Touchy Throttle
Discussion in '2nd Gen Tundras (2007-2013)' started by danix, May 2, 2021.
  1. May 2, 2021 at 9:41 AM
    danix
    danix [OP] New Member
    I've found a little info on a recall on another site but nothing here.
    My 2007 with 5.7V8 has a super touchy throttle. Most of the time it's fine, but sometimes even the slightest throttle application causes it to leap forward. It did it yesterday at the airport as I was leaving the curb and scared the crap out of folks.
    Throttle also seemed super touchy on the bumpy freeway, where bumps were causing throttle surge.
    Toyota has done a general inspection on the truck, wondering if I should ask them for something specific. Any info would be helpful thanks!
    TNCountrygal likes this.
  2. May 3, 2021 at 9:37 PM
    MTRock
    MTRock 1889
    Montana
    2013 Rock Warrior DC
    DC rear fold down seats, decals removed, blacked out badges, complete stereo, ceramic coating, ToyTec Boss 3/1.5, RidgeGrappler 305/70r17, blacked out rock rings and center caps, smoked tail lights, BAMUFFLER Alpharex Pro headlights, TRD PRO Sequoia Grille, DAPtune
  3. May 4, 2021 at 6:50 AM
    BlueCrushSC16
    BlueCrushSC16 New Member
    Charleston, SC
    The Pedal Commander has really reduced the touchiness of the gas pedal in my '07.
    Filthyphil likes this.
  4. May 5, 2021 at 2:23 AM
    414tundra
    414tundra New Member
    I had the same issue when I bought my 07 used. I replaced it with an OEM pedal that I bought off of Amazon and the touchiness went away.
  5. May 5, 2021 at 4:17 AM
    Rex Kramer
    Rex Kramer Vinyl Spinner
    Georgia
    I love the responsive gas pedal in my 2007, and I wouldn't do anything to change it.
  6. May 5, 2021 at 4:20 AM
    MrMitch96
    MrMitch96 New Member
    Mitch
    ME
    2014 Toyota Tundra SR5 TRD-Off Road
    Just use the tow haul button
  7. May 5, 2021 at 9:59 AM
    danix
    Responsive yes, its the inconsistency that bugs me.
    Black Wolf and Leo's first like this.
  8. May 5, 2021 at 10:08 AM
    danix
    It appears that revised part 78110-0C012 cures the touchiness. I may try it.
    The inconsistent response could be my foot - when I had the issue at the airport, I had just come off a week driving a Nissan Titan, so perhaps my foot was miscalibrated :)
  9. May 6, 2021 at 10:12 AM
    idiggplants
    idiggplants New Member
    PA
    2013 DC 4wd
    5100 fronts middle setting 5100 rears 3rd gen offroad wheels softopper ditch lights
    nah, its definitely not just you. this is the first vehicle ive ever had an issue with. its impossible to roll onto the throttle. the first 1/8" of throttle depression does what the first 1/2" should do.
    idk why people mistake it for throttle response. its possible to have great throttle response and still be able to ease onto the throttle. ive gotten a bit better at easing away from a red light, but the tundra is my second vehicle, so every time i switch back to it, i end up giving my GF and i some wiplash at least a couple times. it especially sucks for trying to increase my mpg, or retaining traction on a slippery surface from stopped. ive heard the throttle commanders can help, but im not about to spend a couple hundred to fix something so stupid.
    ive heard that the issue arose from toyota's shitty fix for the recall. apparently the fix was to install a shim which made most trucks accelerate in this manner. ive also heard that if you complain about the touchy pedal they will swap out for the newer pedal under the recall.
    danix[QUOTED][OP] likes this.
  10. May 6, 2021 at 10:18 AM
    Dalandshark
    Dalandshark Infected with 5G
    Northwest
    2007 Tundra SR5 5.7 Longbed
    Eibach Level LIft
    You can have the pedal replaced with the latest version and it will help. That’s what I did.
