  1. Apr 29, 2021 at 2:00 PM
    TheBlackPearl
    TheBlackPearl Newish member
    La Gulf Coast
    2020 Black TSS Crewmax 4x4
    Just a little psa...every time you go through car wash (with brushes) you’re sanding down your clear coat a little. Not to mention scratching up your headlights.
    whodini12, TILLY and DeesCrewMax like this.
  2. Apr 29, 2021 at 2:03 PM
    AZBoatHauler
    So.Arizona
    And there is a decent chance your roof molding will blow away on the way out.
  3. Apr 29, 2021 at 2:28 PM
    CorsoTundra
    CorsoTundra This is the way
    North GA
    2021 Cement Trail Edition
    Toytec Aluma 3/1.5, Pro headlights, OEM LED fog lights, AJT chrome delete, interior/exterior LEDs, front TRD sway, 18x9 Method Roosts, 285/75/18 Toyo A/T 3, RCI engine skid,
    Did a few things today:
    Finally got the Baja Designs fogs in
    Then did a little DIY on the chrome Method caps
    Put the Rigd on this truck and installed their new latch
    Threw a little cement TRD hitch cover on
    and finally ordered a dual sub enclosure and amp from @tech12volts.
  4. Apr 29, 2021 at 2:33 PM
    snowman19
    snowman19 New Member
    Scott
    Cypress, Texas
    2019 White Tundra CM
    Katskin leather seats, painted engine cover, fuse box cover, Rigid 30" light bar in bumper, Method 605 wheels, Bak roll up bedcover, Rhino lined grill surround and bumper caps
    Like the trick on the wheels, been thinking about doing something like that on my Method 605’s...did you hand paint the letters? Truck looks awesome...
    CorsoTundra[QUOTED] likes this.
  5. Apr 29, 2021 at 3:05 PM
    Asimov2025
    Asimov2025 Not Sure
    Trent Woods, NC
    2019 TRD 4x4 Sport
    Non-stop mods
    We had the hail hit too...no damage this time. In 2016 it wiped out my truck and tore up the roof. I feel your pain. Texas snow.
  6. Apr 29, 2021 at 3:23 PM
    CorsoTundra
    North GA
    Thanks, it's getting there.
    I used a silver sharpie for the letters. Did 2 coats of self etching primer over the chrome caps, then 2 coats of flat black. Came out better than expected. Now I don't have to spend $33 a piece on black caps.
  7. Apr 29, 2021 at 3:57 PM
    DCB500
    DCB500 New Member
    Oklahoma City
    2019 Tundra SR5 TSS Double Cab
    Wheels, sound system, antenna, tailgate letter inserts, Grill/Hood Bulge, Exhaust, Leather
    Replaced my pre-fab box with one from Tech12Volts. The other one was rattling and discovered that it was cracked when I pulled it out. But this one from JRT has separate chambers for each speaker and sounds markedly better. And with the room I freed up under the small seat I got this storage box that fits perfectly. Only regret is I ordered the dark grey carpet instead of black - thought the dark grey would be a little darker but can’t see it when the seats are down so not a huge deal.
  8. Apr 29, 2021 at 4:06 PM
    PNWTundra2021
    PNWTundra2021 New Member
    Craig
    Puyallup, WA
    2021 Tundra TRD Offroad
    Limited Faux Pro
    Got some gears from the great guys at Nitro.
  9. Apr 29, 2021 at 4:07 PM
    Aught16TSS
    Aught16TSS New Member
    J
    Tuckasee
    2016 TSS - Magnetic Gray Metallic
    Dual Flowmasters, hidden LEDs in hood bulge, 3.5" lift and Ridge Graps
    what tow mirrors did you get? They look like the factory ones I had on my 08. I’m looking for a good set to put on my 16.
  10. Apr 29, 2021 at 4:27 PM
    Plumpy33
    Plumpy33 New Member
    Mark
    Central PA
    2020 White Double Cab Limited
    Installed seat jackers on the passenger seat to make the Mrs. more comfy. (If mom ain’t happy, ain’t nobody happy!)
