How to remove upper control arm from spindle?
Discussion in '1st Gen Tundras (2000-2006)' started by potoghi, May 27, 2021.
  1. May 28, 2021 at 2:33 PM
    #91
    potoghi
    potoghi [OP] Tundra4Life
    Hawaii
    United States
  2. May 28, 2021 at 2:35 PM
    #92
    Sirfive
    Sirfive Socially feral
    ‘02 Limited AC TRD
    Bassani cat-back
    Jump something. Get a vid.
  3. May 28, 2021 at 2:37 PM
    #93
    potoghi
    Hawaii
    United States
    Lmao. One side lifted and the other isn’t. I think that’ll get a few seconds of air time.
    Drainbung, Darkness and Dr Doobie like this.
  4. May 28, 2021 at 2:42 PM
    #94
    N84434
    N84434 In the Frozen Tundra
    Milwaukee WI.
    2001 Limited TRD
    it'll sit differently with weight on the wheels. Looks outstanding!
  5. May 28, 2021 at 2:43 PM
    #95
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
    Drainbung likes this.
  6. May 28, 2021 at 2:49 PM
    #96
    tdrich7
    tdrich7 New Member
    2006 Tundra DC 4wd SR5
    This thread will be perfect for when I attempt any of this stuff for the first time. Glad you got it done!
  7. May 28, 2021 at 3:05 PM
    #97
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    You're doing great. Don't tighten that pivot bolt all the way until the truck is
    Is it just me or does it seem like the shaft is dangling at an angle?
  8. May 28, 2021 at 3:10 PM
    #98
    Dr Doobie
    Dr Doobie Growing member
    Talkeetna,Alaska
    '07 RCSB 5.7 SC'd 4x4 SSM
    That's what she said!:rofl:
  9. May 28, 2021 at 3:12 PM
    #99
    Sirfive
    ‘02 Limited AC TRD
    Bassani cat-back
    Mine looks like that. Not big and red, but a little crooked.
    bmf4069 and DeesCrewMax like this.
  10. May 28, 2021 at 3:14 PM
    #100
    potoghi
    Hawaii
    United States
    Is it just me or does it seem like the shaft is dangling at an angle?[/QUOTE]
    here’s what everything looks like on one side from underneath
    KNABORES, Sirfive and Drainbung like this.
  11. May 28, 2021 at 3:14 PM
    #101
    Drainbung
    Drainbung Some days you are the show...
    Bob
    Oasis of NV
    2019 Cement DCLB 4X4
    TRD Fleshlight
    Darkness and potoghi[OP] like this.
  12. May 28, 2021 at 3:21 PM
    #102
    Professional Hand Model
    Fred
    Hand Protectors
    Yeah. Same here. This job will be upcoming in about 2 years when I need new shocks and steering rack. I feel like a Pro now!
  13. May 28, 2021 at 3:25 PM
    #103
    Dr Doobie
    Talkeetna,Alaska
    here’s what everything looks like on one side from underneath[/QUOTE]
    I'm looking on my phone but shit looks great! Job well done! Congratulations
  14. May 28, 2021 at 4:21 PM
    #104
    potoghi
    Hawaii
    United States
    It was going so smoothly until the c-clip came. Other than that I was able to wack it free in 2 hits.
    bmf4069, Darkness and Drainbung like this.
  15. May 28, 2021 at 4:23 PM
    #105
    Sirfive
    ‘02 Limited AC TRD
    Bassani cat-back
    I broke my snap ring plies trying to open up my old master cylinder. If only toyota had made their leaf springs out of the same metal as the c-clips.
    N84434, potoghi[OP] and Barrett50 like this.
  16. May 28, 2021 at 4:35 PM
    #106
    Sirfive
    ‘02 Limited AC TRD
    Bassani cat-back
    Just file a new flat spot to grab with. Ill do mine, but i spent my round tuit.
