  1. Apr 21, 2021 at 9:24 PM
    Mitch09
    Mitch09 New Member
    NC
    2022 SR5 TRD Off-road
    they’re ok. My old ones had a lot of oxidation and these weren’t expensive. If I did it over again I’d probably stick to the clear oem look.
  2. Apr 21, 2021 at 10:48 PM
    Thrussn
    Thrussn Plastidip Hoe
    Gabe
    NM
    Silver 2005 4.7L 4WD Access Cab
    Bilstein 5100s, SickHIDs projector housings, Plastidip everything, TRD Pro style rims, LEDs everywhere, SUPERBUMP bumpstops. Firestone Riderite air bag springs, Deaver G57s, Onboard VIAIR system, Backup Camera, light bar behind the bumper, CGS catback, Exhaust cutout after cats, JBA Shorty headers, JBA Y-Pipe, pioneer deck, pioneer speakers, kicker 10" sub w/ amp, door sound deadening, Dirtydeeds 12 pin injectors, UniChip, Skid Row Skidplate, EZ Oil Drain valve (Better than Fumoto), Oil Catch Can, & 4WD Conversion
    The machine shop finally finished up on my 14wa gx460 calipers. Threw them in along with all of the additional bits like black zinc rotors, OEM anti-squeal shims, and Akebono pads.
    Excuse the brake dust
    Pearl-snap, Voss, Sirfive and 16 others like this.
  3. Apr 21, 2021 at 11:17 PM
    alb1k
    Left Coast
    05 2WD DC w/ attitude
    It's good
    Did you wet the ground for the photo?:)
    oscardog86 and NUDRAT like this.
  4. Apr 21, 2021 at 11:18 PM
    alb1k
    Left Coast
    It's good
    had I taped liked that I might be done. Don’t spray the black grid part people!
    tacoguybill[QUOTED] likes this.
  5. Apr 22, 2021 at 2:00 AM
    Hooptytrix
    Hooptytrix Squeaky Chicken
    Dirty South
    2000 AC 4x4, 2001 AC 4x4 Sold. 2005 DC SR5 2WD
    I think you meant this
    oscardog86 and KarmaKannon like this.
  6. Apr 22, 2021 at 2:04 AM
    Hooptytrix
    Dirty South
    It started raining as I was wrapping up but I may have to start getting more creative with my shots. I'll start by cleaning the lens from now on :D
    NUDRAT and Tundra2 like this.
  7. Apr 22, 2021 at 2:05 AM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    A clean aperture goes a real long way.
    NUDRAT and Hooptytrix[QUOTED] like this.
  8. Apr 22, 2021 at 2:05 AM
    Hooptytrix
    Dirty South
  9. Apr 22, 2021 at 3:17 AM
    KarmaKannon
    KarmaKannon Master of None
    Utah
    2006 Double Cab w/long travel
    Some junk
    I wish there was an easy way to do a kdss sway bar system on our trucks. I'd have a front and rear sway bar if that were the case. I didn't even know this stuff existed until we started looking at lexus gx460s for the wife.
    onesojourner likes this.
  10. Apr 22, 2021 at 3:40 AM
    Professional Hand Model
    Fred
    Hand Protectors
    You possess skills and can make it happen.
    EvilMilkshake and des2mtn like this.
  11. Apr 22, 2021 at 4:09 AM
    Fred
    Hand Protectors
  12. Apr 22, 2021 at 4:18 AM
    Fred
    Hand Protectors
    For anyone that cares, the oxidation can be cleaned up with some fine wet/dry sanding. Follow up with Alcohol wipe cleaning and spray with Acrylic Clear Coat from big box. Check my build page for results pictures.
    onesojourner and Mitch09[QUOTED] like this.
  13. Apr 22, 2021 at 4:20 AM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Thrussn[QUOTED], alee891 and bmf4069 like this.
  14. Apr 22, 2021 at 4:43 AM
    Or maybe missing a comma between black and people.
  15. Apr 22, 2021 at 4:46 AM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Voss, Lil Steve, NWPirate and 3 others like this.
  16. Apr 22, 2021 at 5:22 AM
    KarmaKannon
    Utah
    Some junk
    Oh I've been thinking about it. It's not a terribly complex system without the electronic doodads. Pretty much a cylinder on the front and rear and bypass lines to allow fluid to move between them. I don't know if there needs to be a reservoir besides what's needed to bleed the lines though. I guess there should be a small one. Now to find some appropriate cylinders...
