3rd Gen Rear Turn Signal Bulbs ???
Discussion in '2.5 Gen Tundras (2014-2021)' started by troc_monster, May 17, 2021.
  1. May 17, 2021 at 8:20 AM
    troc_monster
    troc_monster [OP] New Member
    troc
    203
    2019 TRD Sport, SR5, Crewmax
    Morning all.
    Recently bought a 2019 Tundra and one of the first things I am in the process of doing is upgrading all the bulbs to LED. I am wondering if anyone has found a 921 LED bulb that works without wiring in a resistor (to avoid hyper flash)?? The JDM Astar's work for the front, didn't know if there was such an option for the rear. OR a 921 with the resistor already tied in? I'd like to keep the stock housing (for now) and have searched, but haven't found anything yet.
    PS - why did Toyota use such a tiny bulb for the turn signal?? :(
  2. May 17, 2021 at 8:21 AM
  3. May 17, 2021 at 8:25 AM
    Chris001
    Chris001 New Member
    Ontario, Canada
    2018 Tundra Double Cab SR5
    LED interior, tint, auto lock tailgate, Rhino Liner, Blacked out emblems
    Vleds has had one in development for over a year now. Still waiting for it to be released. LOL Don't think Covid helped much!
  4. May 17, 2021 at 9:43 AM
    troc_monster
    troc
    203
    That's what I was afraid of. Guess I wait for now...
  5. May 17, 2021 at 9:47 AM
    That's a different project that they are working on for the turn as tail system.
    Taco-Spike likes this.
  6. May 17, 2021 at 9:48 AM
    I have the Vleds 921 brake light led. Let me pull my order history and I'll let you know what you need...I can't remember if I needed the resistor box.
  7. May 17, 2021 at 9:49 AM
    TRDFerguson
    Jake
    Southeast Greater Basin, AZ
    2018 MGM CrüeMax
    You might eventually see some hyper flash with the JDM Astars in the front. Mine worked fine for a month or so, then one side started to hyper flash erratically, then the other side started it as well. I added resistors and haven’t had issues since. Resistors aren’t that big of a deal to install.
    1lowlife likes this.
  8. May 17, 2021 at 9:53 AM
    Chris001
    Chris001 New Member
    Ontario, Canada
    They were to release a v6 triton 921 in red where you could add the resister without splicing the harness, but they were changing the lens design. Last I checked they said April/May 2021 for these. ( however they keep pushing it back).
  9. May 17, 2021 at 9:57 AM
    I spoke to them 2 weeks ago. The 921 V6 Triton lens is done and it will be part of the tail as turn system and pre-orders will become available in a few weeks. The tail as turn is similar to the Meso system on the Tacoma side of the house.
  10. May 17, 2021 at 10:14 AM
    So you will need the 921 leds and the VLR-6 for the hyperflash. That will run you around $115 or so shipped. Now they are working on a tail as turn system that will release for pre-orders in a few weeks. I will confirm this when I call him. That system would use the V6 Triton system for both turn signal and brake lights so it will have a pretty hefty price tag since the Tritons start out at ~$125 per set.
    https://www.vleds.com/shop-application/turn-signals-rear/turn-signals-rear-921/921-6-r-2.html
    https://www.vleds.com/vlr-6-duotap-wp-2.html
  11. May 17, 2021 at 10:16 AM
    troc_monster
    troc
    203
    really? ok, I will watch out for that.
    And I realize it isn't a huge deal to at the resistors. I was really trying to avoid splicing, but if I have to, I have to.
  12. May 17, 2021 at 10:19 AM
    troc_monster
    troc
    203
    :thumbsup: thanks for the info.
  13. May 17, 2021 at 10:21 AM
    I'll post with an update as soon as I talk to them. I want to get more details on the new system. I already have Tritons in the brake lights.
  14. May 17, 2021 at 11:05 AM
    Chris001
    Chris001 New Member
    Ontario, Canada
    Hear ya. I have the tritons for brake and reverse. The CS I have spoken with said the 921 tritons in red would be available separately, ( unless that was changed?)
  15. May 17, 2021 at 11:20 AM
    I'll find out and report back....
  16. May 17, 2021 at 11:21 AM
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    PosiTaps make it way easier. If you loosen or remove the battery, you have plenty of room to work with on the driver's side, and the same with the windshield washer fluid reservoir on the passenger side. Just mount the resistors on the engine bay wall so they don't melt anything.
  17. May 17, 2021 at 11:23 AM
    1lowlife
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    TRDFerguson likes this.
  18. May 17, 2021 at 11:26 AM
    TRDFerguson
    Jake
    2018 MGM CrüeMax
  19. May 17, 2021 at 12:11 PM
    troc_monster
    troc
    203
    1lowlife[QUOTED] likes this.
  20. May 17, 2021 at 11:56 PM
    1lowlife
    DADA
    2014 MGM DC SR5
    Mounted them behind the tail lights, one on each side, covers front and rear turn signals.
    I need to take a pic someday, I have pics of everything else.
    The VLED duo taps are nice, but the OEM wiring is so small it takes a little work to get a good connection.
    They cost a bit more than cheap resistors, but this wasn't something I was willing to go cheap on..
    From the VLED web description.
    Application
    If your vehicle uses the front turn signal as a DRL the best way to add load is on the rear turn signals so they are not continuously active in DRL mode.
    The VLR-3 is also used where adding load to both the front and rear circuit is more difficult.
    This enables you to install one resistor per side (front or rear) instead of four VLR-6's.
  21. May 18, 2021 at 6:22 PM
    troc_monster
    troc
    203
    :thumbsup: again, thanks for the info. definitely considering this now after reading up on it.
  22. May 19, 2021 at 4:35 PM
    Oats87
    Oats87 Dirt Rider
    Sunnyvale, CA
    A Non-Toyota
    WILLINH likes this.
  23. Jun 14, 2021 at 1:03 PM
    Chris001
    Chris001 New Member
    Ontario, Canada
    Well the new v6-921 are up for pre order, but it looks like they’re not offering the preorder discount they have in the past. $140 per pair atm.
  24. Jun 14, 2021 at 1:40 PM
    Yeah I see that. I went to the site as I haven't gotten the email yet. I'll hit them up tomm....its the harness that we will need now.
