  1. May 14, 2021 at 6:53 AM
    jhardy1979
    jhardy1979 New Member
    Justin
    MGM 2015 Tundra Crewmax Limited 4x4
    Yeah that window control module is really cool and also very easy to install.
  2. May 14, 2021 at 7:28 AM
    tundrasportinMA
    tundrasportinMA New Member
    Western Mass
    2019 Tundra Sport DC
    6112/5160 , SCS Ray 10's, Cooper Discover AT3 -295/70/18, Dirty Deeds 8inch, N-Fab Podium
    I think it looks pretty slick, anyone have any concerns about the way its wired to the battery ? Disclaimer - I know nothing about wiring so not criticizing just curious.
  3. May 14, 2021 at 7:48 AM
    3rdTundra
    3rdTundra Hay Hauler
    Central Texas
    2017 Tundra SR5 Double Cab TSS 4x4
    FRAC harness / camera & Full set of Valhalla plates
    I agree with your concern. I would think it would be better to tap into an always-on 12V supply inside the cab.
  4. May 14, 2021 at 8:00 AM
    jhardy1979
    Justin
    It would be a little easier to do that as well.
    tundrasportinMA likes this.
  5. May 14, 2021 at 8:04 AM
    Ordered the Pro Holder phone mount.
  6. May 14, 2021 at 8:15 AM
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    Expecting the parts to show up today for my differential breather relocation. And also got the parts to wire up my power fold mirrors to auto-fold when the truck is turned off.
  7. May 14, 2021 at 8:54 AM
    1794TX
    Steven
    N.TX
    '20 1794
    wait just a tick - - what is this madness about auto-folding mirrors when the truck is turned off. you some kind of Hairy Pooter wizrd or something? I'm gonna need to check part numbers on that.
    3xYOTA likes this.
  8. May 14, 2021 at 8:56 AM
    French Avocado
    Utah / Wyo
    what parts for auto-fold? Please do an install video as well.
  9. May 14, 2021 at 8:58 AM
    RainMan_PNW
    Casey
    Clark County, WA
    You’ve got memory mirrors…so don’t think it’s gonna work for you. Your power fold functions are all controlled by two ECUs - one in each door. Your switch is just sending a signal.
    My Pro didn’t come with power fold, so I added it using the switch from a Gen2 Limited (power fold without memory). In those switches, the switch is directly controlling the power to the mirror. From what I can tell, a DPDT relay wired up right should send power to fold the mirrors when the truck is turned off, then restore whatever the switch is actively set to when the truck is turned on.
    Wallygator likes this.
  10. May 14, 2021 at 9:04 AM
    1794TX
    Steven
    N.TX
    '20 1794
    I should look into the relays for the Lexus RX. My wife's has both memory and auto-fold... Not sure if that's doable, but I'll report back whatever info I find.
  11. May 14, 2021 at 9:07 AM
    GAknight
    GAknight New Member
    Shade of a Pine, GA
    '14 TSS 4x4
    Too many…scratch that…not done yet.
    Here’s a install diy, using KTJO 4x4 harness/kit.
    I know there’s a thread on here about the kit somewhere. Just search around, or google it.
  12. May 14, 2021 at 9:10 AM
    RainMan_PNW
    Casey
    Clark County, WA
    That’s likely controlled by the same ECUs.
    Depending on how your switch actually functions (momentary signal or fixed position - I don’t have a platinum or 1794 to test on), it might be possible to hijack the wiring inside each door between the ECU and the mirror to add a relay to do the same thing. But not sure if that will fully work or not.
    when I get it done, I’ll post it up in my build thread for sure
  13. May 14, 2021 at 9:11 AM
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    Changed this
    to this
    And this
    to this
    Not sure if I keep these Wet Okole covers. At least no more static electricity shocks when I'm getting out of the truck.
  14. May 14, 2021 at 9:13 AM
    RainMan_PNW
    Casey
    Clark County, WA
    From what I read on that thread, people were having issues with it correctly working. Not sure how it all worked out in the end…I’ve reached out to KTJO a few times inquiring about different products and really haven’t gotten any response. So I quit asking
  15. May 14, 2021 at 9:14 AM
    RainMan_PNW
    Casey
    Clark County, WA
    I had WO’s in my last truck for over 250k miles. They were showing their age at the end, but held up great!
    IndianaGeologist and vtl[QUOTED] like this.
  16. May 14, 2021 at 9:17 AM
    Dsptundra
    Austin TX Area
    2021 Silver Limited CM
    Got the tow mirror caps sanded and primed last night. Finish coats today and if all goes well mirrors on later this afternoon.
  17. May 14, 2021 at 9:17 AM
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    My main point was how quickly the fabric seats get dirty, thanks to sons. I was cleaning them up the other day using Tornador and I was literally coughing because of the dust clouds. Also some stains I could not remove easily, on the truck that is less than 2 years in use!
    Wallygator, mgm16trdpro and Fotnot like this.
  18. May 14, 2021 at 9:29 AM
    RainMan_PNW
    Casey
    Clark County, WA
    Very true. I chose to have the WO's get dirty over the factory fabric for sure. With dogs, trips to the creek for a swim, etc. it was nice to have the neoprene.
    Once a year I'd take them out and run them through the front load washer on delicate cycle, then air dry and re-install. The only issue I had with them was that I did the piping on the edges, and the driver's side outside edge that piping wore through within a year.
    vtl[QUOTED] likes this.
  19. May 14, 2021 at 9:31 AM
    Angry Gunny
    Angry Gunny New Member
    Rob
    Bedford, PA
    2016 SSM 1794 4X4
    Yes please
  20. May 14, 2021 at 9:33 AM
    SpooledReel
    SpooledReel Insufficient Funds
    RickyP
    Spanish Fort, AL
    2015 Tundra CM Limited 4x4
    7811C867-AD55-4B99-93A3-72100996CA2C.jpg 38DF363B-B415-4DA3-BB79-58F082961EFB.jpg D4B66999-A97A-44F9-AD1C-2C929D7DE280.jpg E1129E0F-6A52-4FDF-9CB4-05D180C24E6F.jpg Installed some Diode Dynamic fog lights (thanks @memario1214) Did the $16 Tailgate Pop and Lock (appreciate the forum advice on that) and wired up LED’s in my bed since I was running wire. Loomed every thing with expandable wire loom and connected to the bed light wire. Planning on running puddle lights underbody and under seat led lights.
  21. May 14, 2021 at 9:36 AM
    GAknight
    GAknight New Member
    Shade of a Pine, GA
    '14 TSS 4x4
    Fair enough. Apologies if the thread/contents are not helpful. Admittedly, I didn’t read thru everything. I just remembered there was a diy thread on it, and wanted to put it out there that others were working on it and potentially had success.
    I added power mirrors to my ride years ago and just added the oem switch. At the time, I don’t think there was any discussion on the auto feature. I understand it being a nice touch. (We had a c-class a couple years ago with it). For the truck tho, I just hit the button when I feel the need.
    French Avocado likes this.
  22. May 14, 2021 at 9:42 AM
    point08
    point08 New Member
    Kyle
    2014 Toyota Tundra 5.7L SR5 4WD DC
    AirLift LoadLifter 5000 Ultimate Plus, AirLift Wireless One 2nd Gen, TRD Rear Sway Bar, Bakflip G2 Tonneau Cover, Running Boards, Tint, Power Tailgate Lock, Hike-It X9 Throttle Controller, Tekonsha P3 Brake Controller with Custom In-Dash Housing, Method 701 Wheels, Toyo Open Country III Tires, 3WLiner Window Mod, External Fuse Box, Dash Cam, Pioneer DMH-1500NEX
    Went and put some new shoes and socks on the rig. Kept the OEM tire size since we are towing and I didn't want any surprises. Will throw the existing steel rims and tires on CL for cheap in case someone needs them more than the tire shop.
  23. May 14, 2021 at 9:44 AM
    Dsptundra
    Austin TX Area
    @RainMan_PNW is more at Dumbledore level wizardry. But yes, it is definitely magic.
  24. May 14, 2021 at 9:58 AM
    French Avocado
    Utah / Wyo
    My GS350 has memory and auto-fold as well. Clearly Toyota knows how to do it. The question is whether the Lexus ECUs can be used to make it work in a Tundra.
  25. May 14, 2021 at 10:07 AM
    point08
    point08 New Member
    Kyle
    These look good! If I ever move to a spray-in liner, I'd like to do the same!
    SpooledReel[QUOTED] likes this.
  26. May 14, 2021 at 10:24 AM
    SpooledReel
    RickyP
    Spanish Fort, AL
    Thank you sir. I’m to cheap to buy a kit that will leave me wanting something more. These are $9 leds that I picked up off eBay along with the wire and loom. There are existing holes there that I assume are for bed stake bolts? I have less than $20 in it. I sealed all of the leds with epoxy which is overkill under my bed cover. It’s way brighter than the picture leads you to believe.
  27. May 14, 2021 at 10:49 AM
    TNTundra16
    TNTundra16 YOU BIG DUMMY!
    Cam
    Amish Country, TN
    2016 CM SR5 4x4 SSM
    :benchpress: The bronze wheels with silver sky paint look killer! Gives me ideas :spending:
  28. May 14, 2021 at 10:56 AM
    GhostCat
    GhostCat New Member
    Just got her out of the shop today....3/2 ReadyLift, Window Tint, 305/70 R18 Hercules Terra-Trak TG MAXX tires......
    Now I've got to remove the front mud-flaps and maybe some trimming to do....but I LIKE HER!!!!
    Oh, I forgot to mention 1.5" Wheel spacers....
    WFD473, Wallygator, Astom22 and 18 others like this.
  29. May 14, 2021 at 10:59 AM
    SpooledReel
    RickyP
    Spanish Fort, AL
    That looks great! Wheel spacers as well?
    Astom22 and GhostCat like this.
  30. May 14, 2021 at 11:02 AM
    Angry Gunny
    Rob
    Bedford, PA
    2016 SSM 1794 4X4
    Yes please
    Thanks, I saw another member here with the bronze on Silver.
    TNTundra16[QUOTED] likes this.
