Indecisive on middle or top settings for 5100s
Discussion in 'Suspension' started by Franco4x4, May 19, 2021.
  1. May 19, 2021 at 7:44 PM
    Franco4x4
    Franco4x4 [OP] New Member
    2019 tundra CM
    This is what I ordered today.
    - 5100 Bilstein for all four corners
    - icon compression 18×9 wheels +25
    - 275 70 R18 bf goodrich ko2
    I'm very indecisive on whether I should go with the middle settings or top settings on the 5100s. I'm going for a level look. I'm a bit nervous if I go with top settings the tires/wheels would look small. Can I get some pictures of middle and top settings with same tires/wheels offset please. Thanks
  2. May 19, 2021 at 7:53 PM
    OnespeedTRD
    OnespeedTRD New Member
    Don
    San Diego
    275/70r18 Cooper AT3 XLT on SCS Ray 10s, Eibach Coilovers, DD 12" Exhaust, AJT Blackout Kit, Truxedo Pro X15, paint match/chrome delete.
    Booney likes this.
  3. May 19, 2021 at 7:55 PM
    RanchTracker98
    RanchTracker98 New Member
    2018 Cement TRD offroad
    Middle setting with 275/70 KO2s. Top setting looks too high to me especially with any weight in the bed.
    BlueRibbon4x4 likes this.
  4. May 19, 2021 at 8:02 PM
    Franco4x4
    2019 tundra CM
    Do you think the +25 offset make a difference?
  5. May 19, 2021 at 8:05 PM
    Franco4x4
    2019 tundra CM
  6. May 19, 2021 at 9:03 PM
    RanchTracker98
    A +25 offset will make your wheels stick out further from the wheel wells than mine. Should give it a nice look.
  7. May 19, 2021 at 9:07 PM
    Franco4x4
    2019 tundra CM
    Thanks for the info. I'm leaning more towards the middle setting.
  8. May 20, 2021 at 7:35 AM
    Crunch527
    Iowa
    TRD Supercharger/BAM
    Ranch Tracker is spot on when it comes to the top setting of the 5100s. I agree, it looks too high. For me even it if measures level, but looks high, it is high.
    I just did this...6112 on #2 setting = 1.3” and put a 1/4 inch spacer on drivers side to address the 1/2” lean on drivers side.
    My original plan was to go at #3 = 1.9 and I am so glad I didn’t.
    I wanted a little rake (lower front end) and it ended up level/very slight rake. So, if I had gone #3 at 1.9” I prolly would have been higher in the front which is a total no-go for me.
    To me, the 5100s at top setting make the front too high...then raising the rear is another issue...this can get crazy trying to chase.
    In the pic below there is still a slight rake but I have been considering going to the lowest setting .75” on the 6112s because I want enough rake that the ass end doesn’t squat with a load.
    Pic is 275/70/18, 32” Toyo AT3 tires. 33A526C3-13B4-4F07-9442-367A230E165B.jpg
  9. May 20, 2021 at 7:49 AM
    Franco4x4
    2019 tundra CM
    Dam your truck is so nice. This is how I want my truck to look. What offset on those wheels?
  10. May 20, 2021 at 7:52 AM
    Nice ride
  11. May 20, 2021 at 12:01 PM
    Crunch527
    Iowa
    Thanks for the kind comments. The wheels are the standard machine-faced Toyota TRD wheels (non-Pro) (+60 offset) that came on my truck when new. I had them powder coated and added the 6112s and larger tires at the same time.
  12. May 20, 2021 at 12:13 PM
    sr5shark
    Alan
    Walnut Creek, CA
    2016 SR5
    I went through the same thing when I had my 5100s. My compromise was to go with the middle setting and a coachbuilder shim on each side. This gave me ~2" of lift in front and the truck was dead-level. After a few months I found that carrying constant weight in the bed all summer (popup, chairs, and gear for my kid's swim meets) I was sagging a bit so I installed shackles to lift the back end a bit.
    If you ever carry anything in the bed, and you do not want to lift the rear, I would go with the middle setting.
    For tires I was running 295x65x18 - these are about the same height as the 295x70's. This pict is with 5100's at the middle setting with 1 cb shim, no lift in the back, and 295x65s:
    Noeyes and Franco4x4[QUOTED][OP] like this.
