  1. May 30, 2021 at 5:25 PM
    MrDirtjumper
    MrDirtjumper Ol’ dickhead
    Josh
    Slam Angelo, Texas
    06 DC TRD, 2wd to 4wd Conv.
    I think it was @jerryallday that asked about the antenna. God knows that notification was lost over the last 24 hrs.
    Regardless.
    jerryallday and NUDRAT like this.
  2. May 30, 2021 at 5:40 PM
    Desert Dog
    2001 SR5 AC 2WD 4.7l
    Yes, it is. I spent a lot of time under the hood of that XJ over the course of 6 years.
    Still got the Renix set-up in the XJ?
    KarmaKannon likes this.
  3. May 30, 2021 at 5:47 PM
    Desert Dog
    Today I got the body side moldings put back on after burning the midnight oil claying, compounding, polishing and waxing it, which I'm getting too old to do without paying a price for. Once I got that done I replaced the PVC valve and grommet and called it a day. Now I have to prepare for the timing belt job for peace of mind.
    bmf4069, onesojourner, NUDRAT and 2 others like this.
  4. May 30, 2021 at 5:49 PM
    Azblue
    The Dirty T ( ^_^)_且
    Is that a drywall screw holding the fender flare on?
  5. May 30, 2021 at 6:02 PM
    MrDirtjumper
    Josh
    Slam Angelo, Texas
    Parts truck. Wanna buy it?
  6. May 30, 2021 at 6:04 PM
    Azblue
    Hey, if it works, it works. :thumbsup:
    RUSTYNUTS likes this.
  7. May 30, 2021 at 6:10 PM
    MrDirtjumper
    Josh
    Slam Angelo, Texas
    I think @jerryallday also asked about the door panel.
    If construction materials keep going up, I’m gonna part this truck out for screws.
    RUSTYNUTS, bmf4069, Voss and 4 others like this.
  8. May 30, 2021 at 9:13 PM
    jerryallday
    jerryallday New Member
    Jerry
    Pasadena, Ca
    2006 DC SR5 V8 Grey
    Hahaha I looks like mine, but I used Gorilla glue. Let me know about the antenna, I need this bolt below, it’s the chrome one.
    I have the plastic molding already. Just need part #4
    Voss and NUDRAT like this.
  9. May 30, 2021 at 9:36 PM
    jerryallday
    Jerry
    Pasadena, Ca
    2006 DC SR5 V8 Grey
  10. May 31, 2021 at 7:02 AM
    onesojourner
    SW MO
    06 DBLcab LTD 4x4
    Polish jobs deserve photos.
    What do you plan to seal it with?
  11. May 31, 2021 at 7:21 AM
    Desert Dog
    I sealed the pure polish with some Meguiar's Gold Class.
    Edit: This was just an initial clean-up so I could get a better look and feel for the condition of the paint. I'll go back soon and redo the job a 2nd time even more thoroughly but apply 3M Paint Protection (commercial grade) after the polish but prior to a wax on top of the 3M.
  12. May 31, 2021 at 2:54 PM
    Thrussn
    Thrussn Plastidip Hoe
    Gabe
    NM
    Silver 2005 4.7L 4WD Access Cab
    Bilstein 5100s, SickHIDs projector housings, Plastidip everything, TRD Pro style rims, LEDs everywhere, SUPERBUMP bumpstops. Firestone Riderite air bag springs, Deaver G57s, Onboard VIAIR system, Backup Camera, light bar behind the bumper, CGS catback, Exhaust cutout after cats, JBA Shorty headers, JBA Y-Pipe, pioneer deck, pioneer speakers, kicker 10" sub w/ amp, door sound deadening, Dirtydeeds 12 pin injectors, UniChip, Skid Row Skidplate, EZ Oil Drain valve (Better than Fumoto), Oil Catch Can, & 4WD Conversion
    I would imagine it does. It was stock except for the exhaust and lift. I found out later that it has the I4 and not the I6 though. My friend plans on doing an LS swap when the I4 is ready to retire since it will be almost equal to the labor and cost to put the I6 in.
    I did the PHM steering seal fix today. I could tell it's been torn for a while, but I finally schmeared some silicone on the tears in the rubber. Big difference in noise
  13. May 31, 2021 at 2:58 PM
    Professional Hand Model
    Fred
    Hand Protectors
    Smoovvv!
    Thrussn[QUOTED] likes this.
  14. May 31, 2021 at 3:28 PM
    wandering_boy
    wandering_boy Junior Tech Wizard
    California
    2005 AC SR5 TRD
    Don't let a kid out smart you.
    This memorial day I spent my morning and afternoon ripping out my intake and then the two air switching valves and the secondary air pump. I really only needed the switches to fix codes P1441 and P1444 but I don't want to rip this thing apart again So the pump is getting replaced as well but I am not bending over for father Yota and shelling out $600 for a new pump I'm going to buy and '03 Sonoma pump which is the exact same minus the connector So just slice the old one on and boom saved $400. Also went ahead and cleaned the throttle body and tried to get as much oily bs out of the manifold. And this is only the beginning. Still have to replace all of my universal joints, carrier bearing, Upper and lower ball joints and the cu de gra, Timing belt and Water pump.
