VF Tuner 3UR Support - Development Tools
Discussion in 'Performance and Tuning' started by OVTune, Apr 25, 2019.
Thread Status:
Not open for further replies.
  1. May 12, 2021 at 3:24 PM
    #5731
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    I open two calibrations in one instance and can compare each map directly next to each other in the same right-hand window of the app.
  2. May 12, 2021 at 3:25 PM
    #5732
    art64
    art64 New Member
    I've opened up 2 files simultaneously on vF tuner--base tune and the 91-GL, just to see the differences on the tables. You can arrange the tables side by side or top to bottom to compare values on rows and columns.
    If you can hook up a bigger and wider screen on the laptop, the better.
    TX210Tundra and Wynnded like this.
  3. May 12, 2021 at 3:27 PM
    #5733
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Yep, same here.
  4. May 13, 2021 at 9:27 AM
    #5734
    OVTune
    OVTune [OP] New Member
    Mat
    2016 FFV CM
    OVTune RD Vehicle
    Update is this week ~ expected saturday
    The biggest update we have *literally ever* done.
    New ECUs added
    18+ Map switching patch files
    Updated / corrected tables
    Flash fix (older ECU)
    tons of stuff!
    everyone will have to update vf tuner
    (master packs will be emailed)
    snivilous, Wynnded, art64 and 3 others like this.
  5. May 13, 2021 at 10:29 AM
    #5735
    NWATundra
    NWATundra New Member
    2013 White Tundra DC
    Are you still sending tune packs out?
    Vr0ck likes this.
  6. May 14, 2021 at 7:30 AM
    #5736
    OVTune
    Mat
    2016 FFV CM
    OVTune RD Vehicle
    Flash issue is fully resolved and will be ready in this upcoming update.
    Made sure to test it myself with an 07 ECU, as old as it gets
    pnw.tundra, art64 and Wynnded like this.
  7. May 14, 2021 at 10:05 AM
    #5737
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    I'll give you the thumbs up if it works with YWF63...unless that's still another matter as it has been. Thanks!
    pnw.tundra likes this.
  8. May 14, 2021 at 1:45 PM
    #5738
    pnw.tundra
    pnw.tundra PNW Tundra
    Paul
    PDX
    2022 TRD Pro | Prev 2020 Tundra aka Blue Whale
    Can’t wait Mat
  9. May 14, 2021 at 2:52 PM
    #5739
    OVTune
    Mat
    2016 FFV CM
    OVTune RD Vehicle
    VF Tuner 1.2.9.9.9 Release notes - Required Update
    - VFT EROM Patch for 2018+ Tundra 3UR With 4 Way map switching available
    - Table Fix - Tundra 3UR - Multiple tables fixed - Added
    - Table Fix - Downshift torque reductions
    - Table Fix - Ignition Coefficient
    - Table Fix - Various EROM / VFT table (naming)
    - Table Fix - Various (naming- info - Axis)
    - Save Fix - Auto Save VFC When "save" selected
    - Flash Error Fix - Early Model 992 ECUs
    - VF Tuner Pro Tuner "Lite" Version Remote software Release
    - VF Tuner License Registration 1.3 Update
    Update will be available for download in 20 mins.
    Pro Tuner link update available (by your emailed link)
    FitsofRage88, Vr0ck, Wynnded and 2 others like this.
  10. May 14, 2021 at 3:03 PM
    #5740
    pnw.tundra
    Paul
    PDX
    Ooh can’t wait to test out the new software
  11. May 14, 2021 at 3:17 PM
    #5741
    OVTune
    Mat
    2016 FFV CM
    OVTune RD Vehicle
    VF Tuner Exclusive 4 - Way Live Map switching files can be located in the installation folder
    The files are named VF001-(yourECUID) (VF EROM patch 001)
    To make it easier for folks, you can see that the map switch tables have been preset with base tuned tables for you
  12. May 14, 2021 at 6:07 PM
    #5742
    OVTune
    Mat
    2016 FFV CM
    OVTune RD Vehicle
    Also folks (like I posted in the tacoma thread)
    If you're a Pro Tuner on this platform, and want to test some of this stuff out off roading, trailing, etc, showing off the features, how it works etc (for your own business) we will provide free credits for these videos. We also want to advertise those for you
    pnw.tundra, FitsofRage88 and Wynnded like this.
  13. May 14, 2021 at 7:14 PM
    #5743
    art64
    art64 New Member
    No more errors on flashing!!! Thank You.
  14. May 14, 2021 at 8:27 PM
    #5744
    TruckyTruck
    TruckyTruck Dumbest Username
    Gary
    @OVTune so I’ve been out of the loop for a while now. Last I thought I needed to wait for an update from Toyota with my ecu and I thought you had mentioned we wouldn’t need to do anything with that. Is that right?
    Do we have functioning s mode and gear lock for 2nd gen trucks with these tunes?
    thanks!
  15. May 15, 2021 at 5:01 AM
    #5745
    Vr0ck
    Vr0ck New Member
    Virginia Beach, VA
    2016 5.7 MGM DC 4x4
    Toytec Boss C/O, Toytec Shackles, 5160s, nfab step bars, 8" BAMuffler, OVTune, AuxBeam LEDs, Vahalla protection plates
    Bummer *still* no map updates on my 2016 ecu 0CM21
  16. May 15, 2021 at 9:05 AM
    #5746
    Rockgate
    Rockgate New Member
    Terry
    Middle TN
    2022 CMLB TRD OR Prem. 4X4 and 2002 RCLBV65Spd
    Anxious to get this or some other tuner. I want to put my headers on 1st though. So the 18+ will have 4 selectable tunes? I'm really wanting gear lock and direct shift. Will those be better for towing?
