Alpharex USA headlights
Discussion in '2nd Gen Tundras (2007-2013)' started by TheBeast, Sep 17, 2019.
  1. May 29, 2021 at 4:44 PM
    #631
    Shedtundra
    Shedtundra New Member
    Spanish Fork, UT
    2012 Black Tundra Rock Warrior
    Alpharex Pro Headlights W/ Level Motor. LED GTR Ultra Series 2.0.
    Headlight Revolution for me.
  2. May 29, 2021 at 8:01 PM
    #632
    MTRock
    MTRock 1889
    Montana
    2013 Rock Warrior DC
    DC rear fold down seats, decals removed, blacked out badges, complete stereo, ceramic coating, ToyTec Boss 3/1.5, RidgeGrappler 305/70r17, blacked out rock rings and center caps, smoked tail lights, BAMUFFLER Alpharex Pro headlights, TRD PRO Sequoia Grille, DAPtune
  3. May 29, 2021 at 9:52 PM
    #633
    shdwkeeper
    shdwkeeper New Member
    2013 Magnetic Gray Tundra 4x4 Limited CM
    Diamondback Bed Cover (Line-X) Bed Rug Mirror Caps (Paint Matched) Door Handles (Paint Matched) 2020 Sequoia TRD Grill Conversion Morimoto XB Fog Lights Alpharex Pro Jet Black Headlights HIKARI 2021 Acme-X H7 LED Bulbs 6112 (top setting) / 5160 Combo @Coachbuilder1 Differential Drop Kit 1.00" @Coachbuilder1 Coilover shims (2 drive-side 1 passenger side) @Coachbuilder1 Front Bump-stop extensions @Coachbuilder1 Front Bumper Shims @Coachbuilder1 +3 Shackles Fuel Vector 18" +20 Wheels 35x12.50x18 Nitto Ridge Grapplers RCI Off-road Engine Skid plate Desert Eagle Off-road transmission/catalytic converter protection plate Interior: VLEDs 5K cabin interior + LED strip footwell Coupe Custom Battery Mount WeatherTech Floor Mats
    Ok thats good to know. I have to replace my drivers side headlight as the horizontal adjustment screw is broke and it just would turn and not adjust the headlight. Come to find out the entire projector is just swaying back and forth. Ugh...
  4. May 29, 2021 at 9:54 PM
    #634
    shdwkeeper
    Headlight Revolution, 10% discount right now till end of May I believe. ALPHA10 is the code.
  5. May 29, 2021 at 10:07 PM
    #635
    Trdwillie14
    Trdwillie14 New Member
    Billy
    2014 trd off road
    2.5 fox 2.5 ads triple bypass T/C uppers Nfab front bumper Westin rear Bajas Rci skids All pro sliders Icon rxt leafs Stt pros Method 701s 37 Mickey Thompson
    They didn’t sell alph when i asked maybe I’m wrong
  6. May 29, 2021 at 10:15 PM
    #636
    shdwkeeper
    Trdwillie14[QUOTED] likes this.
  7. May 30, 2021 at 6:03 AM
    #637
    Trdwillie14
    Billy
    2014 trd off road
  8. May 30, 2021 at 8:03 AM
    #638
    Rozr1
    Rozr1 New Member
    2008 SR5 DC
    Headlight revolution is cheaper with the code alpha10 as keeper mentioned, I tried it on their site and it works. Does anyone know if Headlight Revolution has the 2nd gen pros with sequential turn available or is it the 1st gen? They are closed today so couldn't get in touch with them.
    Trdwillie14 likes this.
  9. May 30, 2021 at 10:48 AM
    #639
    shdwkeeper
    Mine are the 2nd Gen with the sequential turn, just received them 2 days ago. HR drop ships them right from Alpharex factory.
  10. May 30, 2021 at 2:21 PM
    #640
    Rozr1
    Rozr1 New Member
    2008 SR5 DC
    Awesome, thanks.
  11. May 30, 2021 at 4:00 PM
    #641
    5150bronco
    5150bronco New Member
    Justin
    Bay Area, Ca.
    Awesome! Just picked up front set.
  12. Jun 3, 2021 at 5:33 PM
    #642
    shdwkeeper
    UPDATE: Just got my drivers side headlight replaced, as the one I originally installed had a broken adjustment screw. Since I live in SoCal I am only about 45min away from Alpharex warehouse and support. Took my truck down there and met with Nelson (technical support) and Bobby (Manager). Nelson took my truck to the back and swapped out the headlight and adjusted/leveled everything for me. Talk about GREAT customer service, I'd give it 10 Stars.
    I also received and installed the new 2021 Hikari Acme LED H7 Bulbs from Amazon. I will post some night shots later. But these bulbs fit perfect into the Pro Housing, and they are an All-In-One design. So, no need to try and shove all these loose cables into your housing. It's basically the same as a halogen bulb, little beefier, but wow I'm impressed. This technology on LED bulbs gets better every 6 months. Here are some pictures in the housing of the Pros. It's basically level where the housing cover goes. Plus, these bulbs have a 2yr warranty and an upgrade program.
