Glass breakage sensor install and setup
Discussion in '2.5 Gen Tundras (2014-2021)' started by Sting Ray, Dec 30, 2017.
  1. May 26, 2020 at 8:58 PM
    #121
    gabex35
    gabex35 2020 Limited 4x4 with mods coming...
    San Diego
    2020 Cement Limited 4x4
    I have that security sensor in my 2020 limited. Does that mean that it’s already functioning or do I need to do that tech stream to make it work?
  2. Jul 23, 2020 at 8:16 PM
    #122
    TundraTXTSS
    TundraTXTSS New Member
    Conroe
    2020 White TRD Pro
    Window Breakage add on Alarm,Wireless Charger. Console Safe, Rear Dif Breather Relocation, Rear Under seat Storage, Hard wire for Radar Detector, Tonnneau Cover, Brake Sensor Protection,SABM with TRD Filter, Tailgate lock, BFG's, LED Running lights.D-3 Tuner.
    I just installed one on a 2020 Tundra, you may need to remove the panel by the driver side floor and turn up the sensitivety to max. Like everyone said get inside and clap your hands. I didn't think mine was working when taping on the glass with keys. However the other day my alarm kept going off and couldn't figure why. Well I had some empty jelly jars and had pushed all the lids down. They were slowly popping back up and setting the alarm off. I still need to attach my hood sensor, perhaps this weekend. Now if there was only a level sensor alarm or if it would send me a message in the Toyota App that would be cool.
  3. May 21, 2021 at 3:17 PM
    #123
    TundroLoco
    TundroLoco New Member
    Angel
    2018 tundra SR5
    here is how i manage to enable my alarm system on my tundra 2018 CM sr5 with the shifter on the wheel column as first I enable the alarm in techstream but it did not work trayed everything and nothing but reading i did realize on my tundra the hood sensor was missing and the alarm horn relay also was missing so first i ordered a new relay Replace parts number]: 90080-87026, 90987-02027
    and I did remove the dommy plug cover from the hood sensor wire and jumped with a peace of wire to make the ecu think the hood was closed.. and boo ya now is working. now the i know is working I will order a hood switch sensor on Amazon to completed to system.
    here is the link for the relay is the same as A/C relay it just cost 7 bucks. https://www.amazon.com/dp/B07YG2GKVP?ref=ppx_yo2_dt_b_product_details
    and for the hood latch switch you can get the whole latch assemble here https://parts.lakelandtoyota.com/p/...fJsWBSbatxrC3pih24U2CiEiODLzO19RoCfc0QAvD_BwE
    for 44 bucks but I'm cheap and I am looking just for the switch the I know it will fit on the hood latch.
    bulldog93 likes this.
  4. May 21, 2021 at 5:13 PM
    #124
    danz75
    danz75 New Member
    Everett, WA
    18' Cement SR5
    OEM LED headlights, Rigid SAE foglights, Go Rhino RB10 running boards, ARE Classic CX
    Could you elaborate a little more about the alarm horn relay? I have a 2018 SR5 DC with bench seat and column shifter. Installed the kit and activated in techstream but cannot get it to work.
  5. May 21, 2021 at 8:31 PM
    #125
    TundroLoco
    Angel
    2018 tundra SR5
    did you remove the dommy plug by the hood latch and jump the two contacts? it need to be done. and if you open up the fuse box under the hood you will see if you are missing the alarm horn relay if the spot is empty order the relay and installed.
  6. May 21, 2021 at 8:49 PM
    #126
    danz75
    danz75 New Member
    Everett, WA
    18' Cement SR5
    I did the contacts but have not looked to see if the alarm horn relay is installed. Will have to look at it first thing tomorrow
  7. May 21, 2021 at 10:55 PM
    #127
    TundroLoco
    Angel
    2018 tundra SR5
  8. May 27, 2021 at 10:39 AM
    #128
    TundroLoco
    Angel
    2018 tundra SR5
    is the relay fixed you issue ?
  9. May 27, 2021 at 2:15 PM
    #129
    danz75
    danz75 New Member
    Everett, WA
    18' Cement SR5
    I just received the relay today and will try to install this weekend. Hoping that the relay was the missing link to getting the GBS working.
  10. May 29, 2021 at 7:58 PM
    #130
    danz75
    danz75 New Member
    Everett, WA
    18' Cement SR5
    Installed the relay and the GBS kit today. Verified that the alarm works now. Might have to up the sensitivity on the GBS since I had to clap pretty hard to set it off. Opening the door when the alarm is armed also sets off the alarm. Thanks for the tip.
