Diamondback cover in aluminum (not black)?
Discussion in '2.5 Gen Tundras (2014-2021)' started by lawfarm, Jan 26, 2019.
  1. Jan 26, 2019 at 12:50 PM
    lawfarm
    lawfarm [OP] New Member
    2018 Tundra SR5 Premium TRD Crewmax
    Anyone have an uncoated diamondback? Pics? Thoughts?
  2. Jan 26, 2019 at 4:45 PM
    JoshuaA
    JoshuaA Canuck Member
    Southern Ontario
    Blaaack 2.5G
    Looks unfinished to me but it’s really what you like, your truck.
    From google:
  3. May 1, 2021 at 5:48 PM
    Sjmilzy
    Sjmilzy New Member
    Stephen
    2018 Silver Tundra
    I live in Oklahoma! The black would cook anything in the bed on some hot summer days! I’m thinking about the uncoated!
  4. May 1, 2021 at 5:58 PM
    eick
    eick New Member
    2020 CrewMax TRD Off Road
    I have black one here in DFW and while the diamondback gets hot the air in the bed is surprisingly cooler.
  5. May 2, 2021 at 4:07 AM
    racerex
    racerex New Member
    Will
    Westchester County, NY
    2021 Limited CM TRD Off-Road
    If you think heat will be that much of an issue, you could install adhesive automotive flexible thermal insulation to the underside of each panel. I’ve used the combo sound deadening thermal/heat shield insulation on the floor pan and lower interior firewall on a few of my project cars.
  6. May 3, 2021 at 9:59 AM
    Rocko9999
    Rocko9999 New Member
    I have an unfinished toolbox and they look bad after a few years. Polishing is a real PITA.
  7. May 3, 2021 at 10:06 AM
    IndianaGeologist
    IndianaGeologist New Member
    I think with the aluminum you'll always be blinding yourself on sunny days.
    Rodtheviking and Rocko9999 like this.
  8. May 3, 2021 at 10:06 AM
    Phrog Driver
    Phrog Driver New Member
    2021 Silver Sky Crew Max TRD Off Road
    I just put on an unfinished Dback SE. Pics here but not been on long enough to generate any thoughts. Dback 1.jpg Dback 2.jpg
  9. May 3, 2021 at 1:35 PM
    Blue Thunder
    Washington
    I don’t like the looks, especially with the black handles. Plus, I think the black finish will make the surface more durable and hide-prevent scratches.
    I had a DB on my F350 and loved it. I threw stuff on top all the time and was glad to have the coated surface.
