6112 Setting and Tire/Wheel Combo Thread.
Discussion in 'Suspension' started by Rngr188, Apr 4, 2018.
  1. Nov 18, 2020 at 5:53 AM
    #1411
    YotaTruckLtd
    YotaTruckLtd Secret Squirrel
    2014 MGM Limited CM
    Bilstein 6112/5160 Boss 4x4 shims Boss 4x4 shackles Fuel Off-Road Vector wheels 20X9 Nitto Terra Grappler G2 35" tires SPC UCAs OEM TRD Pro Grille OEM 2020 LED headlights and OEM LED fog lights OEM color matched mirror caps and door handles OEM black exhaust tip Ecoological color matched front and rear bumpershellz V3 Go Rhino RB20 running boards XPEL Prime XR Plus ceramic tint 30% front 15% rear 70% windshield BAKFlip MX4 tonneau cover Dasaita 13in Vivid Headunit AJT interior chrome delete black kit AJT climate control black knobs AJT V3 shift knob TVD exterior emblem black inlays 3BMakers Yota hitch cover Husky front and back floormats K&N Select engine air filter GTR Lighting Armor Series LEDs Reverse lights Cargo lights 3rd brake light License plate lights
    The top setting gave my truck exactly 3.30" and has settled down to 3.25". I installed some @BOSS4x4s shackles set at 1.50" in the rear for a leveled look. I also had some SPC UCAs installed and the alignment is great. No issues at all.
    JoshR324[QUOTED] and Rica25 like this.
  2. Nov 18, 2020 at 1:17 PM
    #1412
    mrburns05
    mrburns05 New Member
    Jacob
    Menifee CA.
    2018 4.6L White DC SR5
    Maxtrac 3.5” Spindles Bilstein 6112 Icon AAL Icon 2.5” PB shocks Coachbuilder +1 Shackles AFE dry filter TRD AIA Magnaflow muffler TB Coolant Bypass
    I put icon 2.5” piggy back on the rear. And they work so good it makes the bilstiens feel like a cheap toy if I’m being honest
    equin and Rica25 like this.
  3. Nov 18, 2020 at 1:22 PM
    #1413
    Rica25
    Ricardo
    Tulare
    1605734397222667553171917251856.jpg 16057344470954769163983059530228.jpg 1605734476243301828894963695132.jpg stock tire size the Michellin Ltx At2
  4. Nov 18, 2020 at 2:28 PM
    #1414
    JoshR324
    JoshR324 New Member
    North TX
    Got any pics of your truck? Sounds like the exact setup I’d like.
    Rica25 likes this.
  5. Nov 18, 2020 at 5:46 PM
    #1415
    YotaTruckLtd
    2014 MGM Limited CM
    There are a few pictures in my profile for you to look at as well.
    JoshR324[QUOTED], Nickj619 and Rica25 like this.
  6. Nov 18, 2020 at 11:00 PM
    #1416
    JoshR324
    JoshR324 New Member
    North TX
    looks badass man. Exactly the look I’m going for.
    Rica25 and YotaTruckLtd[QUOTED] like this.
  7. Nov 19, 2020 at 4:51 AM
    #1417
    SnowB0und
    SnowB0und New Member
    2013 SR5
    I’m about to put this setup on, I’ve noticed a lot of you did 1.9 with a CB shim on both sides (or 2 driver one passenger). Does that ride better than top circlip setting?
    Pillslinger likes this.
  8. Nov 19, 2020 at 6:49 AM
    #1418
    RollTide82
    RollTide82 New Member
    Michael
    2019 Tundra 4x4
    There is always a debate. I did the 1.9 setting with 2 drivers and one passenger....can't compare the ride but after talked to Darren from Boss Offroad...that was my choice. Still rides a bit stiffer than stock to me but...only been about 100 miles.
    SnowB0und likes this.
  9. Nov 19, 2020 at 9:22 AM
    #1419
    Tundraofnv
    Tundraofnv New Member
    2020 Cement Crew
    RollTide82: how much of a lift did you get initially and how much did it settle? Is the passenger side level to the driver’s side?
    Thank you in advance
    Rica25 likes this.
  10. Nov 19, 2020 at 6:48 PM
    #1420
    LJOHNS
    LJOHNS New Member
    If I go with 6112’s up front (set on 1.3 because I tow a camper) do I need to replace the rears? I have TRD shocks stock. I just want to go up to 275-70-18’s.
