Don't Forget to Change Rear Differential Oil
Discussion in '1st Gen Tundras (2000-2006)' started by DarkMint, Jun 7, 2021.
  1. Jun 11, 2021 at 10:59 AM
    jcrob33
    jcrob33 New Member
    JR
    2004 Toyota Tundra DC // 245k+
    Interesting. I honestly haven't thought about it. maybe I should change that out. Is there a drain plug? Looks like just a fill plug...
    ToyotaJim and Coal Dragger like this.
  2. Jun 11, 2021 at 10:59 AM
    Professional Hand Model
    Fred
    Hand Protectors
    I’d Shpread some of that oil over onto those rusty welds and any other rust on the frame.
    15whtrd likes this.
  3. Jun 11, 2021 at 11:00 AM
    Drain plug is on the bottom. Undo the fill one first though.
  4. Jun 11, 2021 at 11:06 AM
    jcrob33
    jcrob33 New Member
    JR
    Yeah good call. that's a Jeep trick too.
  5. Jun 11, 2021 at 11:44 AM
    Coal Dragger
    Coal Dragger New Member
    Kung Fu Dick
    bmf4069[QUOTED] likes this.
  6. Jun 11, 2021 at 1:09 PM
    Coal Dragger
    Kung Fu Dick
    Finished.
    I think the new gear oil smelled exactly the same as the old gear oil, the color was almost identical as well. Practically nothing on the drain plug magnet, no shavings, just a fine layer of black dust from the ring and pinion gears wearing in.
  7. Jun 11, 2021 at 1:31 PM
    MNtundra
    MNtundra New Member
    Tony
    Minnesnowta
    01' Tundra AC 4x4, 04' CRV 4WD
    Bilstein 5100's, 4runner Wheels 31" BFG, Rear Seat Delete
    Minnesnowta, though I regularly got to CO and AR to visit family. Been pining for a Tundra Meet Up! 1st Gens ONLY. :ohsnap:
  8. Jun 11, 2021 at 7:51 PM
    wandering_boy
    wandering_boy Junior Tech Wizard
    California
    2005 AC SR5 TRD
    Don't let a kid out smart you.
    I did mine at 142k and it was just as black as that. On a side note, I think diff fluid is the worst smelling oil. But prove me wrong
  9. Jun 11, 2021 at 9:32 PM
    ToyotaJim
    ToyotaJim New Member
    I've never done this service and would like to. Can someone please go thru the steps clearly? Thanks.
  10. Jun 11, 2021 at 10:01 PM
    assassin10000
    assassin10000 New Member
    Andrew
    Northern CA
    '05 SR5 AC 2wd
    Fairly simple.
    Open fill plug, to make sure you can add fluid.
    Open drain plug, drain fluid and clean fine particles off the magnet with a paper towel.
    Reinstall drain plug and fill diff with fluid until it starts seeping back out of the hole.
    Put fill plug in.
    GELCW, FrenchToasty, w666 and 3 others like this.
  11. Jun 11, 2021 at 10:57 PM
    Coal Dragger
    Kung Fu Dick
    As simple as that.
    Don’t even need ramps, truck sits high enough in the back to just crawl under it.
  12. Jun 11, 2021 at 11:32 PM
    ToyotaJim
    Excellent, I just looked at the manual and watched some helpful videos. Looks simple enough.
    I have 2 Tundras that I'll be doing this job on and I have supplies already in the garage. A 2WD 2002 and a 2000 lifted 4x4 with big tires... 305/70/16s. I'm wondering if a thicker oil may be needed?? Temps here get below freezing in winter, to above 100 in summer. Idaho.
    Manual seems to call for 80w90 in the rear and 75w90 in the transfer case. If I'm reading it right.
    So, I have enough 75w90 for several jobs, covering me for that exact spec in the transfer case. I have all new, 8 qts. of Valvoline full synthetic 75w90.
    I also have 8 qts. of Chevron Delo 85w140 that I scored on a great sale. I also have about 3.5 qts of 80w90 but 3 different brands (Quaker State, Valvoline, and another) of I presume conventional stuff, partial bottles GL5 specs, garage sale finds; opened, but clean/new/partial bottles. Anyone run a heavier gear oil due to tire sizes or stick with recommended? Can I mix these safely? Is a small difference in weight (75w90 or 80w90) a big deal? I surely can go buy exactly what it calls for but it would be nice to use up what I have in my garage first if it's fine... Otherwise a trip to Autozone is in order.
  13. Jun 11, 2021 at 11:42 PM
    jimf909
    jimf909 Battery almost dead...
    Washington or Idaho
    '03 Tundra SR5 AC 4.7 TRD w/LSD
    Dead stock with oem 16" starfish wheels. We'll see how long that lasts. :) Topper of unknown origin.
    This thread is nice and all, but where's the good ole 'merican cole slaw and diff oil change thread? My diff is intolerant of femented things. It's also gluten intolerant. It's allergic to peanuts too. I think it needs a support group.
    bmf4069, Darkness and wandering_boy like this.