    Installed interior VLEDs and then replaced the fuse that I blew.
    Also replaced the chrome cup holder surround with Tuffskinz. I went with MGM. I was worried about adding MGM to my Super White DC, but since it is such a small piece it only cost me about 5 hp and 2 mph at top speed!
  11. Apr 29, 2021 at 4:38 PM
    TucsonTundra1794
    Anthony
    Tucson, AZ
    2023 1794 Edition TRD Package
    Did a couple small things, new cargo hooks, tail gate gap cover, got the truck detailed, removed bed stickers, and ceramic coated... and added a few HP.
  12. Apr 29, 2021 at 4:55 PM
    AZBoatHauler
    So.Arizona
    Whats up with that?
    Paint looks killer for 90k and I'm assuming 4-5 years of desert sun.
  13. Apr 29, 2021 at 5:23 PM
    Kung
    KG, VA
    I had the dealership tear the dash apart. LOL
    When I had my solenoid damper replaced, the non-master tech left two huge spots in the dash where it'd go *bam* anytime you'd drive the truck over anything more crazy than a minor gravel road....and I live down a fairly moderate gravel road.
    So they fixed the one they heard - and it unmasked the other one.
    THIS time, without me asking, they not only fixed the issue, they also put quite a bit of NVH foam (noise, vibration & harshness) at/near any contact points or places it was likely to make noise. I drove it over the WORST freaking roads I could find on the way home and it didn't make any sounds at all.
    Not everyone can say this, but I'm VERY pleased with my dealership. :)
  14. Apr 29, 2021 at 5:24 PM
    TucsonTundra1794
    Anthony
    Tucson, AZ
    That's the reprogramming from my bullydog GT. 10 minutes of anxiety while it reprograms everything. One little hiccup and my truck is a paperweight until I can reload the stock tune. Worked perfect though and throttle response and shifting are amazing. Plus no more governor ;). Paint came out great but he peeled off the paint protection under the headlights ( under my advice) and some paint came off with it. Now I'm looking around to get both of them repainted.
    3xYOTA, mgm16trdpro, GAknight and 2 others like this.
  15. Apr 29, 2021 at 5:32 PM
    Clemshady
    Clemshady Bama Storm Trooper
    Jeff
    2017 Super White Limited DC TRD 4x4 Offroad
    \ Factory OEM LED Tundra Pro headlight upgrade Diode Dynamic amber Pro fogs 3" DD amber Pro ditch lights SDHQ ditch brackets 42" DD light bar SwitchPro 9100 Pedal Commander Vinyl wrapped bumpers Painted calipers Painted horns Chrome delete complete ARE CX Evolve Topper TRD rear swaybar Matching door handles and mirror caps Oh shit handle upgrade Matching grille surround/hood bulge TRD PRO insert grille BBS Forged TRD PRO wheels Coachbuilder +3 shackles Eibach Pro 2.0 Coilovers and rear shocks
    Got my truck washed and created a for sale thread in 3rd gen/marketplace/wheels and tires for TRD OR wheels if anyone is interested. Still loving my BBS Pros!!
    Tundra@21, 3xYOTA, EN2TUNDRA and 13 others like this.
  16. Apr 29, 2021 at 5:46 PM
    TunBrun
    TunBrun New Member
    Sunnyvale, CA
    2017 5.7L Crewmax Blazing Blue
    After finishing install I noticed a some significant vibrations when I drove it. Turns out the plate was making contact with the bottom of the transfer case.
    I tried spacers, putting the rear plate beneath the front plate to lower it, and eventually took off the small protection plate mounted to the bottom of the transfer case.
    Just wanted to post this so folks are aware of it.
    AggiePhil and IndianaGeologist like this.
  17. Apr 29, 2021 at 6:01 PM
    Wallygator
    QUOTE="Bakershack, post: 2217397, member: 46846"]Pics?[/QUOTE]
    Here ya go. The lights are pretty bright. This pic is with just one on...
    Both on from the outside...
    And while we are here, here is what I did today. Lux lighting magnetic mount leds used as under hood lighting.
    whodini12, Tundra@21, 3xYOTA and 14 others like this.