    Rica25 likes this.
  11. Nov 23, 2020 at 1:39 PM
    #1421
    gabewhite
    gabewhite New Member
    2020 Tundra TRD Sport
    Stock...for now.
    Great looking truck!! Any other photos?
    ShinyConcretE[QUOTED] likes this.
  12. Nov 23, 2020 at 8:13 PM
    #1422
    ShinyConcretE
    ShinyConcretE New Member
    Justin
    Northern California
    2020LimitedCM
    Thank you. 8D5C6E55-4723-4CC3-8BFD-F6EC0F04C00C.jpgEA55B3F9-384A-45C6-80C9-1285FE439C8E.jpg
  13. Nov 24, 2020 at 7:26 AM
    #1423
    frichco228
    frichco228 Valued Member
    Frank
    Virginia
    2016 Crewmax 4WD, TRD Offroad
    275/70-18s fit perfect on a stock truck, no lift or changes needed. So if your springs/shocks are in good shape no need to spend the $, just buy the tires you want and enjoy.
    Rica25 likes this.
  14. Nov 30, 2020 at 6:14 PM
    #1424
    ZiaTundra
    ZiaTundra New Member
    I'm looking to do this setup on my 2008 5.7v8 Crewmax.
    What is the CB shim and where do I get it? Will I need it pre-assembled onto the strut coil setup or does it bolt on during installation?
    Rica25 likes this.
  15. Nov 30, 2020 at 7:18 PM
    #1425
    Rica25
    Ricardo
    Tulare
    Shim bolts on during installation
  16. Nov 30, 2020 at 8:23 PM
    #1426
    SHill_96
    SHill_96 New Member
    Spencer
    Boise, ID
    '05 SBM Double Cab Tundra
    Just scrolled through a lot of this thread and didn't see any first gens on 6112s... Is there a reason for that? I've been looking at them for my '05, but was wondering if there's an alternative everybody else uses.
    Rica25 likes this.
  17. Nov 30, 2020 at 8:30 PM
    #1427
    Rica25
    Ricardo
    Tulare
    I've seen a few. Not to many
  18. Nov 30, 2020 at 9:29 PM
    #1428
    NoRcptn
    NorCal
    2017 Platinum
    I’ve had 5100 on my Tacoma’s and went with a rancho quick lift /adjustable ride on my 04. I was happy with them. Rode really nice. I didn’t really know about the 6112’s then, But I just ordered some for my ‘17 Tundra.
    https://www.4wheelparts.com/p/2004-Toyota-Tundra-RanchoRancho-2.25-Inch-Loaded-QuickLIFT-RS999923/_/R-BCKM-RS999923?ppcfon=1&gp=1&ef_id=EAIaIQobChMI4t-qwIas7QIVOCCtBh1djQPxEAQYAiABEgL_q_D_BwE:G:s&s_kwcid=AL!7836!3!430284196272!!!g!671659370080!&gclid=EAIaIQobChMI4t-qwIas7QIVOCCtBh1djQPxEAQYAiABEgL_q_D_BwE
    Rica25 likes this.
  19. Dec 7, 2020 at 5:17 AM
    #1429
    DFW_SoldTacoBoughtTundra
    DFW_SoldTacoBoughtTundra New Member
    DFW
    2021 Limited 4x4
    6112s, Icon add-a-leaf pack, Icon 17s
    Made it through all 48 pages.... all the trucks look fantastic and I believe 6112s are the route I want to go for my '21 Crewmax Limited 4x4. I ran the Eibach kit on my Taco when I had it and love the look of a leveled/lifted truck. I've read about diff drops, CB drops, Coachbuilder shims, etc. and am not sure what all I might "need" for the limited lifting that I want to do. I'd like to run a 275/65R20 (34x10.8) and am wondering if I can get away with this at the 1.9" setting. Hate to even ask this since I'm used to doing a lot of the work myself but is having Toyota install the parts one way to avoid warranty claim denials in the future?
    Rica25 likes this.
  20. Dec 7, 2020 at 6:17 AM
    #1430
    RobertD
    Robert
    DFW, Texas
    You should post in new member intros and show us your truck! That's a good question that I don't have an answer for. I also doubt your dealer will install an aftermarket lift. If you worry about warranty, you might be better off having a different shop that does aftermarket work, install your lift since most of those places warranty their work. Yes it's not the same as your Toyota warranty but it might cover you for your basic issues.