  17. May 28, 2021 at 4:36 PM
    #107
    potoghi
    Hawaii
    United States
    5BDE6427-E70B-408F-BEEB-FC996F7DE3C6.jpg FC3CF2A4-EDC9-4B1A-8B70-8D4F1D3963C2.jpg 8F4FF17C-8213-4A8B-A4E8-72F7A3A17897.jpg
    stuffed some thin metal in between after lifting it up a little and used the metal sheet to get my pliers in
  18. May 28, 2021 at 4:38 PM
    #108
    Dr Doobie
    Talkeetna,Alaska
    Get a flat head under,it and behind it, when you get the end of the clip out of the groove.and you can work it out slowly.
    : I see you got it out faster than I can type! lol good job
  19. May 28, 2021 at 4:52 PM
    #109
    Drainbung
    Bob
    Oasis of NV
    TRD Fleshlight
    This. I've had good luck driving them off with a flat head (full responsibility for primitive Pete tool abuse).
  20. May 28, 2021 at 6:44 PM
    #110
    potoghi
    Hawaii
    United States
    Does anyone know the correct way to use this tool for getting out upper ball joints?
    bmf4069 likes this.
  21. May 28, 2021 at 6:46 PM
    #111
    Sirfive
    ‘02 Limited AC TRD
    Bassani cat-back
    Put the nut on the threads? For my blazer i had to use several pieces of scrap metal to make it fit cause the kit didnt have the right sized adapters. I might have used a 3/4”-1/2” drive adapter on the press shaft.
    potoghi[OP] likes this.
  22. May 28, 2021 at 6:51 PM
    #112
    Dr Doobie
    Talkeetna,Alaska
    Looks like the ball joint is almost out. Smack that sumbitch with the Ford wrench (hammer) and it should pop out
    potoghi[QUOTED][OP] and Sirfive like this.
  23. May 28, 2021 at 6:53 PM
    #113
    Sirfive
    ‘02 Limited AC TRD
    Bassani cat-back
    Vise grips for pliers, pliers for a wrench, wrench for a hammer, hammers everything else.
  24. May 28, 2021 at 7:10 PM
    #114
    Dr Doobie
    Talkeetna,Alaska
  25. May 28, 2021 at 7:45 PM
    #115
    potoghi
    Hawaii
    United States
    Some passing thunderstorms flew by so it’s intercession time.
  26. May 28, 2021 at 7:59 PM
    #116
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    Post #79 buddy
  27. May 28, 2021 at 8:21 PM
    #117
    Dr Doobie
    Talkeetna,Alaska
    I'm wit ya, bowl break,gotta keep da head right:rasta:
  28. May 28, 2021 at 8:40 PM
    #118
    MrDirtjumper
    MrDirtjumper Ol’ dickhead
    Josh
    Slam Angelo, Texas
    06 DC TRD, 2wd to 4wd Conv.
    I’ve done UBJs twice and Jesus Christ, while thoroughly entertaining, this thread is full of some of the worst advice I’ve ever seen.
    Plan to remove the whole spindle. It will make everything so much easier. This starts by removing the caliper and securing it so you don’t kink the brake line.
    Then break the upper ball joint free.
    The best way I’ve found to get the UBJ out from the UCA is using one of the 3 arm pullers that was shown in post #7. Get it snug and with two more turns of the ratchet it will pop right out. Leave the castle nut on to catch it once it breaks free.
    After that, take the (4) 17 mm bolts free from the lower ball joint and the whole spindle is out. Put it in a bench vise and then use a rented ball joint press to unseat and re-seat the UBJ.
    bmf4069 and potoghi[OP] like this.
  29. May 28, 2021 at 8:45 PM
    #119
    potoghi
    Hawaii
    United States
    Everything I’ve done here is a good way to potentially screw something else up big time. But that hasn’t happened yet. I hope :help:
  30. May 28, 2021 at 8:54 PM
    #120
    MrDirtjumper
    Josh
    Slam Angelo, Texas
    Hey man, we all start somewhere. There are dudes on here that make me feel like I’m a beginner.
    My best advice is watch a few videos of Timmy The Toyota Man on youtoob. He does a lot of 3rd gen 4Runner stuff which is nearly identical to our trucks. Toyota reuses a lot of the same engineering and geometry, they just scale it from gen to gen.
