  1. May 17, 2021 at 8:48 AM
    rock climber
    rock climber New Member
    2001 Sequoia 4X4, 2000 AC 4X4
    The passenger side specs are odd. Not sure why they are so different. I'd get it readjusted.
    NUDRAT likes this.
  2. May 17, 2021 at 8:50 AM
    djb
    djb New Member
    DJB
    Arizona
    2015 White Tundra Platinum Crew Cab 4WD
    Front Grille Flat Black Bumper Guard, Flat Black Fender Flares, 3.5 Lift Kit, Larger All Terrain Tires
    Drove my 2003 Tundra 262 miles yesterday exploring Arizona! Hit 261k miles on it, still runs like a gem! Bought it new, original owner. Wouldn’t trade it for anything!
  3. May 17, 2021 at 8:51 AM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    I haven't seen anybody use those but I have looked them over before. For my truck they wouldn't work.
    Those would only work with SPC arms or long travel kits with hiem joints on the pivots. Maybe JBA arms, I'm not sure if those have adjustable ball joints.
    KarmaKannon likes this.
  4. May 17, 2021 at 8:52 AM
    rock climber
    I'd take it back and have them fix it. Tell them the specs you want. 2.5 Caster, .04 of toe (each side) camber .25
  5. May 17, 2021 at 8:55 AM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    I've already walked away, and said thanks. It's on me now.
    I'm not going to go back and act like a Karen "I changed my mind after the fact. I want it redone."
    I'll see what the other shop has to say sometime soon. For now, it's bed time. Up in 4 hours.
    NUDRAT and bmf4069 like this.
  6. May 17, 2021 at 9:14 AM
    Sirfive
    Sirfive Working on pavement
    ‘02 Limited AC TRD
    Bassani cat-back
    ‘Dash beeper’ didnt get any search results. Anyone know the best way to unplug it on an ‘02?
  7. May 17, 2021 at 9:28 AM
    des2mtn
    SW
    2004 Black DC Limited 4x4
    Tonto cover
    The beeper that activates when your door is open and key is in ignition?
  8. May 17, 2021 at 9:30 AM
    Sirfive
    ‘02 Limited AC TRD
    Bassani cat-back
  9. May 17, 2021 at 9:31 AM
    des2mtn
    SW
    Tonto cover
    I don't have pictures but there should be a plug you can simply disconnect on the ignition assembly. You'll have to remove the lower dash assembly around it/ under steering wheel to access it.
    Sirfive likes this.
  10. May 17, 2021 at 9:44 AM
    Sirfive
    ‘02 Limited AC TRD
    Bassani cat-back
    I dont like wiggling on this dash. Doing it, but i dont like it. It kinds sounds like the beeper might be in the steering column?
    i got the bottom column plastic cover off, and decided going any deeper was a hard no. Unplugged the door button switch. Doesnt bug me at all that the lights dont come on when i open the door.
    tied a fish wire to the plug so it can be easily retrieved.
    187544923_10159116033755275_255243308080_1afd46ed382c6224a7a2084aeeda6af22504e8e9.jpg
    whats this yellow clip attached to?
    Gonna clean it up since ive got it open.
    https://youtu.be/CwGrC0KicSo
  11. May 17, 2021 at 10:00 AM
    I don't see anything wrong with taking it back to the shop and asking them to get it right. Just say you studied the numbers a bit more, and what they mean, and would like it in spec. You paid them a lot of money and they didn't do it right.
    If you ask nice, that doesn't make you a Darren(male Karen). I took my truck back to Meineke 3 times because they couldn't get the alignment right. They were cool about it. I found out later they were doing it by hand, no machine. I'll never go there for an alignment again.
    KarmaKannon, BubbaW, bmf4069 and 4 others like this.
  12. May 17, 2021 at 10:05 AM
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    Yup take it back. Say you aren't happy with how it drove. Any good shop should redo it for no charge.
    BubbaW likes this.
  13. May 17, 2021 at 10:07 AM
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    I agree with Erik there.
    BubbaW likes this.
  14. May 17, 2021 at 10:13 AM
    des2mtn
    SW
    Tonto cover
    Solution achieved! If my front dome lights came on with the doors I probably would've done that too. The bottom part of my dash is actually off right now so I'll take a picture of the connection later for anyone that wants to do this.
    Sirfive[QUOTED] likes this.
  15. May 17, 2021 at 10:17 AM
    Thrussn
    Thrussn Plastidip Hoe
    Gabe
    NM
    Silver 2005 4.7L 4WD Access Cab
    Bilstein 5100s, SickHIDs projector housings, Plastidip everything, TRD Pro style rims, LEDs everywhere, SUPERBUMP bumpstops. Firestone Riderite air bag springs, Deaver G57s, Onboard VIAIR system, Backup Camera, light bar behind the bumper, CGS catback, Exhaust cutout after cats, JBA Shorty headers, JBA Y-Pipe, pioneer deck, pioneer speakers, kicker 10" sub w/ amp, door sound deadening, Dirtydeeds 12 pin injectors, UniChip, Skid Row Skidplate, EZ Oil Drain valve (Better than Fumoto), Oil Catch Can, & 4WD Conversion
    I paid a local shop for an alignment after replacing my LCA bushings. They quoted me $90 and then charged me $140. It was clearly out of spec when I drove it and ended up going to my local yota stealership. They charged my $60 and gave me a before and after showing me how out of spec the other shop left mine.
