2018 Tundra key fob range
Discussion in '2.5 Gen Tundras (2014-2021)' started by Philly Tundra, Jan 21, 2019.
  1. Jan 21, 2019 at 11:02 AM
    Philly Tundra
    Philly Tundra [OP] New Member
    Tre
    2018 Limited
    Debadged chrome Color matched side mirror door handles Swap chrome grill for color match platinum honeycomb
    I have an 18 limited the range on my key fobs is usually terrible...after having an 08 for 10 yrs and never having a problem i figured the fobs just came with bad batteries so i changed both but it didn't help much.
    Am i the only one? Cant use it more than 10ft away like 3/4 of the time..
    Anyone else?
  2. Jan 21, 2019 at 12:34 PM
    NCTundra18
    NCTundra18 New Member
    Jeff
    Candler, NC
    2018 White Limited Crewmax
    TRD dual exhaust, Rough Country lift kit and too much money spent.
    Just tried mine and it works from about 60ft and that's me standing at my neighbor's driveway. My truck was at the bottom of my driveway so i couldn't see it.
  3. Jan 21, 2019 at 2:16 PM
    Hammy68
    Hammy68 Peak Bagger
    New Hampshire
    2018 Silver Tundra TRD Off Road Crewmax
    RC 1.75” Front, 1” Rear, TRD Dual Exhaust, Nitto RGs 275/70/18, TRD Center Caps, Rugged Cover Hard Tonneau, Rhino Liner, LED interior/exterior upgrade
    I noticed with mine that it doesn’t lock the doors sometimes, unlike my Tacoma and 4Runner. Its like if I jump out and hit the fob pretty fast, the truck will not accept the signal- like it needs a few seconds after I close the door to reset something allow the doors to lock. I have to stop and turn around and hit the fob a few more times. I tried both fobs thinking the button might be defective, but both fobs are the same.
  4. Jan 21, 2019 at 2:21 PM
    Tundra_Sam
    Tundra_Sam New Member
    My 2018 has issues. Haven’t had time to take it in. It’s a pain to get all doors to unlock.
  5. Jan 21, 2019 at 2:25 PM
    Hammy68
    Hammy68 Peak Bagger
    New Hampshire
    Mine unlock fine, and I have them set to all unlock with 1 click.
  6. Jan 21, 2019 at 2:25 PM
    NCTundra18
    Jeff
    Candler, NC
    I changed mine so all of the doors unlock at the same time.
  7. Jan 21, 2019 at 5:32 PM
    PA452
    PA452 New Member
    2021 Tundra SR5 CM TRD O/R
    Mine doesn't work from as far away as my Tacoma fob did, but I haven't had any issues with it either.
  8. Jan 21, 2019 at 5:51 PM
    wilsonos2
    wilsonos2 New Member
    Don
    2018 Tundra Sport
    3” lift, 33” tires
    2018 here and my range is pretty poor. i hold it under my chin all the time for extra distance.
  9. Jan 21, 2019 at 8:27 PM
    JDHolliday27
    JDHolliday27 New Member
    2018 CM
    Booney and Donkeypunch like this.
  10. Jan 21, 2019 at 8:42 PM
    Philly Tundra
    Tre
    2018 Limited
    Thanks.. i did also swap cargo lamps for led. I'm going to see if i can shield behind on side to see if that helps. Will post my findings.
  11. Jan 21, 2019 at 10:53 PM
    Donkeypunch
    Donkeypunch New Member
    Yup, I am pretty sure most, if not all member who posted on here about KeyFob issues changed the cargo lights to LEDS.
  12. May 8, 2021 at 11:17 PM
    Vockroth
    Vockroth New Member
    Steven
    Santa Clarita, California, USA
    2008 Tundra Double Cab Limited 2WD Arrest Me Red
    Late Model 18" Factory Wheels | Michelin LTX M&S P275/65R18 116T Tires | TRD Sway Bar |Factory Running Boards | Ready Lift 66-5075 2.4" Front Leveling Kit | Bilstein B6 4600 Shocks and Struts | Curt Mfg 31198 Front Hitch | LLumar Formula One Stratos 30% Ceramic Tint Front Side Windows | K&N 33-2387 Filter Element | Morimoto Head Lights and Fogs | Snug Top Hi-Liner | Bed Rug | Anker ROAV T2 R5114 FM Transmitter | Intro-Tech #56060046 Custom Auto Shade | Ozium Air Freshener 4.5oz, (fits in ashtray hole)
    My 08 has a 10ft range. Always had. New FOB didn't help. My IS300 has maybe 100ft range with the FOB built into the key.
  13. May 9, 2021 at 6:37 AM
    frichco228
    frichco228 Valued Member
    Frank
    Virginia
    2016 Crewmax 4WD, TRD Offroad
    Probably due to LED lights installed in the cab, tails or 3rd brake
  14. May 9, 2021 at 9:37 AM
    panicman
    Eric
    2018 SR5 CM TRDoffroad MGM
    2018, VLED led cargo lights, range is at least 50-60’, no issues.
  15. May 10, 2021 at 10:42 PM
    Vockroth
    Vockroth New Member
    Steven
    No LEDs on my truck. I have learned that if I hold the fob high in the air that it works better. I did a test I pointed the FOB at my truck and walked back till it didn't work. I tried the chin thing and nothing. I held the FOB high over my head and it worked. I continued walking back till the FOB didn't work. I got maybe another 8 feet.