  11. May 29, 2021 at 8:08 PM
    #131
    TRDFerguson
    Jake
    Southeast Greater Basin, AZ
    2018 MGM CrüeMax
    Anyone know if the GBS is able to pick up the noise of a sawzall cutting exhaust pipes? Wondering if this might be a good add on for catalytic converter theft deterrent.
    eRockAZ likes this.
  12. May 29, 2021 at 9:26 PM
    #132
    TundroLoco
    Angel
    2018 tundra SR5
    you very welcome.
  13. Sep 11, 2021 at 1:11 PM
    #133
    SchnauzerMan
    SchnauzerMan New Member
    Southern New Mexico
    2019 SR5 CM 4x4
    Sumo Struts, Tiger Steps, Bed Rug, Undercover Flex Hard Folding Tonneau Cover
    Just to confirm, if I have the alarm installed and working already (SR5 Upgrade Package) all I need to have the glass breakage alarm function is to install the glass breakage sensor/module (ie no further activation needed)?
  14. Sep 11, 2021 at 6:20 PM
    #134
    TundraTXTSS
    Conroe
    2020 White TRD Pro
    Should be, that's what I did with my 2018, before I sold it I pulled it out and installed it in my 2020. It's all plug and play.
  15. Sep 11, 2021 at 7:34 PM
    #135
    pursuit2550
    pursuit2550 New Member
    2020 Tundra SR5 DC Attitude Black
    Just finished doing it on my 2020 SR5. Plug and play. There are 2 part numbers for the tundra. One is for the 07-13 and 1 for the 14-21. I bought the 07-13 not knowing there was one for the 14+. Only difference is that the 07+ doesn’t bring the hood latch jumper. I just jumped the wires out myself with a pin.
  16. Sep 11, 2021 at 9:52 PM
    #136
    SchnauzerMan
    Southern New Mexico
    2019 SR5 CM 4x4
    Excellent!
  17. Aug 15, 2022 at 7:20 AM
    #137
    purplenova
    purplenova Not a new member
    Tom
    Ohio
    2016 Tundra Crewmax SR5
    Pillar Tape, Bullet Liner, 20% Tint, Tyger Star Armor Kenwood amp & AudioControl LC7i Tech12volts JL Tweeters
    I installed this same item on my 2011 CM and was searching for the same for my 2016, but all dealerships states the item is discontinued.
    Am I searching the wrong part number?
    Glass Breakage Sensor - Toyota (PT398-30120)
  18. Aug 15, 2022 at 7:23 AM
    #138
    bulldog93
    bulldog93 Usually tired...
    Jeff
    Santa Rosa, California
    2020 Super White Tundra TRD Pro
    Try pt39834142
    purplenova[QUOTED] likes this.
  19. Aug 15, 2022 at 8:15 AM
    #139
    purplenova
    Tom
    Ohio
    Thanks
  20. Dec 13, 2022 at 10:18 AM
    #140
    2mchfun
    2mchfun Yeah it'll pull it, just don't expect to stop!
    Just installed pt39834142, already had hood switch, just popped in mic and the brain. Good to go, no tech stream registration was needed. Very easy and affordable.
  21. Mar 4, 2023 at 7:29 PM
    #141
    shannon
    shannon New Member
    shannon
    Manitou Springs, CO
    2010 DC
    Hey man! What year is your truck and what part number did you end up using to make this glass breakage sensor work? TIA
    2mchfun[QUOTED] likes this.
  22. Mar 4, 2023 at 7:45 PM
    #142
    Tundra-XP
    Tundra-XP New Member
    Will
    2020 Toyota Tundra XP MGM CM TRD Off Road
    I have a 2020 SR5 and put in pt39834142. Works great. No tech stream needed.
    bulldog93 and 2mchfun like this.
  23. Mar 4, 2023 at 7:46 PM
    #143
    2mchfun
    2021, part number is in my post directly above your post.
  24. Mar 4, 2023 at 7:50 PM
    #144
    shannon
    shannon New Member
    shannon
    Manitou Springs, CO
    2010 DC
    Yep, I meant to just ask for just the year of your truck. Thanks. I'm looking for a part number for a 2010 and I'm getting mixed results on what fits and doesn't.
  25. Mar 4, 2023 at 7:52 PM
    #145
    shannon
    shannon New Member
    shannon
    Manitou Springs, CO
    2010 DC
    So... does the PT393-30120 fit in your 2011? I found the part but the automated thingy says not compatible with my 2010. Thanks in advance. Just trying to save myself a return.