  16. May 17, 2021 at 10:58 AM
    Everytime you say that I think of this:
  17. May 17, 2021 at 11:12 AM
    Sirfive
    ‘02 Limited AC TRD
    Bassani cat-back
    Literally the only justification i have of wanting a coastal rear bumper/spare tire mount. But the more i look at tires, the more excuse i have for steelie 17’s
  18. May 17, 2021 at 3:42 PM
    assassin10000
    assassin10000 New Member
    Andrew
    Northern CA
    '05 SR5 AC
    @Tundra2
    They should have evened up the caster. You've already replaced the cams and anti-siezed them iirc. No reason not too.
    I run 2.6-2.8 caster, which is higher than stock. This gives a little more steering feel and feedback. Makes the truck steering a little more car like. .2-.3 caster or camber difference side to side isn't a problem but anything more than .5 is too much, as it'll usually cause a mild pull.
    Stock specs make the steering too 'light' and vague IMO.
    Sirfive, KarmaKannon and BubbaW like this.
  19. May 17, 2021 at 3:47 PM
    assassin10000
    Andrew
    Northern CA
    '05 SR5 AC
  20. May 17, 2021 at 3:48 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Thanks for the feedback. I just want it to be right, and I think you're right on the mild pull. I feelt it.
    All of the front end components except the knuckle/spindle, and inner tie rods have about 9,000 miles on them. I installed SPC upper control arms in December.
    Went to the schmancy alignment place, and had them do the whole smeal back then. Raben said they wouldn't touch the upper control arm to adjust the camber. o_O
  21. May 17, 2021 at 3:53 PM
    KarmaKannon
    KarmaKannon Master of None
    Utah
    2006 Double Cab w/long travel
    Some junk
    I ran my own version of those. I adjust caster and camber with my upper arms now. Kinda hard to see but I welded the slot closed with some moon kinda shaped filler pieces and did some weld washers over that. Same concept more or less.
    potoghi, oscardog86, NUDRAT and 4 others like this.
  22. May 17, 2021 at 4:05 PM
    assassin10000
    Andrew
    Northern CA
    '05 SR5 AC
    No problem.
    Were they scared? They shouldn't need to unless there are other things out of whack but saying up front they won't touch them...
    If I had uppers I'd use them to bring a little more caster and keep my wheels a little more centered in the wheel wells. If lifted it'll help even more.
    One of the more unique chassis I've worked on. C5 vette with coilovers and a jeep body. Track use only race car.
    Wide body viper:
    Oldschools:
    Lil Steve, oscardog86, chrisb and 6 others like this.
  23. May 17, 2021 at 4:22 PM
    Glock 40
    Glock 40 I'm here to break shit
    Yukon Cornelius
    Way up thar
    2000 AC Limited 4X4 4.7L
    Deadpool Edition
    Sick rides!
  24. May 17, 2021 at 4:26 PM
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
    63 Impala SS :confused:
    assassin10000[QUOTED] likes this.
  25. May 17, 2021 at 4:39 PM
    Thrussn
    Gabe
    NM
    I noticed the steel brake line that runs into my caliper had a leaking fitting. I tightened it and it started leaking worse. I ended up buying a new line from the dealership and it's installed now. Feels good to not have leaking brakes.
    While under my truck, I looked at my weeping front differential and noticed the leak isn't coming from the housing itself, but from the breather. Glad to know It's not the differential housing that's leaking. Anyone have tips on how to get to that breather without dropping the entire diff? Or am I SOL?
  26. May 17, 2021 at 4:50 PM
    MS22
    MS22 New Member
    02 Tundra 4x4
    Holy sheet I forgot there was one there! Better go check on mine.
  27. May 17, 2021 at 4:55 PM
    assassin10000
    Andrew
    Northern CA
    '05 SR5 AC
    Good eye.
    BubbaW[QUOTED] likes this.
  28. May 17, 2021 at 7:25 PM
    Around here, 95% of the operators are clueless about the CAMM alignment software that make it easy to get you to the caster and camber of your choice. Majority of them just know the old school way of just “good enough” and couldn’t care less about learning anything new. That’s been my experience.
    chrisb and Darkness[QUOTED] like this.
  29. May 18, 2021 at 3:18 AM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Unless this is a dash squeak (because I'm already going to look there) I'll paypal anyone $20 who can help me identify this, and help me fix it.
    Squeak means stuff loose, and I don't like it.
    First video is with my hand resting on my cup. Second video is me holding my phone/arm off the arm rest (to attempt to eliminate extra cab noise/vibes coming through my hand to microphone.)
    https://youtu.be/7b5HxjWRHTk
    https://youtu.be/FNP4QfGCojs
    I hear it when I drive over small bumps. I hear it when I start the truck, or shut the doors. I hear it inside, and outside the truck. I'm pretty much at a loss using mental experiments to find it.
    NUDRAT likes this.
  30. May 18, 2021 at 3:25 AM
    Sirfive
    ‘02 Limited AC TRD
    Bassani cat-back
    Its oldtruckitis. Turn some music up and it’ll go away. Lol. But my sequoia has cardstock stuffed into every crevice in the dash. Now all my squeaks and rattles are coming from everywhere else.
    Does it squeak if you bounce the suspension while stationary?
