Aftermarket spare tire options
Discussion in '1st Gen Tundras (2000-2006)' started by jerryallday, Apr 12, 2021.
  1. Apr 12, 2021 at 11:44 PM
    jerryallday
    jerryallday [OP] New Member
    Jerry
    Pasadena, Ca
    2006 DC SR5 V8 Grey
    I am running method nv 305s 17inch 0 offset with 285/70r17 ko2s. I only bought four rims/wheel but purchased 5 tires.
    I really don’t want to spend the money and buy another method wheel to just to have it mounted under the truck. I would feel different if I had a cool rear tire mount. Also I paid $242 each in December and they are $262 each right now.
    Is there a inexpensive steel rim option with the same offset and size? I just need it to work incase shit happens on a trail or highway.
    Should I just use my stock spare rim? My budget is about $150
    Method Specifications
    Sku# MR30578560500
    Wheel Diameter- (IN 17
    Wheel Width - 8.5
    Bolt Pattern - 6x5.5
    Offset (mm)- 0
    Hub Bore (mm)- 108.00
    Backside Spacing (in)- 4.75
    Wheel Weight (LBS) -31.2
    Max Load (LBS) - 2500
  2. Apr 12, 2021 at 11:46 PM
    jwatt
    jwatt I heart men
    Jack
    Oregon
    Salsa Red 2007 Tundra DC @91k.
    7" BDS Coilover Suspension Lift/BDS UCAs/XB LED Headlights/Nitto trail Grappler tires on Black Rhyno Armory wheels
    I was in the same boat, but I decided to not even carry a spare tire. AAA is just a call away.
  3. Apr 13, 2021 at 12:22 AM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
  4. Apr 13, 2021 at 3:37 AM
    tvpierce
    tvpierce Formerly New Member
    Maine
    Is your spare rim 17”? (Most are 16”)
  5. Apr 13, 2021 at 3:45 AM
    Black
    2014 Tundra Limited CrewMax
    Does AAA come out on the trails?
    I have always wondered about this what are their actual rules are?
    Most of my off roading are technically on County or National Forest Roads. Be it unmaintained and many run up the middle of the creek bed at times. It is still a county road and one must have a valid registration to be operating on it.
    Wonder how AAA handles that.
    But to the OP do no NEED the offset so you don’t rub????
    Offset or overall width does not really matter just overall diameter of the tire.
    You can always make sure to put the spare on the rear (yes adds an extra step).
    You could also just buy a spacer for the spare. Or keep cruising all the wheel sites and eBay looking for a close out.
    That is how I buy my oversized spare tire. I find a close out from a place that has a lone tire left.
    Got a 275/70/18 Goodyear Wrangler Adventure with Kevlar for $120 as it was the last one TireRack had.
  6. Apr 13, 2021 at 4:59 AM
    jwatt
    jwatt I heart men
    Jack
    Oregon
    Their limitation concerning off road is ambiguous. I think it depends on local towing services which aaa chooses to use. It will most likely cost for local service, but aaa will reimburse it.
  7. Apr 13, 2021 at 5:53 AM
    BluegrassPro
    BluegrassPro New Member
    Jeff
    2021 TRD Pro
    Following. I feel the same. I’ve been working/thinking of a way to carry mine in the bed and have sort of a fabricated piece that it mounts too and bolts in and locks of course. I want something that looks good but keeps it there if I need it. Not under
  8. Apr 13, 2021 at 6:58 AM
    UTAHRTK
    UTAHRTK New Member
    SOCAL
    2017 MGM Tundra TRD CM
    Dirty Deeds 8" standard exhaust, King 2.5's/Bilstein 5160's, Built Right UCA,s, Method 701's, TOYO ATIII 35x12.5x17, TRD LED headlights, Pro Grill
    I recommend biting the bullet and getting a matching wheel. I have MR701 wheels and figured peace of mind and ease of replacement due to size/offset worth it. My tires are 295/70/17 and it fit in spare location with no trimming of spare brackets. I placed the face of the wheel up as to minimize road damage... If you go hard off-road the under the bed mount could potentially be an access issue. Good luck.
    jerryallday[OP], Glock 40 and des2mtn like this.
  9. Apr 13, 2021 at 7:11 AM
    Glock 40
    Glock 40 I'm here to break shit
    Yukon Cornelius
    Way up thar
    2000 AC Limited 4X4 4.7L
    Deadpool Edition
    Same here, I sucked it up and got a matching 5th Method with new KO2. Peace of mind.
    jerryallday[OP] and des2mtn like this.
  10. Apr 13, 2021 at 7:12 AM
    BluegrassPro
    Jeff
    2021 TRD Pro
    I agree! I’m ordering matching spare for sure. Anyone see any great ideas for keeping spare in bed without drilling ?
    id10tfr33 and jerryallday[OP] like this.
  11. Apr 13, 2021 at 8:36 AM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    I think the thing to look for is will the steel wheel clear your caliper. With 16" steel wheels and 13wl brakes the answer is often no. A 17" hopefully would fit.
  12. Apr 13, 2021 at 9:01 AM
    jerryallday
    Jerry
    Pasadena, Ca
    2006 DC SR5 V8 Grey
    Yeah, I think I will just bite the bullet. I already have the matching tire. I thought about carrying a random steel rim but it would only fit in the rear. Without a 0 to negative offset it would rub on the UCA in the front. Changing two tires during a flat sounds like no fun.
    Plus I would have to carry stock lug nuts to mount it. Since the methods take different lugs. I knew this was the answer but I guess you need to hear it from others.
    I guess it’s pay to play. Anyone got a discount for methods?
    Glock 40 likes this.
  13. Apr 13, 2021 at 12:35 PM
    jimf909
    jimf909 Battery almost dead...
    Washington or Idaho
    '03 Tundra SR5 AC 4.7 TRD w/LSD
    Dead stock with oem 16" starfish wheels. We'll see how long that lasts. :) Topper of unknown origin.
    I was 6.3 miles down a marked road on NFS land stuck at the bottom of a steep driveway on private property (no house, no nothing, just a driveway to vacant land) after the first snow of the year (not a Tundra, it was a 2WD car) and AAA refused to fetch me. I don't recall exactly what the explanation was but it may have been a lack of 4WD hooks in the area, being too remote or something like that. The car was at risk of being stranded for the winter so I called a private tow company and paid $450 for a tow. Those guys are awesome and they had a ton of fun hauling it up the hill.
    :bikewhoops::rofl:
  14. Apr 14, 2021 at 5:55 AM
    UTAHRTK
    UTAHRTK New Member
    SOCAL
    Probably no deals on a single Method but I'd call the Method dudes; they might work with you.
    jerryallday[OP] likes this.
  15. Apr 25, 2021 at 1:20 PM
    jerryallday
    Jerry
    Pasadena, Ca
    2006 DC SR5 V8 Grey
    Update: bought a method rim from offerup. It’s not a direct match but close enough. All the measurements line up. Got it for $125. I can finally wheel and drive with peace of mind.
    Will still be on the search for an exact match 305 nv in black.
    but here she is. Total spare cost was $275 with a matching new ko2 spare from another seller.
    Burgmane, id10tfr33 and Glock 40 like this.
