Tailgate Latch Rod Clip?
Discussion in '1st Gen Tundras (2000-2006)' started by Glock 40, Jun 1, 2021.
  1. Jun 1, 2021 at 5:22 PM
    Glock 40
    Glock 40 [OP] I'm here to break shit
    Yukon Cornelius
    Way up thar
    2000 AC Limited 4X4 4.7L
    Deadpool Edition
    Tailgate wouldn't open so I removed the inner panel and discovered the RH side plastic clip (orange) that attaches the pull rod to the closure mechanism is broken. Checking the online dealership diagrams... it's difficult to decipher the exact part number. Anyone had to replace this and can share a part number?
    [​IMG]2021-06-01_06-12-24 by GhostCreekMine, on Flickr
    [​IMG]2021-06-01_06-12-37 by GhostCreekMine, on Flickr
  2. Jun 1, 2021 at 5:24 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    There was someone who went to their local auto store. I think it was a Napa and got suitable replacements.
    Perhaps @SouthPaw? It's been a while since it happened. Memory fuzzy.
    Glock 40[OP] likes this.
  3. Jun 1, 2021 at 5:38 PM
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
    Napa and Autozone....ones I got at az were a little off but not much to matter or go back OEM.
  4. Jun 1, 2021 at 5:41 PM
    chunk
    chunk New Member
    2001 SR5 Tundra, 2WD
    Bone stock, original owner
    I had a broken one too, I know i didn't go through Toyota, I wanted it fixed now. I sourced it locally and for me that would have most likely been Napa.
  5. Jun 1, 2021 at 6:00 PM
    Glock 40
    Yukon Cornelius
    Way up thar
    Deadpool Edition
    We've got a NAPA up here so I think I'm gonna try that first. Thanks!!
  6. Jun 1, 2021 at 6:33 PM
    SouthPaw
    SouthPaw The headlight guy
    2000 Limited 4x4 AC
    Si - https://www.tundras.com/threads/tailgate-rod-clip-replacement.84735/
    DORMAN PART NUMBER - 75450
    https://www.oreillyauto.com/detail/.../v/a/8199/automotive-truck-2000-toyota-tundra
    The black clip in this pack will work. The key is to insert the rod into the hole first and then snap the clip portion onto the rod after. Give Napa that part number and they can cross reference it for you.
  7. Jun 2, 2021 at 12:44 PM
    Glock 40
    Yukon Cornelius
    Way up thar
    Deadpool Edition
    Thanks for this tip, worked like a charm! It's like a little puzzle piece in an awkward location. I could not get my large paw to fit in there so I had a girl snap it all together. Tailgate works great now!
    For future reference, if anyone stumbles upon this thread in need of help... this is the part I picked up from NAPA for about $4.00. Says "GM/Chrysler" but works well for Tundra too. Thanks everyone. :thumbsup:
    [​IMG]2021-06-02_01-38-26 by GhostCreekMine, on Flickr
    MS22, 15whtrd, Festerw and 4 others like this.
  8. Jun 2, 2021 at 12:57 PM
    SouthPaw
    2000 Limited 4x4 AC
    Good deal. I broke the first clip trying it the other way so I figured it definitely worth passing it on.
    Glock 40[QUOTED][OP] likes this.
  9. Jun 2, 2021 at 2:08 PM
    Stolen from Luis
  10. Jun 2, 2021 at 4:03 PM
    Professional Hand Model
    Fred
    Hand Protectors
    Toyota OEM or go home. :rofl:
    Better put some lube all up on everything since she is open. I did this lubing back a few years ago as a prevent measure when my Tail Gate Handle broke.
  11. Jun 2, 2021 at 4:26 PM
    Glock 40
    Yukon Cornelius
    Way up thar
    Deadpool Edition
    Yup, I hit everything with TriFlow before reassembling. :thumbsup:
  12. Jun 2, 2021 at 4:30 PM
    Fred
    Hand Protectors
    :yes:
  13. Jun 2, 2021 at 5:09 PM
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    Usually the Chevy repair kit works.
    tie wire and duct tape :rofl::rofl::rofl:
  14. Aug 3, 2023 at 8:29 AM
    cwestervoorde
    cwestervoorde New Member
    Thank you BubbaW for the parts. Found an easier way to put the clips on ... remove the two torx screws on the side of the tailgate and remove the latch. The plastic clips can then be VERY EASILY snapped in. Then add the bar and slide the (new very strong) clip on. Hope this helps the next person.
    BubbaW likes this.
  15. Aug 3, 2023 at 8:59 AM
    shifty` Bohannon Bohannon Bohannon Bohannon
    Don't forget to lube your shit! :D
