Transmission fluid type
Discussion in '1st Gen Tundras (2000-2006)' started by Pucks18, Apr 29, 2020.
  1. May 11, 2020 at 2:42 PM
    JLag01AC
    JLag01AC New Member
    2001 Access Cab
    I actually had no issues and my truck has 207K. Previous owner who owned it for most of its life did one of those “professional” tranny flushes at around around 100K so to my knowledge it had never had a filter and gasket refresh. My only issue was the dreaded rusty seized up dipstick tube. I had to unbolt it - kind of a bitch - but otherwise easy job.
  2. May 11, 2020 at 2:44 PM
    JLag01AC
    JLag01AC New Member
    2001 Access Cab
    Oh and yes the pan magnets had very little metal on em. Very clean for over 200k.
  3. May 11, 2020 at 2:52 PM
    Professional Hand Model
    Fred
    Hand Protectors
    Similar thing here. I’ve had shops do 3 or 4 (can’t remember) full fluid exchanges over the 140k miles I’ve had it. I tow and haul mucho reason for the frequent changes. Now that I’ve retired from professional hand modeling (forced retirement due to stage lighting accident), I do my own 4.25 quart drain and fills every oil change or every other depending. That fluid level being just right is the key in how smooth the transmission works IMO.
    ToyotaJim and bmf4069 like this.
  4. May 12, 2020 at 5:12 AM
    I actually snapped a filter bolt on mine.
  5. Jun 9, 2021 at 9:37 PM
    ToyotaJim
    ToyotaJim New Member
    Bumping this up. I'm doing some drains and fills on my 3 Toyotas. The two Gen 1 Tundras 4.7L call for Dexron II or III. The 2004 4Runner 4.7L calls for Type IV. I believe this is correct, I've triple checked the manuals and talked to a Toyota parts guy to confirm.
    Anyway, looking for more opinions or longer-term users experience with using the Valvoline Maxlife full synthetic. It claims to cover "90%" of vehicles and specifically Dex II, Dex III, and Toyota T-IV. I just bought like 5 gallons of the stuff cleaning Walmart out, for like $4 per qt which made me happy... My prelim research lead me to believe it works fine. My slight hesitation is "mixing" with whatever is in the transmission - which are unknowns. I literally have no idea but assume these fluids are compatible?? Valvoline isn't exactly snake oil....
    Oh, and my fluids in all look excellent. But I want to get after this. On one, I have no records of the trans ever being done, now at 155k. On the other the only record was 212k, now it's at 245k, so ~33k miles ago. So, I definitely need to get after it on these. In 2019 the 4Runner actually had a pan drop, filter replace, drain and fill, and my records might say what they used. I'll have to dig those out...
    Any smart folks with experience want to chime in?
  6. Jun 9, 2021 at 10:10 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
  7. Jun 10, 2021 at 3:51 AM
    Fred
    Hand Protectors
    Stick with Valvoline Dex/Merc (DexIII) on the early 1st Gen Tundras. Cost about $14 a gallon. Its very specific to our transmissions.
    The Type-IV works for other members here. Reason I don’t use it is it covers a wider range of transmissions (see spec) and it costs more. I do drain and fills every other 3.5k mile engine oil change so new approx 4.5 Quarts drained and filled at 7k miles. Extra left overs goes to suck and fills on the Power Steering.
    ToyotaJim[QUOTED] and bmf4069 like this.
  8. Jun 10, 2021 at 4:11 AM
    dbittle
    dbittle Middle Age Member
    Huntsville AL
    2006 V8 RCLB 2WD
    I can chime in. I got started with max life for Honda’s and have used it for several years and 100000+ miles about three times. I put it in a 2008 sienna at about 130000 miles and just sold it with 230000, no problems. It’s in my 2006 4.7 liter now. Like PHM says, the blue bottle is the right answer for Dex III trucks. It’s good quality fluid. It also mixes fine with the factory fluid. Red bottle is fine if you want to go with a single fluid for all vehicles also. I’m doing that right now, actually.
  9. Jun 10, 2021 at 4:45 AM
    The good stuff. My PS leaks so much I just carry this around with me.
  10. Jun 10, 2021 at 4:49 AM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    I have this one, and the red jug now. Keep it with the truck. (Red jug is for car.)
    bmf4069[QUOTED] likes this.
  11. Jun 10, 2021 at 6:17 AM
    onesojourner
    SW MO
    06 DBLcab LTD 4x4
    Just don't use it in an 05-06.
    YardBird and bmf4069[QUOTED] like this.
  12. Jun 10, 2021 at 7:22 AM
    No sir. I like my dip stick.
  13. Jun 10, 2021 at 8:31 AM
    onesojourner
    SW MO
    06 DBLcab LTD 4x4
    But do you like it more than an extra gear?
    bmf4069 likes this.
  14. Jun 10, 2021 at 8:37 AM
    Honestly, I think so. I'd rather have the power that the 05-06 has, but I like having a trans dipstick on both our vehicles. Our 2012 Rav4 has the antiquated 4 speed auto and we still get 28-29MPG highway. I've never been bothered by the transmission in either vehicle but maybe I just don't know what I'm missing. I sure do like the easy drain+fills though.
    bmf4069 likes this.
  15. Jun 10, 2021 at 8:43 AM
    onesojourner
    SW MO
    06 DBLcab LTD 4x4
    On the Interstate pulling a trailer for 12 hours is where it comes in handy. When OD is off there are only 3 left. Over revving and under revving happen a lot. If I was not towing all the time I think I would agree.
  16. Jun 10, 2021 at 9:50 AM
  17. May 13, 2022 at 6:43 AM
    Jorg4709
    Jorg4709 New Member
    Jorge
    Toyota Túndra 2008
    How easy is change the filter and tranny oil on a 5.7? Any recommendations?
  18. May 13, 2022 at 7:17 AM
    bmf4069 likes this.
  19. May 16, 2022 at 12:00 PM
    AV8R4AA
    AV8R4AA New Member
    Greg
    Justin Texas
    2005 Tundra XSP
    My 2005 has no dip stick.needed the more modern fluid.
    Dropped pan, did filter, drain and fill till its bright and clear.
    ONLY use Toyota transmission juice.
  20. May 16, 2022 at 1:31 PM
    #50
    thxcolm
    thxcolm New Member
    central valley, CA
    2001 Toyota Tundra SR5 V8
    Was having some work done at the dealer this weekend and I said I was thinking about doing a transmission filter for my 01' AC 4x2 (i'm at 255k miles). When I first bought the truck 2 yrs ago I did a preventative drain and fill to the truck.
    He was hesitant to replace the filter + pan in the future and said it wasn't a necessity, but said that just the drain and fill works.
    Sounds sound I guess, or is this just a planned oblescence thing, to not change the filter until the tranny gives up the ghost. Thoughts?
  21. May 18, 2022 at 10:11 PM
    #51
    NickB_01TRD
    KY
    01 Tundra V8 4X4 AC SR5 TRD
    I've heard that the filters aren't super restrictive and are unlikely to be clogged. Pan bolts can break on removal as well. Easier to just do drain and fills. Some people do 2-4 of them depending on how the fluid looks.
    FrenchToasty and thxcolm[QUOTED] like this.
  22. Jul 18, 2022 at 4:44 PM
    #52
    Jorg4709
    Jorg4709 New Member
    Jorge
    Toyota Túndra 2008
  23. Jul 18, 2022 at 4:53 PM
    #53