    Rica25 likes this.
  21. Dec 7, 2020 at 10:39 AM
    #1431
    DFW
    2021 Limited 4x4
    I appreciate the response, and to clarify I would not expect Toyota to warranty the aftermarket part, I am more concerned with things they would claim were caused by the installed part whether they were or not (simple example: a leaky cv boot).
  22. Dec 8, 2020 at 7:17 PM
    #1432
    dhdubey88
    dhdubey88 New Member
    Roseville
    2017 SR5 crew max
    Flowmaster 40 series muffler Headache rack/tonneau cover Bilstein 6112 at top notch Bilstein 5160 Coachbuilder +2 shackle Rear diff breather relocate Coachbuilder bumper shims Lower control arm skid trim Oedro bolt on sliders Raceline injector 18” wheels 35x12.5x18 toyo RT
    Installed my 6112 at top setting with coachbuilder +2 shackles and bilstein 5160 on Sunday and got my new tires today. Didn’t get the tires I was planning on but when a good deal comes up you can’t pass it up. Got Toyo R/T 35/12.5/18 and they are a great fit and make the truck look like it should.30B3A12A-F1CB-41F1-8BB8-6B2E0A505442.jpg
    Will try to get some better pictures tomorrow in the sunlight. But very happy with the results of lift with 35s
  23. Dec 8, 2020 at 7:30 PM
    #1433
    Famof5Tundy
    Famof5Tundy New Member
    2020 MGM CM Platinum
    Just getting started
    Definitely need more pics. Looks nice, well done....well except it's a slow color. Gotta have that MGM
    Rica25 likes this.
  24. Dec 8, 2020 at 7:47 PM
    #1434
    dhdubey88
    Roseville
    2017 SR5 crew max
    Yes, more pictures are needed. was busy with this Stupid thing called work today that really gets in the way of other stuff... with the exception of funding the other stuff.
    I thought super white was the faster color. It says it’s super in the color.
    pvmike, Rica25 and RobertD like this.
  25. Dec 8, 2020 at 7:52 PM
    #1435
    dhdubey88
    Roseville
    2017 SR5 crew max
    FA30DB68-6C63-4315-A84D-4A2E9242E68E.jpg 3B885CAC-7513-495C-8B7D-6A401504E314.jpg Here are the pics my tire guy sent me when he finished the install.
  26. Dec 8, 2020 at 8:04 PM
    #1436
    chaddydubbs
    chaddydubbs New Member
    Chad
    Omaha, NE
    2017 MGM Tundra SR5 Crewmax
    Tyger running boards, black badge overlays, stubby antenna, TRD Pro grille, window tint, LED interior lights
    Pretty much solidified my decision between 295/70R18 or 35s. That looks great!
    What about trimming/rubbing??
    Rica25 likes this.
  27. Dec 8, 2020 at 8:12 PM
    #1437
    dhdubey88
    Roseville
    2017 SR5 crew max
    When I first picked up my truck it barely rubbed at full lock in reverse. Then had it aligned and now there is something barely rubbing at full lock in drive. Rims are +18 offset and I have the coachbuilder bumper shims
    I did pull my front fender well plastic down before dropping it off so I’ll see if I can fit that back in hopefully tomorrow
    Rica25 and chaddydubbs[QUOTED] like this.
  28. Dec 8, 2020 at 8:49 PM
    #1438
    FAMILIA5
    FAMILIA5 New Member
    P
    Temecula Ca
    2021 TUNDRA TRD SPORT
    3” Ready lift spacer, 295-70-18, Method 315, Camberg Upper controll arm.
    Hello, nice truck. I have a 3” spacer and want to swap to Bilstein 6112. Is your truck 4x4??
    Rica25 likes this.
  29. Dec 8, 2020 at 9:41 PM
    #1439
    dhdubey88
    Roseville
    2017 SR5 crew max
    Thank you if you are talking to me and yes mine is 4x4. If you want to keep your 3” you’ll need to get some cb shims.
    Rica25 likes this.
  30. Dec 9, 2020 at 8:14 AM
    #1440
    dhdubey88
    Roseville
    2017 SR5 crew max