  14. Jun 12, 2021 at 12:11 AM
    ToyotaJim
    By the way, I have 3 telephone book sized repair maintenance manuals for my Tundra. I've often tried referring to them. They are so far quite useless... Huge gaps in explaining steps, big blank pages, I suppose so that the owner can make his own notes from experience or research. A full 3/4 of this page is blank, and there are no helpful tips, steps, or even complete details of how to drain the fluid or put new fluid in... If you didn't know how to do it, or be told, or see it done, you'd be lost following this information.
  15. Jun 12, 2021 at 3:46 AM
    tvpierce
    tvpierce Formerly New Member
    Maine
    In fairness to Toyota, the FSM isn't written for the consumer, it's written for trained techs.
  16. Jun 12, 2021 at 4:56 AM
    brobert225
    brobert225 Firm grasp of the obvious
    The smell is the additive that does the work. You should worry if there is no smell.....+1 on the Mobil 1 gear oil, it is good stuff.
  17. Jun 12, 2021 at 6:03 AM
    Fred
    Hand Protectors
    I’d change out my rear seals (or at least inspect them via ABS Sensor holes for leakage first) before doing a diff oil change.
    wandering_boy and des2mtn like this.
  18. Jun 12, 2021 at 9:22 AM
    wandering_boy
    California
    2005 AC SR5 TRD
    Well these days its not alway
    Ooo. Good note. No point putting new fluid in if it's going to come out or get dirty again
  19. Jun 12, 2021 at 1:24 PM
    assassin10000
    Andrew
    Northern CA
    '05 SR5 AC 2wd
    Unless you are overheating the ring & pinion with massive loads (constant towing and/or racing... Baja anyone?) there is no need for a heavier oil.
    You can mix 75w90 & 80w-90 in the diff with no problems if you have a mix of bottles. The second number is how well it does at operating temp, both should work similar enough.
    If you have an OEM or clutch type LSD, stick to conventional with friction modifier (either included or add yourself).
    For the transfer case I would not mix or use 80w-90, as it will not reach temps the diff will and the slightly lower cold viscosity is a bit better there.
    ToyotaJim[QUOTED] likes this.
  20. Jul 27, 2021 at 10:26 AM
    #50
    mbreed2
    mbreed2 Is not right
    Allentown PA
    2001 Tundra 4x4
    So I just downloaded the fsm from a link on this forum some where. And this oil weight spec is different from my owners manual. Not sure if I should go back to AutoZone and exchange or not... Gut tells me to stick with the owners manual, but maybe there is a bulletin or something updating it.
  21. Jul 27, 2021 at 10:27 AM
    #51
    mbreed2
    Allentown PA
    2001 Tundra 4x4
    Isn't the LSD a TRD after sales upgrade?
  22. Jul 27, 2021 at 10:41 AM
    #52
    des2mtn
    Shady Grove
    2004 Black DC Limited 4x4
    Tonto cover
    LSD is an option on some trucks, but it's not part of the TRD package.
    The quickest way to tell if you have an LSD is to see if your diff has a sticker. Second easiest is to plug your VIN into the Toyota owner's site and it'll tell you there.
    Interestingly enough it looks like the LSD wasn't an option on the 01's according to these brochures. https://www.tundras.com/threads/1st-gen-tundra-brochures.91566/
    YardBird and FrenchToasty like this.
  23. Jul 27, 2021 at 10:59 AM
    #53
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    Yes and no. Some trucks came with the LSD from the factory, others had them installed at dealerships as an add-on. Rumor has it the dealer add-on version holds a bit more power before the clutches slip.
  24. Jul 27, 2021 at 11:19 AM
    #54
    Pucks18
    Pucks18 Fleabit peanut monkey
    2001 Tundra 4x4 Limited trd
    fun fact kimchi is a nutritionally deficit food
  25. Jul 27, 2021 at 12:35 PM
    #55
    Strangebird22
    Strangebird22 New Member
    Terry
    Ohio
    2000 Tundra AC 4.7 4X4 SR5
    Is that because you throw it back up immediately:eek:
    bmf4069, tacoguybill and Hi06silver like this.
  26. Jul 27, 2021 at 3:47 PM
    #56
    DarkMint
    DarkMint [OP] just gettin by
    Ben
    2004 Tundra DC SR5 4WD
    Bulimia is not to be joked about, Turreh!
  27. Jul 27, 2021 at 4:18 PM
    #57
    mbreed2
    Allentown PA
    2001 Tundra 4x4
    Yes, please read minds responsibly.
  28. Jul 27, 2021 at 7:27 PM
    #58
    Sirfive
    Sirfive Socially feral
    ‘02 Limited AC TRD
    Bassani cat-back
    I stole my lsd oil only sticker for a medicine bottle ive got.
  29. Jul 27, 2021 at 8:01 PM
    #59
    Diablo169
    Diablo169 ROKRAPR
    Max
    Santa Cruz
    06 Double Cab 360k+
    My diff fluid was changed 280k ago in 06’ not really worried about it. My Tacoma’s was done 332k ago and is also doing well.
    Maybe at some point I’ll swap them with some Amsoil 75-90
  30. Jul 27, 2021 at 11:19 PM
    #60
    remington351
    remington351 New Member
    2006 SR5 DoubleCab
    And here I thought nobody would be interested in my diff fluid from three years ago...
    bmf4069 and tacoguybill like this.
