5.29 gears with 35s?
Discussion in 'Performance and Tuning' started by mcchase, Aug 16, 2019.
  1. May 14, 2021 at 7:49 PM
    #91
    rothmigo
    rothmigo New Member
    DFW TX
    2020 Tundra Crewmax Platinum
    7" BDS/Fox, 5.29, 37x13.50 Nitto, 22x12 Hostile Rage,BAM
    Having the same "truck is a beast with the 5.29's" experience! After hearing I have 37's, the Dirty Deeds dude made me promise I would regear before he accepted my order for the BAM muffler lol he was right. It just wants to go...take the foot of the brake and it's moving. I pity the parking brake when someday I forget to disengage it. Added the Auburn LSD. On the highway before regear it hunted way more, was less likely to find 5th and 6th direct drive and cruise control was pretty annoying but so much smoother now. Tows nice. I do still have my Pedal Commander engaged but only lightly to take the edge off. Transmission shifts sooner, engine revs faster so truck sounds meaner / less tired when taking off. Biggest challenge if finding an installer for the gears...not just anyone is willing and able to do this. For my situation I'm also a big fan of the tranny cooler - plenty of other threads beating that horse one way or the other lol.
  2. May 14, 2021 at 8:07 PM
    #92
    5150bronco
    5150bronco New Member
    Justin
    Bay Area, Ca.
    Yes I think I need to too.
    it seems like an easy decision because the choices are 488 or 529 but there’s so many factors to consider. I seem to always be focused on what RPMs will I be at at 65 miles an hour.
  3. May 15, 2021 at 12:38 PM
    #93
    SoCalTundy
    SoCalTundy Tundra Owner since 2017
    Icon Shocks. Total Chaos UCA. Deaver u748 TC shackles. Dirty Deeds standard 10 exhaust. Diode Dynamics fogs. 5.29 Revolution Gears. SSW 17" wheels on BFG 35x12.5.
    Another observation; I heard nitros had a whine to them and that revolution gears were quieter. Because of this I went with revolution. Day 2 of driving and I hear a whine slowing down beginning at 30 mph down to 20 mph. My son was with me and I asked him if he heard that. He says “the siren?” I laughed because that’s what it sounds like. It’s not loud but it sounds like a fading siren that’s far away. Anyone else experiencing this?
  4. May 15, 2021 at 1:45 PM
    #94
    rothmigo
    rothmigo New Member
    DFW TX
    Yes some whine from the Nitro's. I really only notice it if I have rear glass down. At first I was concerned but when I starting hearing a whine from my stock silverado too I realized I was listening way too hard lol! But definitely more whine from the Nitro's than the stock gears at speeds you mentioned. If I begin towing more I will go from 80w90 to 85w140 and imagine it will be quieter. I'm sticking with dino b/c of the Auburn. I've seen on the forums here any whine at all means something ain't right...but also where aftermarket gear mfgr's quoted saying it isn't the case so don't pull your hair out.
    For sanity around break in procedure, I used a temp gun to check rear temps doing the break in drives and then later first time short towing pulls. The installer was very happy with break in oil and used a borescope to confirm to confirm he was satisfied with it...on Jeeps I think he removes the diff cover and repaints/checks the mesh. But on Tundras to do so removing the 3rd member again is a PITA. As a side note he prefers Revolution too in general but the Nitro's is what I had requested and what we could get seamlessly enough last year. He just said he likes the way Revolution gears go together in general. What a gem finding this installer here in central IL...few offroad shops. Yota dealers here were kind enough to tell me that they didn't have the skill set for it before I found the installer here.
    SoCalTundy[QUOTED] and Vizsla like this.
  5. May 15, 2021 at 4:20 PM
    #95
    Downytide
    Downytide New Member
    GTA
    Lunar Rock that whines
    Its normal, as ratio goes up numerically, the less teeth are on the ring and pinion and the noise level tend to increase.
    Mine sounds has a very little whine that's like a race transmission when slowing down, it's audible when I roll down the rear windows and no music , but once window up it's hard to be heard, REM polishing also help a lot with the noise reduction.
