Trans fluid UOA
Discussion in '2.5 Gen Tundras (2014-2021)' started by Sumo91, May 7, 2021.
  1. May 7, 2021 at 3:27 PM
    Sumo91
    Sumo91 [OP] Busy with projects
    TN
    2014 MGM Tundra Platinum 4x4
    Hey guys, just got my UOA on my trans fluid. 41k miles on the fluid. I ran Schaeffers 204SAT all trans supreme. Which is slightly thicker in viscosity than what should be used, but didn't hurt anything. I called Schaeffers whenever I realized I used the wrong fluid, and they said I should be good to go if everything was shifting good, so I kept it in. I replaced it with 205A, ill be posting another report in 50k miles on the 205A. Screenshot_20210507-172119_Acrobat for Samsung.jpg
    WILLINH, ColoradoTJ, omgboost and 2 others like this.
  2. May 7, 2021 at 3:29 PM
    Rocko9999
    Rocko9999 New Member
    Did you do a complete fluid replacement to start with or just drain/fill?
  3. May 7, 2021 at 3:38 PM
    Sumo91
    TN
    I replaced around 14qts when I put the 204sat in. And I put in around 16qts when I replaced that with 205A. I drain it from the cooler return line on the transmission about 2qts at a time, refill 2qts, and repeat.
    Rocko9999[QUOTED] likes this.
  4. May 7, 2021 at 6:07 PM
    blanchard7684
    blanchard7684 New Member
    Thanks for sharing .
    Do you have cooler or just the puck?
    Sumo91[OP] likes this.
  5. May 7, 2021 at 6:11 PM
    Sumo91
    TN
    2014, has a factory cooler
  6. May 7, 2021 at 7:46 PM
    Blue Thunder
    Washington
    Yep, looks good.
  7. May 8, 2021 at 4:12 AM
    JohnLakeman
    Outside of Weird, TX
    2017 MGM DC TSS 4.6L
    All wear metals, except copper, are below Blackstone's AB60 reference sample. That's good, but the copper is worth watching to see if it continues. Not necessarily a bad sign, but higher than reference.
    I would want more explanation of Boron, Calcium, and Phosphorus purpose in transmission fluid. Those are probably additives. The levels are significantly higher than reference, and represents Shaeffer's formula.
    Sumo91[QUOTED][OP] likes this.
  8. May 8, 2021 at 7:03 AM
    Rocko9999
    Do you use a funnel and hose to refill or a pump?
  9. May 8, 2021 at 11:29 AM
    Sumo91
    TN
    They seem to be good additives. Schaeffers always has a really robust additive package. I love all their products. The fact that the fluid still has alot of additives after towing heavy and driving hard is great. I'll be doing a uoa on the rear diff next.
    I found this link about oil additives which was helpful.
    https://www.google.com/amp/s/learno...nce/oil-additives-typical-concentrations/amp/
    JohnLakeman[QUOTED] likes this.
  10. May 8, 2021 at 11:33 AM
    Sumo91
    TN
    A funnel and hose
  11. May 8, 2021 at 1:38 PM
    Sumo91
    TN
    @JohnLakeman after doing more research into the copper levels, it is most likely from the transmission cooler. I've read that the copper in the cooler can leach into the fluid, which may explain it
    JohnLakeman and ColoradoTJ like this.