  18. Apr 29, 2021 at 6:04 PM
    IndianaGeologist
    IndianaGeologist New Member
    Have you tried contacting @Classy63 ? He might have an idea on how to help.
    TunBrun[QUOTED] and AggiePhil like this.
  19. Apr 29, 2021 at 6:07 PM
    Classy63
    Classy63 Valhalla’s Shield guy
    Tyler
    Cypress Texas
    15 platinum Barcelona red
    Toytec Aluma 2.0 front and rear, Toytec shackles, Toytec add a leaf pack, Tuff Country UCA’s, Firestone bags with daystar cups. JBA long tubes, w/3” cats, Dirty Deeds TRD replacement, DAP tune, AFE filter
    Did you remove the factory little skid plate from the transfer case?
  20. Apr 29, 2021 at 6:15 PM
    CurtisLemansky
    CurtisLemansky 5.7 or Die
    2017 SR5 CM TRD OR
    They’re OEM, so probably exactly the same as what you had. I was considering Boost Auto aftermarket mirrors but I think the OEM are better suited for a half ton.
  21. Apr 29, 2021 at 6:20 PM
    Aught16TSS
    J
    Tuckasee
    @CurtisLemansky thanks for the reply. I liked the oem mirrors for towing my TT. I’m gonna start looking for an affordable set. Truck looks good by the way.
    CurtisLemansky likes this.
  22. Apr 29, 2021 at 6:34 PM
    Just found out its a guy that works downstairs. He just bought it recently. Its a 2021 with a Rough Country 4 inch lift on +18 offset. I told him about the forum and my DD exhaust. I'll rope him in when he sees the toys on mine lol.
    GODZILLA, WFD473, Astom22 and 9 others like this.
  23. Apr 29, 2021 at 6:35 PM
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    That’s what I was wondering. I didn’t even try keeping the factory thing on there
  24. Apr 29, 2021 at 6:41 PM
    TNTundra16
    TNTundra16 YOU BIG DUMMY!
    Cam
    Amish Country, TN
    2016 CM SR5 4x4 SSM
    Lookin good and good luck with sale! Folks don't hesitate to buy from Jeff as he's a stand up guy :thumbsup: I'm anxiously waiting to see the bronze powdercoated trd wheels :boink:
    Clemshady[QUOTED] likes this.
  25. Apr 29, 2021 at 7:23 PM
    Clemshady
    Jeff
    Thanks for the kind words Cameron. As soon as I get bronze wheels back, pics will go up ASAP. Hopefully next week.
    RobertD and TNTundra16[QUOTED] like this.
  26. Apr 29, 2021 at 7:29 PM
    3rdTundra
    3rdTundra Hay Hauler
    Central Texas
    2017 Tundra SR5 Double Cab TSS 4x4
    FRAC harness / camera & Full set of Valhalla plates
    I tried some non-OEM tow mirrors and had a poor fit on driver's side. Left a gap at the top point where the mirror mount meets the door panel. I see a lot of comments about the non-OEM tow mirrors fitting poorly. In this case I think the OEM mirrors are the way to go, like you did, rather than the ebay options.
  27. Apr 29, 2021 at 8:09 PM
    AggiePhil
    College Station, TX
    Maybe so but it’s better than driving a filthy truck around all the time.
    lonedrake likes this.
  28. Apr 29, 2021 at 8:11 PM
    TILLY
    TILLY Gently Used Member
    Massachusetts
    2019 MGM TRD Sport D/C
    Why is it better. :monocle:
    SSPey, GODZILLA and TheBlackPearl like this.
  29. Apr 29, 2021 at 8:45 PM
    TunBrun
    TunBrun New Member
    Sunnyvale, CA
    Yeah, I did. I figured your plate would provide more than enough protection. OK?
  30. Apr 29, 2021 at 8:47 PM
    TunBrun
    TunBrun New Member
    Sunnyvale, CA
    Good call, I think I got it straightened out.
    I was mostly posting so that if someone else experienced the vibrations they would know what to look for and have some ideas on how to handle it. :thumbsup:
