  1. Apr 20, 2021 at 2:51 PM
    KarmaKannon
    KarmaKannon Master of None
    Utah
    2006 Double Cab w/long travel
    Some junk
    Ah don't tell me that. Envious!
    onesojourner[QUOTED] likes this.
  2. Apr 20, 2021 at 2:56 PM
    alee891
    alee891 Rather Be Dead
    Now/here
    Shitbox
    Does anyone know of a manufacturer who provides / produces an aluminum or steel replacement for the tailgate molding on our trucks? The clips on mine have been broken for as long as I can remember, and I'm finally getting annoyed of the molding / protection popping off the truck when I unload things.
    I can find plastic replacements online, but I want to install something more robust and be done with it. Preferably not diamond plate.
  3. Apr 20, 2021 at 3:07 PM
    Professional Hand Model
    Fred
    Hand Protectors
    May not be your style, but I ran 6 Metal Roofing Screws (all weather painted self tapping with rubber grommet washer) evenly spaced along the inside portion of the gates length to hold the OEM Plastic. Been holding nicely for years. I’ve thought about a metal cap as you suggest but seems hard to find and not worth the $$$ to have one custom’d.
  4. Apr 20, 2021 at 3:09 PM
    alee891
    Now/here
    Shitbox
    That seems like a far more cost effective approach. I have no problem manipulating for functionality. You installed from the inside of the gate (closed), facing out, if I'm understanding correctly? I'm a pikcher lurner, if you have some to reference :D
  5. Apr 20, 2021 at 3:21 PM
    Fred
    Hand Protectors
    Basically, the screws are installed on the inside lip (like where the OEM Clips are). Not the top of the gate. The inside of the gate bed as its closed. You’ll space the screws evenly and in a fresh location (not the original clip holes). I can get a pic later as right now I’m tired.
    The screws are 1” Self Tappers from Big Box. They are painted gray and come with the rubber and metal washer already on the screw. Use an appropriate hex bit and they tap right through the plastic and underlying metal with a drill. Do not over tighten.
    I’ve screwed down some of the OEM Plastic Bed Liner in areas where its warped up or become loose and floppy with the same technique.
    chrisb and KarmaKannon like this.
  6. Apr 20, 2021 at 4:32 PM
    MrDirtjumper
    MrDirtjumper Ol’ dickhead
    Josh
    Slam Angelo, Texas
    06 DC TRD, 2wd to 4wd Conv.
    Look into something called ExpertVoice. If they have a relationship with your employer, or previous employers, you can get access and get discounts on all kinds of stuff. Most of it is trivial but the discount on complete bikes is insane. That is, if you can find anything in stock. The covid MTB craze made a lot of vendors pull out because of demand.
  7. Apr 20, 2021 at 4:55 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    4 Years ago today.
    OEM green looks so weird to me now. :crazy:
    This was also my first set of LEDS that had in the headlights. No fogs, no light bar, no git'r'dun.
    3 years ago. I remember this day vividly. :oops:
    NUDRAT[OP], Darkness and bmf4069 like this.
  8. Apr 20, 2021 at 5:01 PM
    MEWaters
    MEWaters New Member
    Maine
    07 2UZFE; previous 02 AC 323k
    Eibach pro suspension Nitro 4.88 with Auburn Pro LSD and PTFE diff bushings Level 8 MK6 18x9 SAIS bypass JBA cat back Scangauge 2 Diode dynamic fogs. LED heads
    Mile stretch speed run in my home town with wire showing in my rear
    07 R6 with Stage 4 power commander tuned in, full headers back micron.
    I had a -1 +2 setup on y sprockets
    speedo read 154
    redline was 13.5 or 14.5k i can't remember
    Had a tank slapper at 65 going through the mountains and about shit my self
    bmf4069 likes this.
  9. Apr 20, 2021 at 5:52 PM
    KarmaKannon
    Utah
    Some junk
    I'll check it out. I could always just hound my boss if he knows anyone. I'm sure someone has a deal guy. I'd say more than half our customers are mtb people.
    chrisb and onesojourner like this.
  10. Apr 20, 2021 at 7:15 PM
    Sirfive
    Sirfive Working on pavement
    ‘02 Limited AC TRD
    Bassani cat-back
    I need a mtb. I have a bmx bike, and grew up in the flat. Ive been through a few box store suspension bikes, but one got an engine and started to fold a wheel, and the other is somewhere in n.arkansas, i used it to bomb downhill mt.petit jean (my grandma and her cousin followed me down, drove me back up while i swapped tires and brake shoes, ald let me go again). First time i burned the brakes i was less than 100’ from a cliff edge. Had to lock it up. I tried riding a 10 speed through these hills, and found that wanting, so i went back to motorcycles.
    onesojourner likes this.
  11. Apr 21, 2021 at 7:23 AM
    Prestovie
    Prestovie New Member
    Preston
    2000 Tundra Limited AC
    33" BFG KO2's, 2 1/2in Rough Country lift kit, Westin Bull Bar and 20" matching light bar, rattle can primer gray body color.
    About to get the old girl back to her former glory. Weird question, but if you had $5-7k to dump into a project and someone that’ll do the work without charging hours(except maybe a six pack and dinner) how would you attack it? Needs a timing belt and exhaust, rust starting to creep over the fenders and rockers, been sitting for over a year so needs all fluids changed... what’s next? I’ll try to post pictures when I’m by a computer, 2000 Tundra Limited w/ 4.7L 4x4 AC. Obviously getting everything in perfect working order is a must, just wondering if anyone can think of some main things to tackle to let me get another 150k miles out of her.