  11. May 6, 2021 at 10:48 AM
    danix
    Found a new pedal on ebay for $85 so I ordered it. I'll report back.
  12. May 6, 2021 at 11:05 AM
    kranyx
    kranyx New Member
    '07 DCLB 5.7
    Yeah, they put a shim in the original pedal during a recall which is what is causing the abruptness.
    for that same recall they could have also replaced the pedal with this part number if the owner complained about it: 04000-0440C
    I ordered one of these pedals a few weeks ago for my '07 for $27+shipping and a brand new 78110-0C012 pedal showed up. it solved 90% of my issue with it.
  13. May 6, 2021 at 6:08 PM
    Dalandshark
    Northwest
    Eibach Level LIft
    I took the shim out of mine and it was still sticky. There are some plastic cams inside that cause friction and were binding on mine. When I inquired and said I wanted to just buy the pedal the parts guy at dealer insisted on taking care of it for me. Ever since then parts cost double though
    :D
  14. May 6, 2021 at 6:18 PM
    blackoutt
    blackoutt YEAH BUDDY!
    Indy
    07 DC Long Bed - Old Man Tan
    OEM+
    I had a cut pedal from the floor mat recall that was touchy in my 07. I replaced it with a 04000-0440C Pedal Assembly Accelerate for $39 shipped and now it's muchhhhhh smoother, and not cut off on the bottom.
  15. May 6, 2021 at 7:18 PM
    ScenicRoute
    ScenicRoute New Member
    2021 Tundra CM Nightshade
    Eibach stage 2, SmartCap, Ride Rite, Bora spacers, 35” rugged ridge tires.
    You’ll get used to it. I remember back in 2004 or so we had a new Tahoe and it went for service and they gave us a newer Tahoe with drive by wire. For the first mile or two every bump was a throttle jostle. I got used to it quickly and didn’t notice it until we got our throttle cable Tahoe back.
  16. May 7, 2021 at 7:02 AM
    Trident
    Trident New Member
    2007 Tundra DC 4X4
    After 4 years I'm pretty much used to mine now, but if there's crappy asphalt (holes, etc) when I take off I can still snap necks.
    2008tundrablue likes this.
  17. May 7, 2021 at 9:53 AM
    Tipsovr
    Tipsovr New Member
    2012 RW Crewmax
    I was wondering if it was just me. My Tundra scares the crap out of my 17 year old when he drives it, compared to his V8 4Runner. The throttle on mine will snap your neck every so often. It just isn't consistent in the way it accelerates.
  18. May 8, 2021 at 10:55 AM
    2008tundrablue
    2008tundrablue New Member
    I also dislike the touchy pedal. It’s a day and night difference between the Tacoma and tundra.
  19. May 10, 2021 at 7:55 AM
    idiggplants
    PA
    2013 DC 4wd
    ok, so im trying to figure out what pedal to buy... seems like the 04000 pedal is about $30-50. the 78110 is about $150-200. big difference. id obviously rather spend $40 than $150. my only concern would be replacing it with the part that was recalled to begin with. im assuming the last owner did the recall, so i dont want to end up with liability undo-ing the recall work.
    which part number did you go with?
    do you know which part yours was?
    may i ask what led you to that part number vs the other? im assuming this is a quick install.... seems like 2 bolts and an electrical connector?
  20. May 10, 2021 at 11:00 AM
    kranyx
    kranyx New Member
    '07 DCLB 5.7
    order the 04000-0440C pedal. The pedal in the box will be labelled 78110-0C012 which is not the recalled pedal, it's the new one.
    I assume that this was an internal part number for Toyota so the dealers could order the pedals at cost or something for the recall.
    I ordered a 04000-0440C pedal and got a new pedal labeled 78110-0C012 inside the box labeled 04000-0440C.
    and yes, it's easy to install, takes 60 seconds. Two nuts and a wiring plug. the nuts can be a bit tricky since they're lock nuts of some sort, but they are reusable.
    idiggplants[QUOTED] likes this.
  21. May 10, 2021 at 11:15 AM
    Aurora CO
    The replacement pedal helps but the throttle mapping pre 14 is in fact different. No mistake about that.
  22. May 10, 2021 at 11:18 AM
    idiggplants
    PA
    2013 DC 4wd
    THANKS! yeah, everything im seeing in googling the 04000 part number refers me to different threads on the forums shows people talking about it being the pedal to get to solve the issues. and it looks like there is an online toyota dealer in my state that will ship it to my door for $37. i went ahead and added it to my, input email/information, and then close the tab right before completing checkout to see if they send me a discount code. ive had that work at quite a few dealers over the years :)
    im pretty stoked to check off the top item on my very very short list of annoyances about this truck. and i dont expect miracles, but i have a feeling it will make a mild improvement to my MPG.
    blackoutt likes this.
  23. May 10, 2021 at 11:27 AM
    blackoutt
    Indy
    OEM+
    I don't know the difference between the part numbers or if they are in fact the same. Just reference a bunch of threads and googling and found the 04000-0440C for cheap-ish. 10 minute very straight forward install, 2 nuts and the electrical connector.
    idiggplants likes this.
  24. May 10, 2021 at 7:33 PM
    Dalandshark
    Northwest
    Eibach Level LIft
    Yes this is the most recent version of the pedal that is called out as a replacement in the recall bulletin. Same as the one I have.
    Edit: my yes is to answer @idiggplants question
  25. May 21, 2021 at 12:53 PM
    danix
    Got pedal, installed it - very simple install, two 10mm nuts and one electrical connector. Took about a minute to swap it.
    I haven't driven it that much, but so far the new pedal definitely seems less touchy.
    Why? I'm guessing that if you measured the output of the potentiometer, pressing 1/2" on the old pedal yields more voltage than on the new one, so that's why it is more sedate.
    At WOT (wide open) the voltage should be the same, so if you floor it there is no loss of performance.
    Dalandshark likes this.
  26. May 22, 2021 at 3:26 AM
    jbrnigan
    jbrnigan New Member
    Midwest
    2007, 5.7L, 4x4, Crewmax,
    The throttle pedal on my '07 Tundra was modified by Toyota in 2008 - per TSB, they added the "shim". That didn't seem to change the level of throttle sensitivity, IMO. Over the past 13 years I have not thought much about it. A few of weeks ago I found the metal cover that you remove to install the shim, on my floormat. Decided to replace the pedal after reading so much about replacement pedals and throttle sensitivity. Got the replacement pedal for 37 bucks delivered (04000-0440C). I must admit, it did change the "feel". It's subtle, but, definitely improved.
  27. May 22, 2021 at 5:57 AM
    blackdemon_tt
    blackdemon_tt Battery Slayer
    I'm so glad I didn't jump on either of these TSBs... I don't have issues with my pedal... The only unintended acceleration I got was once in Arizona when I flew past an unmarked state trooper, that I didn't see.... and I got out of a ticket for....
    MTRock likes this.
  28. May 26, 2021 at 8:01 PM
    Scooter916
    Scooter916 New Member
    Nathan
    08 5.7l CrewMax SR5 2wd,
    custom shift knob, Hooke Road front and rear bumpers, 12v Solutions Remote Start
    I picked up my 08 5.7l last June. So I've had it about a year now and have always felt the has pedal was a bit jumpy, especially at intersections or stop signs with ruff roads, if I'm not paying super close attention it's not a very smooth acceleration. After reading about a recall, Im curious if the previous owner did anything about it, or if I have the new pedal. Is there a part number took look for?
  29. May 26, 2021 at 9:57 PM
    Dalandshark
    Northwest
    Eibach Level LIft
    Log into Toyota owners (Toyota website) and add your truck. If it was done, 99% chance it will show up there. 99% chance if the pedal recall shows up that they just installed a shim and didn’t replace the pedal.
  30. May 26, 2021 at 9:59 PM
    Scooter916
    Nathan
    Awesome thank you, where is the shim located if I need to look for it?
