 AM
    #3686
    Dsptundra
    Austin TX Area
    Love that place! We’ll be there for a week in late August. A last hurrah before the kids go back to school.
    BuckWallace[QUOTED] likes this.
  27. Jun 19, 2021 at 8:42 AM
    #3687
    Blue Thunder
    Washington
    How are the campsites? We are going to try and get down there next year.
  28. Jun 19, 2021 at 8:49 AM
    #3688
    BuckWallace
    Oregon
    Sierra 3500 AT4 L8T
    There are very few "bad" campsites. Some are less private than others, but most are pretty good sized. Loops I, H, L, & M all have full hookups, while every other loop besides the tent loop have electric and water. We did some spot scouting for reservations next year and came up with what we thought was a good list of full hookup sites:
    H26, L31, L39, L40, L35, M50, M48, I81
    You might have to check the site lengths depending on your trailer size—we have a pretty short trailer so we can fit into a lot of places.
    Anyway, I'd say it's definitely one of the better state park campgrounds in Oregon!
  29. Jun 19, 2021 at 4:12 PM
    #3689
    point08
    point08 New Member
    Kyle
    BOOOOOOOO. I wasn't able to complete the 38 gallon swap. After cutting the shit out of the cross-member bar that I had to add, the parking break and gas lines were still in the way. Said F-IT and put the pump back in the 26 gallon and then put it back up in the truck. This is definitely more work than some of the threads have made it out to be. I'll wait till a buddy that can torch-cut it is back in town to get done what I need done to that stupid ass bar. :mad::annoyed:
    Blue Thunder and gosolo like this.
  30. Jun 19, 2021 at 4:37 PM
    #3690
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    Sucks that you are having a hard time! Hope your weekend goes well
