Let's talk about rotors and pads!
Discussion in 'Towing & Hauling' started by GuppyWN, Jun 7, 2021.
  1. Jun 7, 2021 at 7:41 AM
    GuppyWN
    GuppyWN [OP] New Member
    I put a set of powerstop slotted rotors and hawk pads on several years ago and they served me fine but I've developed a nasty pedal vibration. Instead of turning the rotors I'm going to replace them.
    Was not unhappy with Powerstop but it appears they now recommend slotted AND drilled for towing.
    Are the EBC yellow or Orange pads worth that dang much extra?
  2. Jun 7, 2021 at 7:47 AM
    Nowhereman
    Nowhereman New Member
    Al
    Monterey Bay area
    2021 Tundra SR5 / TRD / Cement
    Rough Country shocks, ReTrax cover, Summo springs, black out badging, bed extender, "some other things I can't mention"
    Check the rotors for run out before tossing them. IF there's some they can be turned.
    I doubt that it's the rotors though. Trucks are not race cars, they don't need full metallic pads.
    Ceramics are good for dust control but not that great in stop start traffic.
    Get an organic / metallic combo as they will perform in 99 percent of what a truck goes through unless your out of control going downhill with a huge load....
    EBCs have been run on our bikes for years. I have not noticed any difference other than cost.
  3. Jul 16, 2021 at 12:21 PM
    Kevin80
    Kevin80 New Member
    2016 SR5 Crewmax
    I'm a little late, so not sure if this is helpful or not, but I had EBC yellow's (can't remember what rotors I had with it) but they wore extremely quick, IMO; under 20K miles.
    I tow a ~6,500 - 7,000 trailer a few times per year and my daily drive is 90 miles on the highway, so I don't think it's overly hard on the brakes, but maybe I'm wrong.
  4. Jul 24, 2021 at 2:40 PM
    Matala
    Matala New Member
    Mark
    Oxford MS
    2014 Tundra 1794 2wd
    Close to pulling the trigger on this
    PARTS & ACCESSORIES
    Cancel
    STOPTECHSPORT SLOTTED CRYO-TREATED ROTOR
    • Front Left
    • Style: Slotted
    • Finish: Black Rotor Hat
    • Manufacturer Part #:
      126.44156CSL
    • For 2014 Toyota Tundra 2wd CrewMax
    • Each:$137.00
    • Qty:
    • Availability:
      In Stock
      Can be delivered Wed, 07/28
    Sub-Total: $ 137.00
    Free Shipping
    Cancel
    • Front Right
    • Style: Slotted
      126.44156CSR
    • Each:$137.00
    • Qty:
    • Availability:
      In Stock
    Sub-Total: $ 137.00
    Free Shipping
    Cancel
    • Rear Left
    • Style: Slotted
      126.44157CSL
    • Each:$125.00
    • Qty:
    • Availability:
      In Stock
    Sub-Total: $ 125.00
    Free Shipping
    Cancel
    • Rear Right
    • Style: Slotted
      126.44157CSR
    • Each:$125.00
    • Qty:
    • Availability:
      In Stock
    Sub-Total: $ 125.00
    Free Shipping
    Cancel
    HAWKHP SUPERDUTY BRAKE PADS
    • Front
    • Material: Heavy Duty
      HB589P.704
    • Per Axle Set:$85.00
    • Qty:
    • Availability:
      In Stock
    Sub-Total: $ 85.00
    Free Shipping
    Cancel
    • Rear
      HB590P.682
    • Per Axle Set:$64.00
    • Qty:
    • Availability:
      In Stock
    Sub-Total: $ 64.00
    Free Shipping
    (38611):
    $0.00
    • Sales Tax:
      $47.11
    SERVICE WITH A SMILE
    Need help deciding? Other assistance? Give us a call or let's chat via email.
    Call UsEmail Us
  5. Jul 24, 2021 at 3:14 PM
    pandapro
    pandapro New Member
    What is holding you back? Also, any reason you’re going with hawk pads over the stoptech pads?
  6. Jul 24, 2021 at 3:16 PM
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
    I never use drill or slot rotors on my track days. I only use factory rotors with hawk blue, stainless brake lines and brake flush with dot 4. Those rotors kill ur brake pad faster.
  7. Jul 24, 2021 at 3:35 PM
    Matala
    Matala New Member
    Mark
    Oxford MS
    Haven't pulled the trigger yet because I research the chit out of things.
    Looking at Hawks because I'm outfitting this CM for truck cap camping and towing.
    Performance Street
    Not Yet Rated | Reviews (71)
    Most Approximate Image Shown
    • For severe duty professional truck fleets and trucks/SUVs frequently towing heavy loads
    • Maximum stopping power, high temperature heat dissipation
    • Extended pad and rotor life
  8. Jul 24, 2021 at 3:37 PM
    SouthWestGA
    SouthWestGA New Member
    2007 Tundra CrewMAX and 2014 Nissan NV3500 Passenger
    If you want to save some money give BrakeMotive on EBay a try
    I have used several sets of their drilled and slotted rotors without issue
  9. Jul 24, 2021 at 8:04 PM
    Matala
    Matala New Member
    Mark
    Oxford MS
    Well, I pulled the trigger tonight.
    pandapro and Winning8 like this.
  10. Feb 23, 2022 at 3:31 PM
    SpooledReel
    SpooledReel Insufficient Funds
    RickyP
    Spanish Fort, AL
    2015 Tundra CM Limited 4x4
    How has this performed. I'm thinking of running this same set up?
  11. Feb 23, 2022 at 3:44 PM
    Part_time
    Part_time Not a new member
    Oregon
    2017 MICA BRONZE SR5
  12. Feb 24, 2022 at 6:59 PM
    HulkSmurf14
    2014 Tundra Limited
    Tastefully enhanced...
    EBC slotted rotors, or StopTech Cryo treated...as for pads, a semi metallic will be the best for your setup...I just tried BuyBrakes.com for my 4runner and it was considerably cheaper than anywhere else and damn near immediate shipping. I am very happy with their site and will order again from them...
  13. Feb 27, 2022 at 4:47 PM
    04rktaco
    04rktaco New Member
    Lee
    California City
    2014 SR5 TRD crewmax 4x4
    All-pro rocksliders RCI aluminum skidplates TRD pro suspension TRD pro exhaust coachman 1inch lift shackles cooper tires
    I had the powerstop kit but the fronts warped a few months after I installed them so went back to new Oem in the front and the original in the rear no problems nice and smooth