    Voss, oscardog86, bmf4069 and 6 others like this.
  15. May 31, 2021 at 3:30 PM
    Fred
    Hand Protectors
    Nicely. How’d you get the idea to use the Sonoma Pump?
  16. May 31, 2021 at 3:32 PM
    wandering_boy
    California
    2005 AC SR5 TRD
    I spent last night scouring this place to find out what to do with those codes and It led me to this tundra solutions PDF about bypassing the system and the pump was just something they mentioned, and I found a few guys that had done it on their 07's. Might make a thread about this process after this endeavor for those who are as unlucky as me living with CARB BS.
  17. May 31, 2021 at 3:47 PM
    Desert Dog
    Understood. The Renix is a quirky set-up but there are cheap, simple workarounds for it. I understand the urge to put an LS in it though.
  18. May 31, 2021 at 3:54 PM
    Sirfive
    Sirfive Socially feral
    ‘02 Limited AC TRD
    Bassani cat-back
    now flip it over and show me the belly. Please.
    wandering_boy[QUOTED] likes this.
  19. May 31, 2021 at 4:00 PM
    Cummins3500
    Logan
    Got a little done on the truck in between calls today. Went on Friday @ 6 pm and have over 40 hours in so far.
    emblems are back on the truck. Went with a 2nd gen blacked out emblems set. I still haven’t decided if the sr5 badges are going back on or not
    Also got my 3rd brake light situated. Tinted with Lux auto tint to match my tail lights. And some diode dynamics Xpr leds.
    https://www.diodedynamics.com/3rd-brake-light-led-for-2000-2021-toyota-tundra-one.html
    https://www.diodedynamics.com/cargo-light-leds-for-2000-2017-toyota-tundra-pair.html
    https://www.luxeautoconcepts.net/co.../luxe-lightwrap-universal-tint-kit-dark-smoke
    Voss, bmf4069, Filthyphil and 7 others like this.
  20. May 31, 2021 at 4:03 PM
    Sirfive
    ‘02 Limited AC TRD
    Bassani cat-back
    What are the bumper lights?
    Cummins3500 likes this.
  21. May 31, 2021 at 4:03 PM
    wandering_boy
    California
    2005 AC SR5 TRD
    @Sirfive Thats normally only for my only fans subscribers but I'll make an exception (I am replacing the gasket)
    Voss, RUSTYNUTS, bmf4069 and 3 others like this.
  22. May 31, 2021 at 4:06 PM
    Fred
    Hand Protectors
    Hows about a little night time light up on the wall with those xpr’s? Was eyeing those a while back but the $90 was wooooooweeeee!
    wandering_boy likes this.
  23. May 31, 2021 at 4:13 PM
    Cummins3500
    Logan
  24. May 31, 2021 at 4:25 PM
    Sirfive
    ‘02 Limited AC TRD
    Bassani cat-back
    Oh wow. I didnt realize.
  25. May 31, 2021 at 4:33 PM
    jerryallday
    Jerry
    Pasadena, Ca
    2006 DC SR5 V8 Grey
    Built a traction board mount for the snugtop.
    still need to spray paint everything and do some trimming. But here it is. Cost was about
    $30 the metal was the most expensive part.
    Voss, chrisb, oscardog86 and 6 others like this.
  26. May 31, 2021 at 4:35 PM
    Sirfive
    ‘02 Limited AC TRD
    Bassani cat-back
    How ya gonna clean em before putting em back?
    id keep a stiff bristled tire brush nearby.
  27. May 31, 2021 at 4:36 PM
    wandering_boy
    California
    2005 AC SR5 TRD
    A lot of brake cleaner a brush. A lot of brake cleaner
  28. May 31, 2021 at 6:50 PM
    Cummins3500
    Logan
    @Professional Hand Model
    So getting a picture of these things properly lit up proved difficult. My iPhone distorts it pretty bad and definitely doesn’t do them justice. The cargo lights pretty well light up the bed and a clean white color and the brake light is still crisp and clear behind the tint. I’d buy em again in heartbeat. I’ve got zero complaints about the diode dynamics bulbs on the truck
    *also anybody got any tips or tricks for takin a picture of lights and getting a good one? Every time I try they suck. Secondly why do my pictures rotate when they get uploaded?
  29. May 31, 2021 at 9:00 PM
    jerryallday
    Jerry
    Pasadena, Ca
    2006 DC SR5 V8 Grey
    This guy on Instagram is selling a third brake light/chase/ cargo light plug and play. He also does headlight retro fit halos.
    He’s legit, I have bought from him before. Chase light is $350 plus shipping
    his truck is also very nice.
    Demo video below
    https://www.instagram.com/p/CO8zcYunKsS/
    chrisb, Filthyphil and derkerderh like this.
  30. May 31, 2021 at 11:05 PM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    Too bad I run a cap.