  13. May 20, 2021 at 1:10 PM
    glowblue
    glowblue From time to time
    VA
    One thing to keep in mind is if you want some slight rake so the rear doesn’t squat when you haul a payload. I kept my rake at 1” just for this reason. If you’re not planning on touching the rear I’d go with the middle setting.
    Franco4x4[OP] likes this.
  14. May 22, 2021 at 4:15 PM
    ATV25
    ATV25 Young at heart
    Terry
    Redding, CA
    2019 Platinum
    5100s, Icon Rebounds, Maxxis Razors
    I am planning on 5100s on middle clip, Icons 18x9 +25mm with 275x70s. All on order from a local tire shop. The wife is taking the truck to So Cal at the beginning of June so it will all be installed when she gets back.
  15. May 22, 2021 at 4:47 PM
    Franco4x4
    2019 tundra CM
    Yeah that's what I decided to do. I already recieved the 5100s just waiting on the tire/wheels to install.
  16. May 22, 2021 at 5:02 PM
    ATV25
    Terry
    Redding, CA
    2019 Platinum
    I'm going to wait until the wife gets back from her trip. No use putting 1500 miles on new tires when the ones on the truck now are in good shape. I'm not going to lie, it's killing me ! LOL
  17. May 29, 2021 at 3:37 AM
    Noeyes
    Noeyes New Member
    Shawn
    2021 tundra sr5
    I just made a post about this exact topic yesterday. Trying to decide between going top setting with no shim or middle with a shim. I'm looking for right at 2 inches. Have you had any trouble or complaints with your setup?
    sr5shark[QUOTED] likes this.
  18. May 29, 2021 at 7:49 AM
    sr5shark
    Alan
    Walnut Creek, CA
    2016 SR5
    I ran this setup for about 1 1/2 years and had no issues - it handled well on and off-road. 5100s on the top setting was higher than I wanted to go at that time so middle setting with a shim was the perfect height.
    Noeyes[QUOTED] and BlueRibbon4x4 like this.
  19. May 29, 2021 at 8:04 AM
    BlueRibbon4x4
    Geno
    2015 Blue Ribbon 4x4
    For about a year I ran the mid setting on my 5100s with a shim on each side. I was perfectly level, and kept a nice ride, since I’ve heard feom many that top setting is kinda rough. Currently I have two shims on mid setting, still a nice ride, no issues, and I off-road often.
    Noeyes[QUOTED] likes this.
  20. May 29, 2021 at 8:41 AM
    Pillslinger
    Pillslinger New Member
    Rollin
    SWMO
    2018 Cement TRD CrewMax
    Bed light kit Jerry can mount Badge overlays (removed 2021) Pin stripe / TRD decal / pillar vinyl removal Raised tailgate lettering Center console badge/tray/divider Interior/exterior LED upgrade VLED footwells TVD Vinyl TRD Offroad wheels Icon 17x8 rebound titanium Bubbas Garage grab handles WeatherTech floor mats (Eagle Klaw added) Rough country front shackles (removed 2021) DD SS3 yellow fogs MESO map light replacement Softopper MESO Chrome delete
    I did a similar approach with 5100s. Went with a 305/70 17 on a +25 offset. Set the 5100s to the middle (1.8 ish) then had CB shims in reserve to tweak the height. Ended up at about 2.25 lift in the front then had to add a +1 shackle to get some of my rake back. Yes, I could have just gone with the top setting on the 5100 but I figured I'm reserving some shock travel and some ride quality by keeping them on the middle setting. 20210509_154715.jpg
    Noeyes and BlueRibbon4x4 like this.
  21. May 29, 2021 at 10:35 PM
    Noeyes
    Noeyes New Member
    Shawn
    2021 tundra sr5
    That was my thinking as well on the ride quality. Did you add one of the half inch shims per side?
  22. May 30, 2021 at 2:45 AM
    Pillslinger
    Rollin
    SWMO
    Yep. 1 on each side. :thumbsup:
  23. May 30, 2021 at 2:53 AM
    Noeyes
    Noeyes New Member
    Shawn
    2021 tundra sr5
    Thanks!
  24. May 30, 2021 at 2:58 AM
    Pillslinger
    Rollin
    SWMO
    :hattip:
  25. May 30, 2021 at 4:46 AM
    biebs96
    PA
    As others have stated... middle. Top puts it slightly nose high.
    Noeyes likes this.