    I have the nitro gear set.
  6. May 15, 2021 at 5:13 PM
    #96
    rockmup
    rockmup New Member
    Todd
    Greenwell Springs LA.
    Kings, 5:29's, E-lockers on 37's
    What are you using to tune ?
  7. May 15, 2021 at 5:21 PM
    #97
    Vizsla
    Vizsla 2 = 2.5
    With the rear window down, no music and windows up sometimes think I hear a whine slowing down same speed, but my hearing isn’t very good and I’m trying to hear it obviously. Had a bad install originally, as I understand whine slowing down is ok, whine slowing down and accelerating means a problem with install like mine. Not sure what whine when accelerating only indicates.
    HPTuners
    SoCalTundy likes this.
  8. May 15, 2021 at 6:12 PM
    #98
    rockmup
    rockmup New Member
    Todd
    FWIW, I have zero whine from my Nitros
    Thanks.
    So what improvements did you actually get from the tuner ?
  9. May 15, 2021 at 8:11 PM
    #99
    TravisJr
    TravisJr New Member
    2001 AC SR5 4WD, 2010 DC SR5 4WD
    Lots o’ mods
    I’m on 35s and have Nitro 5.29s. Wouldn’t change a thing. Yes, if I’m driving with windows down and stereo off, there’s a whine when coasting.
    Guess how often I drive in those conditions? Next to zero. Mechanical whine does exist, but I’m of the opinion that it’s been made out to be far more of an issue than really is. Under real life conditions (ie bombing down the road with the AC full blast and the Dokken banging) it’s not noticeable. YMMV.
    Flyinryank, rothmigo and SoCalTundy like this.
  10. May 15, 2021 at 8:23 PM
    #100
    SoCalTundy
    I hear mine with the windows up and everything else inside off. If I turn on the radio I’m sure I won’t hear it. It’s not loud but it’s there.
  11. May 15, 2021 at 9:05 PM
    #101
    Vizsla
    Vizsla 2 = 2.5
    I would like to tell you everything that is better, but don’t know enough to explain correctly. Adjusting the calibration made a noticeable improvement, truck is happy lol. Removing the speed limiter really helps, but might not matter depending on where you live. 90 mph is cruising speed where I live on highway, not safe if that’s top speed for my truck. I will be out with my buddies soon, we have most combos covered, will try to get some drag race info. Last time my truck had stock gears, @831Tun was fastest with 5.29, not sure if he had bulldog tuner on but don’t think so. Other trucks had 4.88s, some with headers and tune.
    https://www.youtube.com/watch?v=czzcBacwl6I
    porkitt, dorton, SoCalTundy and 5 others like this.
  12. May 15, 2021 at 9:12 PM
    #102
    snivilous
    snivilous snivspeedshop.com
    SW UT
    300k+ Supercharged 2008
    I had that whine (revolution 5.29 with rem) on the deceleration, like you said a specific speed range. I can't say I've heard it in a long time, seems like once the gears wore in a bit (presumably) the whine went away. I'm at 4000 miles or so on the gears, I can't say they're any different sounding than stock now.
  13. May 16, 2021 at 6:17 AM
    #103
    Terndrerrr
    Terndrerrr 923000 miles to go
    Music City
    6UR-FE
    Curious if anyone has gone up to 5.29s with 285/75R18s aka skinny 35s. Mine are 35.1" and 65lbs. Lighter than a true 35x12.5
    My truck will hold lockup through most of the hills around here, but there are a few steeper grades where it does not. These are the places around Nashville where there's an extra lane for the big rigs to mosey on up.
    I don't know if it's necessary, but it might be fun.
  14. May 16, 2021 at 6:38 AM
    #104
    15whtrd
    15whtrd Mr. Blonde
    Circumference is the main issue, you would definitely benefit from some gears! But you don’t have to either if it works for you. I want to update my gears and I am only running 33‘s
  15. May 16, 2021 at 7:44 AM
    #105
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    Love that video, the dust is amazing. The truck has changed so many times, it's hard to remember but I think you're right and the BD had been removed. Thinking about getting the HP tune but need to pay my daughter's tuition first.