  12. Apr 21, 2021 at 7:30 AM
    18" TRD Off Road Wheels
    This necromancy spell took WAY longer than intended to achieve the desired results. Wonder if the ol' Necronomicon is needing fresh souls to be back up to par?
    Still, glad to have you back, @bmf4069. Bummer on the rough go, but glad you're moving ahead. Sometimes you just gotta keep smiling, even if you're faking it.
    Congrats on the bike, too!:bikewheelie:
  13. Apr 21, 2021 at 7:55 AM
    Sounds like you are on the right track. I would certainly give the suspension a hard look too. And do all you can to stop the rust. How's the frame look? How many miles are on it now?
  14. Apr 21, 2021 at 8:15 AM
    Prestovie
    Preston
    I’m excited man, suspension right now is stock with an RC level, thinking about going ICON stage 2 with the leaf and adjustable coil overs. Frame is great! Recalled and replaced in 2015. Wondering if it’s worth it to get the body rust professionally fixed, last time i just cut it out and welded on sheet metal before rattle canning the whole truck(wasn’t going for looks lol). Currently sitting at 164k miles
  15. Apr 21, 2021 at 8:49 AM
    Wes_heppy
    Wes_heppy Trucks...Dirtbikes... Guns...
    Weston
    2003 tundra 4x4 4.7
    TC UCA Radflo coilovers Long Tubes LSD
    146k 4x4 tundra for sale where I live anybody in the market :)
  16. Apr 21, 2021 at 10:29 AM
    Cummins3500
    Logan
    Got the sequoia at least started. Trucks security system was tripped due to the remote start. Gonna pull that crap off. Only to realize the old girl had lost a head gasket. Blows more white smoke than my Cummins blows black :bananadead: 226k on the clock.
  17. Apr 21, 2021 at 10:30 AM
    chrisb
    chrisb scumbag
    noblesville, IN
    06 AC 4x4
    RIP
    Cummins3500 likes this.
  18. Apr 21, 2021 at 10:31 AM
    onesojourner
    SW MO
    06 DBLcab LTD 4x4
    I think that is the second one in the last few months. Sorry man. What is the plan? How many miles did you put on it?
    Cummins3500[QUOTED] likes this.
  19. Apr 21, 2021 at 10:47 AM
    Cummins3500
    Logan
    Truck has 226k on the clock, it’s in 2 good of shape for us to right the truck off. So I’m either looking at a crate motor or fixing the one that’s in it.
    *oem for the head gaskets I’m assuming?
    *ARP head studs, overkill I know but I’m already gonna be in there
    Not sure what I’m gonna do if the heads are warped.anybody seen this
    https://spprecision.com/products/toyota-2uz-fe-47-long-block-crate-engine-sale.html
    Kinda of scared it’s a gimmick but hell decent low mileage used motors are around 3 grand
  20. Apr 21, 2021 at 10:48 AM
    I'm starting to wonder if the 4.7 head gasket failures are as rare as we think. I've talked to a few people on Instagram it happened to. Remember, this forum is only a tiny % of all owners.
    Then again, I think Empty said he's not seen many happen at the dealer. Maybe when it happens people just junk em.
  21. Apr 21, 2021 at 10:54 AM
    rock climber
    rock climber New Member
    2001 Sequoia 4X4, 2000 AC 4X4
    There are a few used 4.7's in denver right now.
    https://denver.craigslist.org/pts/d/sedalia-47-complete-engine-toyota/7296744461.html
    https://denver.craigslist.org/pts/d/aurora-01-toyota-tundra-47-engine-denver/7289129361.html
    Also, don't know if the 4.7 from the 4runner is direct swap, but those actually seem to be easier to find and iirc they were made in Japan with better rods so you can boost it!
  22. Apr 21, 2021 at 10:59 AM
    It's just the universe telling you to add a liter to your displacement. :evil:
    speedtre, bmf4069 and Darkness like this.
  23. Apr 21, 2021 at 11:01 AM
    chrisb
    chrisb scumbag
    noblesville, IN
    06 AC 4x4
    *no one likes this*
  24. Apr 21, 2021 at 11:04 AM
    Cummins3500
    Logan
    if I’m adding liters I’m gonna add 2 more and get another diesel :anonymous:
    @rock climber I’ll look into the 4Runners, I can’t imagine it’d be hard to shove one in a sequoia
    GODZILLA[QUOTED] likes this.
  25. Apr 21, 2021 at 11:10 AM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    @bmf4069
  26. Apr 21, 2021 at 11:14 AM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    Only one in 7 years. Due to overheating from a blown radiator
  27. Apr 21, 2021 at 11:17 AM
    Says size doesn't matter while pointing a 9 foot rifle at me..... :p
    Everyone in this thread knows I only say stuff for laughs and that I am to be ignored. :burp:
  28. Apr 21, 2021 at 11:19 AM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Hell, I need to add more'n that just to compete with the rest'a y'all!
    Darkness likes this.
  29. Apr 21, 2021 at 11:22 AM
  30. Apr 21, 2021 at 11:24 AM
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