    I wonder if hydraulic bump stops could be tapped for fluid bypass? They can be had with rod ends for easy mounting if I recall.
    Then again a small enough air shock would do the same thing without the complexity of the bypass lines. Then you'd just release the pressure to unlock the sway bars and pump it up to lock them.
  17. Apr 22, 2021 at 5:45 AM
    lsaami
    lsaami Let ‘er buck
    Minnesota
    2000 Tundra 4x4 "$1100 Build"
    bmf4069, Thrussn, speedtre and 2 others like this.
  18. Apr 22, 2021 at 5:52 AM
    onesojourner
    SW MO
    06 DBLcab LTD 4x4
    We test drove a LC with that setup. I agree that is something I will look for when the 4Runner gets replaced. It is great technology.
  19. Apr 22, 2021 at 5:55 AM
    Careful, the KDSs thread on T4r is even longer than the no tranny cooler thread here.....
    They do seem like great systems, but a lot of quirks in the system to deal with
    “Low speed clunk” is one to start
    onesojourner[QUOTED] likes this.
  20. Apr 22, 2021 at 6:27 AM
    KarmaKannon
    Utah
    Some junk
    The gx460 we are hoping to pick up tomorrow has kdss. I'll be honest and I thought the Lexus SUVs were just pretty grocery getters. Once ai engaged the center diff "lock" and tried to turn in a parking lot... Changed my mind. That thing is going to climb better than my truck.
  21. Apr 22, 2021 at 6:35 AM
    onesojourner
    SW MO
    06 DBLcab LTD 4x4
    It definitely will. I am super surprised Lexus has not been pushing the "overlanding" thing with that vehicle more. The LX and GX are at the top of the offroad game if you do some bumber trimming. You can fit 35s on a LX with the stock suspension.
  22. Apr 22, 2021 at 6:41 AM
    KarmaKannon
    Utah
    Some junk
    The lx570 is a sweet ride. I was tempted but the gas mileage is even worse than the so/so gx460. Still the gx with some trimming and sliders should make a great vehicle. Just have to talk the wife into it. Hopefully I can ease her in with the wheels and sliders and maybe find some spare bumpers to trim and build under.
  23. Apr 22, 2021 at 6:48 AM
    onesojourner
    SW MO
    06 DBLcab LTD 4x4
    It is terrible for sure.
    Life Goals
    NUDRAT, Voss, Lil Steve and 2 others like this.
  24. Apr 22, 2021 at 6:52 AM
    NWPirate
    Zach
    WA
    What year?
    Throw a picture up here tomorrow so I can drool :D
  25. Apr 22, 2021 at 8:38 AM
    KarmaKannon
    Utah
    Some junk
    It's a 2012. Needs a little love, but seems solid. I did a deposit the other day and we are planning a pick-up tomorrow or Saturday if all goes to plan. We'll see. I need a few things from the dealer still and they don't have enough of my money for me to not walk away. I think it should all work out though.
    They do look so nice though.
    abcinv, Pearl-snap, Voss and 7 others like this.
  26. Apr 22, 2021 at 8:50 AM
    I like that bumper style a lot more than the Predator grill. Nice color too!
  27. Apr 22, 2021 at 8:52 AM
    KarmaKannon
    Utah
    Some junk
    Me too. I like the f sport grill even better. Good thing it's only about $100[​IMG]
  28. Apr 22, 2021 at 10:08 AM
    alb1k
    Left Coast
    It's good
    Um, yeah, I meant the grid part. I edited to correct my bad auto correct or whatever happened there. Don't spray people either....
    Hooptytrix[QUOTED] and bmf4069 like this.
  29. Apr 22, 2021 at 10:31 AM
    Sirfive
    Sirfive Master Procrastinator
    ‘02 Limited AC TRD
    Bassani cat-back
    Brake hoses showed up last night, so thats todays truck project. Rear went in great. Since the load valve is the highest point in the system at the back should i gravity bleed from there before opening the fronts? How would one bleed the line between the load valve and front?
    Hooptytrix likes this.
  30. Apr 22, 2021 at 11:25 AM
    peanut
    peanut making uneconomical choices about my truck
    2001 Tundra 4x4 V8 Access cab 222k miles
    It has a bleeder on it. So however you're bleeding the rest of them should work fine.
    I think the order is
    back passenger
    back driver
    lpsv
    front passenger
    front driver.
    Sirfive[QUOTED] likes this.