  17. May 15, 2021 at 7:12 PM
    #5747
    FitsofRage88
    FitsofRage88 real eyes realize real lies.
    Hill Country, Texas
    2019 FFV CM (3URFBE) 2Gen
    Blackhawk(0CU00) Working on it!
    Mat
    Looking more into this now VFT EROM Patch for 2018+ Tundra 3UR With 4 Way map switching is available and reading the tech details per the last page in the FAQ
    do i need to open the modified / patched file and copy your tune onto it.
    or
    flash the file onto the ECU once. And then the features like map
    switching, gearlock, directshift are then available.
    how many credits are needed?
  18. May 17, 2021 at 11:34 AM
    #5748
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    @OVTune :thumbsup: Flashed from .P5F to .VFC. Nooo problem. It was a little disconcerting when the ECU Flasher window disappeared though. Clicking the Minimize button on VF Tuner brought it back though. I don't know if that's normal (read only one comment about it) or if I accidentally touched the laptop touchpad.
  19. May 17, 2021 at 11:35 AM
    #5749
    OVTune
    Mat
    2016 FFV CM
    OVTune RD Vehicle
    awesome!
    yep I am aware it happens on some PCs. If you just click anywhere it comes right back.
    That means I was wrong I thought your issue was different. Glad it's working!
    Wynnded[QUOTED] likes this.
  20. May 17, 2021 at 11:36 AM
    #5750
    pnw.tundra
    Paul
    PDX
    Once I get some tune packs, I’ll get some videos for you. On that note, any update on when I expect to get some TP’s?
  21. May 17, 2021 at 11:39 AM
    #5751
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    I feel so normal.... :pout:;)
  22. May 17, 2021 at 11:53 AM
    #5752
    TX210Tundra
    TX210Tundra New Member
    2008 RCSB 5.7 2WD "Sport" / 2022 Limited Hybrid
    2008 - SOS 2/4 Lowering Kit : Firestone Bags : Bilstein Sports at 4 corners : TRD Pro Grill : TRD Pro 18in BBS Forged : Grip Pro LSD : Mike's "ByeNanny" : ARH LT 1 3/4 : ARH Cats : 3" X-Pipe: 3" Dual Borla XR1's / 3" Vibrant Resonators: 3" Tail pipes: DIY SABM: TRD Intake : AFE T/B Spacer : TRD Accelerator : LED Interior/Exterior : Atoto Pro HU : Cerwin Vega 10in Slim : AVS Visors : Sequoia Leather Seats : TRD shift Knob - OVTuned "Spicy 91 Torque Tune" 2022 Limited Crewmax Sonic Red Hybrid - TRD Filters : EGR Window Visors : Cheer Dring Android Adapter : RC Bed Cover : RC 1.75 Level Kit : Undercover Swing Case
    TP locked and loaded here, now time for the real fun :yes:
    Wynnded likes this.
  23. May 17, 2021 at 5:21 PM
    #5753
    4firemandan
    4firemandan Superduper Member
    SWFL
    2016 Crewmax 4x4, 5.7
    TRD Supercharger, Ported SC inlet, RCF TB, 4.5” intake, WMI, 2.38 pulley, custom tune, DW660 inj, aeromotive fpr, msd boost-a-pump
    Any Supercharged 5.7s have a VFtuner SC file emailed to them yet?
  24. May 17, 2021 at 5:40 PM
    #5754
    FitsofRage88
    Hill Country, Texas
    Does anyone know per vFtuner
    Is it easy to flash the stock file back to the original from the tune pack Im currently on now?
    Im curious If more credits are needed which I do not have?
    I haven't been able to reach Mat considering he has been dropping all these goodies lately..
  25. May 17, 2021 at 5:42 PM
    #5755
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Well....technically, I have. But I've been running an Orange Virus tune for about 18 months. I've requested and received my tune file which was converted from .P5F to .VFC a couple months ago, but it was essentially a completed tune with the exceptions of Gear Lock and Direct Shift. They're not sorted the way Mat wants them as yet, at least for the older ECUs like mine.
    I'm trying to remember, your ECU calibration isn't in the S/C file of the software?
  26. May 17, 2021 at 5:48 PM
    #5756
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    I'm a little confused about what you mean by "stock" and "original" in reference to the files. They sound the same to me.
    What you could simple do is try it, if the software throws you a pop-up stating that you need to use or don't have enough credits, then you'll know.
  27. May 17, 2021 at 5:57 PM
    #5757
    OVTune
    Mat
    2016 FFV CM
    OVTune RD Vehicle
    Hi Guys,
    now that we have released map switching and all ECUs are supported in VF Tuner + no flash errors anymore, we will be sticking to just using our forum for posting update info.
    Thank you everyone. It's been a long road, incredibly fun tuning these trucks. I appreciate everything, all the assistance, testing and support provided by you guys.
    Future update information will be on our forum only.
    Some time next week we will be posting whats going onto our 2021 for development for you guys. (hint : it's a whipple). The aim is to have a 600WHP ready to go calibration example file for you guys.
    My developer is working on full 07-17 map switch / GL / DS VF Tuner support as well. Like previously mentioned those ECUs are more fragile, so it's just a bit more work.
  28. May 17, 2021 at 6:03 PM
    #5758
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Forums - vF Tuner Forums
  29. May 17, 2021 at 6:03 PM
    #5759
    snivilous
    snivilous snivspeedshop.com
    SW UT
    300k+ Supercharged 2008
    No sir
  30. May 17, 2021 at 6:38 PM
    #5760
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Maybe I can mooch one more question out of you? Can those of us with the Gen 1 ECUs anticipate an announcement on when Tune Packs might start being sent out...over on your forum?
Thread Status:
