Need help
Discussion in 'Lighting' started by stormy1, May 4, 2021.
  1. May 4, 2021 at 5:55 PM
    stormy1
    stormy1 [OP] New Member
    Replaced interior lights with LED all was well till I Got to foot well light , took out lamp and had to mess with it to get LED to fit, looked up and sometime in the process lost all interior I just replaced, changed every 7.5 amp fuse under the hood no good 2021 tundra
  2. May 4, 2021 at 6:29 PM
    TaquitoBandito
    Joel (AKA Bif)
    Did you look in the fuse box under the dash? It's on the drivers side.
  3. May 4, 2021 at 6:33 PM
    stormy1
    Got my head all twisted up in there and all I see is a small fuse block full , I think about 5 fuses all 30 amp
  4. May 4, 2021 at 7:16 PM
    TaquitoBandito
    Joel (AKA Bif)
  5. May 4, 2021 at 7:25 PM
    HighonFirewood
    HighonFirewood Everything can be fixed with a hammer.
    Stage Left. Colorado
    2019 Tundra
    Look at the diagram. I popped a 15 or 7.5 in the cab for my tail light LEDs.
  6. May 4, 2021 at 7:36 PM
    stormy1
    Nothing on fuse box under hood says dome, like I said replaced all 7.5 anyway, under dash behind parking brake small fuse block with all 30 amp fuses don't know what to do now
  7. May 4, 2021 at 7:48 PM
    TILLY
    TILLY Gently Used Member
    Massachusetts
    2019 MGM TRD Sport D/C
    So you lost all the lights messing with the footwell light, did that one work when you got it plugged in correctly, or is that one dead as well?
  8. May 4, 2021 at 8:04 PM
    stormy1
    All still dead
  9. May 4, 2021 at 8:14 PM
    TILLY
    Massachusetts
    It might sound like a stupid question, but did you check the 3/way interior light switch to make sure you didn't accidently bump them off while working down in that area?, its happened before.
  10. May 4, 2021 at 8:17 PM
    Bob_Wiley
    Bob_Wiley I feel good, I feel great, I feel wonderful...
    Eric
    AZ
    2016 Black SR5 Crewmax 5.7 FFV
    Just to confirm, you’ve replaced this fuse under the hood? I’ve had the same problem with my interior lighting after installing LED footwell lights. Every time they’ve gone out, this fuse was the culprit.
  11. May 4, 2021 at 8:34 PM
    stormy1
    I was hoping i did just bump switch, but not it. I have nothing on my fuse box under the hood that says DOME but I did replace every 7.5 amp fuse in there, I think there's 4
  12. May 4, 2021 at 8:51 PM
    TILLY
    Massachusetts
    That's a bummer. The only other thing I can think of is that there is a setting in your H/U to set the timing in seconds for the interior lights to turn off which also includes a completely off setting. Maybe a long shot, but I would check that for sure. Good luck.
