Adding puddle lights
Discussion in '1st Gen Tundras (2000-2006)' started by Cummins3500, May 23, 2021.
  1. May 28, 2021 at 9:35 AM
    Cummins3500
    Cummins3500 [OP] Never finishes.....
    Logan
    Had the gen rights too long to return them. I’ll toss em back in the parts pile for now. I’ll find a use for em eventually. Those led strips and the setup @Baller is running are the cleanest options I’ve seen. Thanks fellas :thumbsup:
    I’m on call next 2 weeks, so all goes well I’ve have something installed. Some of the places we frequent during the summer are bad for snakes.
  2. May 28, 2021 at 9:39 AM
    Baller
    Baller New Member
    '05 Tundra SR5 DC
    Whoa! Why buy a light bar when you can just drive with your hood up! :drunk:
  3. May 28, 2021 at 9:45 AM
    Baller
    Baller New Member
    '05 Tundra SR5 DC
    This is how I have it also. No plans to change it. It works exactly how I want it to.
  4. May 28, 2021 at 10:26 AM
    Tundra18overland
    Tundra18overland Traversing the million mile road
    Jesse
    GA
    2018 SR5 CM Expedition Build
    those are sweet
  5. Jun 5, 2021 at 5:50 PM
    Cummins3500
    Logan
    Decided to bite the bullet and install lights in the mirror. Turned out pretty clean, spacing was off just a touch side to side. I think the step bit walked on me but it’s close. My wife assured me nobody will notice but my Ocd’ness knows it’s there. Sorry about the rotated pictures, no pc to flip em on
    3CA8818C-FB53-41C1-A2DE-B47155A0D283.jpg B72F803B-A085-4B89-972C-7CE5EA00FBF0.jpg E6A0761E-4A97-4F4B-AAFE-C24F169EAF4D.jpg 64629DAE-110E-432B-A7A2-F8CBA5BE463F.jpg E161D188-7187-4DD4-860E-11723CBBBEA6.jpg 1EDB2FD3-C355-4009-8AD6-C4A1BFC8AED1.jpg 4D653A0E-DBBE-473D-BF16-37A9D00ABD14.jpg 48715E12-42D2-41AC-AC33-2477DA45B3CD.jpg
  6. Jun 5, 2021 at 5:52 PM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    Yea... I want to do this too...
  7. Jun 5, 2021 at 6:01 PM
    Cummins3500
    Logan
    Go for it, I was a little nervous drilling the mirror but it worked out pretty good. Hardest part was picking where to drill. The bottom of these mirrors aren’t 100% flat. I think I’m gonna top it off with a small strip of diode dynamics with @Professional Hand Model placement under the truck to cover my back doors.
  8. Jun 5, 2021 at 6:14 PM
    TUNDRA375
    TUNDRA375 New Member
    GA
    2021 TRD PRO LUNAR ROCK
    Awesome I like that..
    Cummins3500[OP] likes this.
  9. Jun 6, 2021 at 5:21 AM
    Fred
    Hand Protectors
    Nice job! I like that you reconsidered your initial job and returned for a Win.
    Having done my side blinkers inside the Mirror Assy I realize how tight it is to fish the wires through. Shoulda done the Puddle Lamps at the same time, but ain’t going back in anytime soon. :D
    1lowlife and Cummins3500[OP] like this.
  10. Jun 6, 2021 at 7:16 PM
    Cummins3500
    Logan
    @Professional Hand Model appreciate it :thumbsup:
    *output pictures above touched off to drill battery
    got a question for ya fellas. Original plan was to run wiring down the door and tap the courtesy lights in the door. That’s not gonna work for me since those lights don’t come on till the door opens. Best I can tell those lights are in the dome light circuit. Is they’re a way to make those door lights trigger with the keyless entry or due I need to be looking to tie my mirror lights in elsewhere? Suggestions ?
    @empty_lord
    @Tundra2
  11. Jun 6, 2021 at 8:26 PM
    assassin10000
    assassin10000 New Member
    Andrew
    Northern CA
    '05 SR5 AC
    Perhaps cargo lamp circuit? Mine come on when unlocked.
    SouthPaw likes this.
  12. Jun 6, 2021 at 10:39 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    I know the cargo lights in the highpoint come on, and some of the interior lights like the center dome do? It's been a while since I used the fob...
    With the door open... Push in the door switch on the center of the cab support with your fingers, and hit the fob button.
    That should make the truck think that the door is shut. Letting you test to see if the door lights come on with the keyfob or not. If they do, it's easy as pie. If they don't... you'll have to to tap into the cargo lights or the interior dome.
    Just a quick test could save you lots of work.
  13. Jun 6, 2021 at 11:30 PM
    Anna's05Tundra
    Anna's05Tundra New Member
    Anna
    05TundraDblCab2wdTRDw/Mishimoto/SnugTop
    SnugTop Camper Shell w/SnugRug OrFab Skid Plate 16" 265 Yokohama Mishimoto Performance Aluminum Radiator Mishimoto Universal Transmission Fluid Cooler 7' 7LED running bar lights w/own relay Westin Step Bar Front and Rear Security DashCam Galaxy DX 595B CB Radio Deluxe Edition Wilson Antenna Interstate Battery Bilstein Coilovers Urethane Pivot Upper Control ArmsNeoprene bushings Rear hitch lights
    Here is what we came up with. We placed these on a bar and attached it to the step board. Added a relay switch in the cab.
  14. Jun 6, 2021 at 11:59 PM
    Cummins3500
    Logan
    @assassin10000 that’s lookin like strong possibility at this point. I was not to have to pull door panels all the way off to get it into the cab lol
    @Tundra2 test reveals door lights don’t come on with the key fob. Just when the doors open. Looks like it I’m gonna have to get in the cab with it. Figures door would’ve been way easy
    @Anna's05Tundra those look good
  15. Jun 7, 2021 at 3:28 PM
    abcinv
    abcinv OEM (+) Junkie
    Tommy
    NW Ga
    Pretty awesome picture of the truck, the water, the city lights, etc. Oh, the puddle lights look great too.
    Nicely done sir!
  16. Jun 7, 2021 at 3:40 PM
    Fred
    Hand Protectors
    Thanks.
    Tundra2 likes this.
  17. Jul 7, 2021 at 10:31 PM
    tyler-brown
    tyler-brown New Member
    Canada, B.C.
    2001 AC Tundra V8 LTD 4x4
    5" tuff country lift 2.5" Eibach front coil overs SPC upper control arms 33x12.5's JBA long tubes Jba mid pipes Jba full exhaust & muffler Dirty deeds 12 hole injectors Front hitch receiver
    [] Finally got around to putting the lights in. I like it. I plan on putting the under hood lights on a switch. And the left over lighting in the box of the truck
    des2mtn and Tundra2 like this.