    Vizsla[QUOTED] likes this.
  16. May 16, 2021 at 9:08 AM
    #106
    Hightide
    chadington von banks
    Abalama
    Magic School Bus
    I’ve used this video multiple times for reference and examples.
    It needs a sound track so badly!
  17. May 16, 2021 at 7:17 PM
    #107
    SoCalTundy
    You might be right. Been driving the truck every chance I get and it seems the sound is fading away. Keeping my fingers crossed.
  18. May 16, 2021 at 7:51 PM
    #108
    Vizsla
    Vizsla 2 = 2.5
  19. May 16, 2021 at 7:58 PM
    #109
    Hightide
    Abalama
    Magic School Bus
  20. May 16, 2021 at 8:32 PM
    #110
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
  21. Jan 6, 2022 at 6:16 AM
    #111
    wexttxco
    wexttxco New Member
    21 SR5 DC 4x4
    Fox 2.5 RR, 35x12.5r18 x3 on method 701, armor, front bumper
    Same curiosity here. Though I haven't heard of anybody breaking them, so I don't think it's a concern.
  22. Jan 26, 2022 at 10:32 PM
    #112
    conviccted
    conviccted New Member
    Victor
    2019 Voodoo TRD Pro
    Ceramic Tint,Spray on bed liner
    What if you drive 85mph on long hwy drives with 35 and 5.29 will you mpg suffer?Or will your RPM be to high?
  23. Jan 26, 2022 at 10:47 PM
    #113
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    At .59:1 trans gear ratio (6th), you'd be around 2550 RPM
    conviccted[QUOTED] likes this.
  24. Jan 26, 2022 at 11:21 PM
    #114
    conviccted
    Victor
    2019 Voodoo TRD Pro
    Thank you that's not bad.
  25. May 5, 2023 at 10:10 AM
    #115
    relentlessfax
    relentlessfax New Member
    Matthew
    2020 Tundra TRD Pro
    None
    I am just going to lay down the big Sausage.. I have a 2020 Army Green TRD Pro Tundra. I just had a 7" BDS coil over lift installed with ALL the bells and whistles including the recoil traction bar. I am having it increased to a 9" lift with adding Front Leveling kit - 1 inchPart ICON 2007+ Toyota Tundra Rear Leaf Spring Expansion Pack Kit - 1.5 inch lift and adjusting the shocks to make it a full 2 extra inches. I have 37" x 12.5" Nitto Ridge M/T tires with 18" wheels (real men have more tire than wheel. I would have gone 17" if they weren't so back ordered) I just had the 5.29 Nitro gear ratio installed and am installed a Harrop supercharger on the 15th. I cannot wait to see how it drives after the supercharger. I basically took everything that made it a Pro off and made it much better (truly Toyota could be offering a better suspension/tire combo for the TRD Pro price). I will post updates but I truly feel like a boss on the road now and I turn heads all day.
    WinterWarlock21 and texasrho83 like this.
  26. May 5, 2023 at 10:47 AM
    #116
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Hell yeah dude. Did a rich uncle kick the bucket?
  27. May 5, 2023 at 11:29 AM
    #117
    relentlessfax
    Matthew
    2020 Tundra TRD Pro
    None
    There was a situation where some oil royalties have come into play... lol. I am going through my mid life crisis at 35 to be honest..
  28. May 5, 2023 at 8:05 PM
    #118
    centex
    centex New Member
    Been there done that. Wasted it too early in life and now I have to justify my classic hot rod.
    texasrho83 likes this.
  29. May 5, 2023 at 8:39 PM
    #119
    relentlessfax
    Matthew
    2020 Tundra TRD Pro
    None
    I fully hear you brother. I have been pretty smart with my money overall and the first thing I did was pay off my house so I could have no mortgage and save. I do want to make it clear I do work hard lol. Not just some trust fund baby but my grandparents did leave me a small amount. I just want to enjoy life right now though while I can. I have a few health issues I don't want to talk about on here haha but yea I just want to be stupid and spend money on something I love haha.
    NoMoreGreen likes this.