    Let me know your thoughts.
    TheBeast[OP] and 5150bronco like this.
  13. Jun 3, 2021 at 5:37 PM
    #643
    Trdwillie14
    Billy
    2014 trd off road
    Was wondering to do this or go with the luxx or mirottos. How do you like them
  14. Jun 3, 2021 at 5:51 PM
    #644
    shdwkeeper
    I'll see how these bulbs operate at night, but I love the look. The sequential turn signals are great as well as the DRLs. I'll put up some videos of what it looks like at night.
  15. Jun 3, 2021 at 11:43 PM
    #645
    shdwkeeper
    Here are a few shots of the headlights with the Hikari Bulbs I mentioned above. I'm on my driveway and it's sloped away from garage.
    WILLINH likes this.
  16. Jun 4, 2021 at 5:39 AM
    #646
    Trdwillie14
    Billy
    2014 trd off road
    You happy with the output ?
  17. Jun 4, 2021 at 7:26 AM
    #647
    shdwkeeper
  18. Jun 4, 2021 at 7:39 PM
    #648
    Frank1848
    Frank1848 New Member
    2014 Tundra
    Quick question, where you able to place the housing cover back on, or did you leave it open?
  19. Jun 4, 2021 at 11:15 PM
    #649
    shdwkeeper
    Went on perfectly
    Frank1848[QUOTED] likes this.
  20. Jun 5, 2021 at 7:01 AM
    #650
    Trdwillie14
    Billy
    2014 trd off road
    Why not go with a bulb headlight revolution? Just wondering I was looking at the gsr?
  21. Jun 5, 2021 at 3:09 PM
    #651
    shdwkeeper
    You can do that, I like the price point, the reviews, and the simple all in one design. I was just trying out different led bulbs and these worked good.
  22. Jun 5, 2021 at 4:59 PM
    #652
    Trdwillie14
    Billy
    2014 trd off road
    Ok cool I have no idea with bulbs so it’s good to know
  23. Jun 5, 2021 at 5:17 PM
    #653
    Frank1848
    2014 Tundra
    Ok, so I am officially stuck, I’m not electrically savvy when it comes to trucks, I’ve installed my pros on my 2014, since the install they stay amber when you start the truck, and my turn signal bulbs stopped working even after I replaced with a new pair of halogens as I was told by alpharex tech, support. Any help would definitely be appreciated
  24. Jun 5, 2021 at 5:27 PM
    #654
    5150bronco
    Justin
    Bay Area, Ca.
    I just got my alpha Rex shipment today!
  25. Jun 8, 2021 at 11:42 AM
    #655
    Mikepow
    Mikepow New Member
    2014 Tundra Platinum
    Are there any discount codes active currently?
  26. Jun 8, 2021 at 12:02 PM
    #656
    5150bronco
    Justin
    Bay Area, Ca.
    First responder and military.
    You can contact real truck too. They usually do 5-10% off. They are good!
  27. Jun 13, 2021 at 8:54 AM
    #657
    schosports
    schosports New Member
    BIll
    Bel Air, MD
    2014 CM
    I’ve thinking about the same thing. I love the Alpharex Pros because the look like a stock retrofit and now have the sequential turn.The new, 2nd generation of the Morimoto Xbs have more output due to using all three projectors now but not quite as stock looking and $1,400. So trying to decide...
    - $415 Alpharex Pros with a V-LEDS Micro Pro led bulb
    - $680 Alpharex Luxx Pros
    I know Nelson Mann at Alpharex is very helpful to the Tundra folks on the Facebook TundraCrew group and offers discounts when ordering direct from him. I should just DM him for his input.
    skan and Trdwillie14[QUOTED] like this.
  28. Jun 13, 2021 at 1:07 PM
    #658
    Trdwillie14
    Billy
    2014 trd off road
    I was wondering even talking to headlight rev. I got blubs from them that are like 200 bucks and I’m just kinda like ah lol. But I think I’ll just go pro and do the same
  29. Jun 14, 2021 at 6:29 AM
    #659
    Osmith
    Osmith New Member
    2011 White Tundra 4x4
    I was told there was a shipping delay and headlights are 4-6 weeks out for customers
  30. Jun 16, 2021 at 10:58 AM
    #660
    TxDylanJ
    TxDylanJ New Member
    Dylan
    2012 Silver Tundra Platinum CrewMax
    Blacked Out Emblems, Toolbox, Alpharex Headlights, Anzo Taillights, All LED Light Replacement, 6in Rough Country Lift, 18in Moto Metal MO961
    I have spent a good part of the day searching for an answer to a question, I feel everyone should have, but with no luck.
    I have had the Pros for a couple months now and I have all ways wondered why when I use my key fob to unlock my truck, all the lights are activated but the headlights? Idk if this has been brought up in the past or why they don’t turn on. I was wondering if other had the same question and if there was any solutions to this problem?
