NAPA HD CV Upgrade
Discussion in '1st Gen Tundras (2000-2006)' started by Glock 40, Apr 5, 2021.
  1. Apr 15, 2021 at 7:42 AM
    #61
  2. Apr 15, 2021 at 7:43 AM
    #62
    Glock 40
    Glock 40 [OP] I'm here to break shit
    Yukon Cornelius
    Way up thar
    2000 AC Limited 4X4 4.7L
    Deadpool Edition
    Thank you, I'll have to look for it when I get under there again. Is it also an allen... easy to access?
    Wait... after looking at your pic, I think that's the 10mm allen I was referring to.
  3. Apr 15, 2021 at 7:44 AM
    #63
    des2mtn
    Shady Grove
    2004 Black DC Limited 4x4
    Tonto cover
    Beat me to it. :rofl:Went out and got a picture too.
    Glock 40[OP] likes this.
  4. Apr 15, 2021 at 7:47 AM
    #64
    des2mtn
    Shady Grove
    Tonto cover
    Yes. It is easy to get to - you may need a pump or transfer mechanism. Skid plate removal isn't necessary but makes it a tiny bit easier.
    Glock 40[QUOTED][OP] likes this.
  5. Apr 15, 2021 at 7:47 AM
    #65
    I've not had any trouble getting any of my drain or fill plugs off. I've serviced them twice since I've had it. But it was a Cali truck that lives in Arkansas now. No corrosion. Good allen wrench with the back end of a box or crescent wrench as a cheater usually does the job.
    Glock 40[OP] and des2mtn like this.
  6. Apr 15, 2021 at 7:49 AM
    #66
    Glock 40
    Yukon Cornelius
    Way up thar
    Deadpool Edition
    Thank you gentlemen. I'll give it a good try. If I can't get it, I'll bring it to a shop before I destroy it. Finger-dip method for checking level, correct?
  7. Apr 15, 2021 at 7:51 AM
    #67
    Glock 40
    Yukon Cornelius
    Way up thar
    Deadpool Edition
    I have transfer devices. Have a Skid Row plate which allows great access without removal. :thumbsup:
  8. Apr 15, 2021 at 7:51 AM
    #68
    des2mtn
    Shady Grove
    Tonto cover
  9. Apr 15, 2021 at 7:52 AM
    #69
    Mine was on there tight but I was able to get a small breaker bar in there and loosen it. You should be able to fit something in there with a long handle.
  10. Apr 15, 2021 at 7:55 AM
    #70
    Glock 40
    Yukon Cornelius
    Way up thar
    Deadpool Edition
    des2mtn[QUOTED] likes this.
  11. Apr 15, 2021 at 7:56 AM
    #71
    Glock 40
    Yukon Cornelius
    Way up thar
    Deadpool Edition
    This gives me a renewed optimism.
  12. Apr 15, 2021 at 8:01 AM
    #72
    Use synthetic, not very stinky at all. I got a smashing deal on some Royal Purple 75-90 (13.99/qt) and bought 8 qts I think to do all three, front rear and transfer. I get 72mpg now with the lower friction from this expensive oil and 375 more HP to the wheels. :burnrubber:
    Ok, not really, but I feel better about using something labeled "synthetic". 'cause science!
  13. Apr 15, 2021 at 8:04 AM
    #73
    Glock 40
    Yukon Cornelius
    Way up thar
    Deadpool Edition
    :yes:
  14. Apr 15, 2021 at 8:05 AM
    #74
    des2mtn
    Shady Grove
    Tonto cover
    Ugh I can smell the Lucas stuff just thinking about it. The 80w-90 for the rear isn't as bad. Something about the phosphorus content?
  15. Apr 15, 2021 at 10:33 AM
    #75
    rock climber
    rock climber New Member
    2001 Sequoia 4X4, 2000 AC 4X4
    The tundra guru on facebook said to hit the allen bolt with a hammer a few times first and that makes it easier to get out. It's hard to get the hammer in there and really hit it though. Worked for me and I'm sure mine hadn't been touched since the sequoia was built in 2001, the fluid was terrible!
    If that doesn't work, people have welded a bolt to it and used that to get it off.
    Glock 40[OP] and FirstGenVol like this.
  16. Apr 16, 2021 at 12:49 PM
    #76
    Professional Hand Model
    Fred
    Hand Protectors
    I use a 2” Round 1 Foot Long short pipe cheater on a 3/8” Ratcheting Wrench combo’d with the 10MM Allen Socket. 3/8” Plus 10MM is the only thing that fits in the tight space as you’ll see. The Pipe Cheater is needed when doing this on the ground (no lift for me) and I use my leg to push the cheater to crack the plug.
    You’ll see what I’m saying if you have no lift. There is only a small window of crank space before the pipe bottoms out on the ground. If you have a lift, then its a different ballgame. I could not imaging trying to crack the drain from above without possibly destroying shtuff or something getting in the way.
    I do fill from above. Run a 4’ long PEX Line from above and turn it into the fill hole. Put a small funnel in the top end and fill with ease.
  17. Apr 16, 2021 at 2:41 PM
    #77
    Glock 40
    Yukon Cornelius
    Way up thar
    Deadpool Edition
    Well.... it was not a 10mm allen on my front diff. I tried hard to tap that 10mm in there but it wouldn't seat well. So I grabbed a small pick and flashlight to clean it out. Lo and behold it wasn't an allen, it was a T55. Once I slapped on a Torx it came out like butta. Who knew?
    The oil in there was low and extremely gnar so I drained and refilled with Valvoline 75-90. Transfer case oil looked good but I drained and refilled anyway.
    [​IMG]2021-04-16_03-39-01 by GhostCreekMine, on Flickr
    [​IMG]2021-04-16_03-39-25 by GhostCreekMine, on Flickr
  18. Apr 16, 2021 at 2:42 PM
    #78
    That ones been stripped. It probably started life as a 10mm allen.
  19. Apr 16, 2021 at 2:49 PM
    #79
    Glock 40
    Yukon Cornelius
    Way up thar
    Deadpool Edition
    No. The "stripped" look is from me trying to pound a 10mm allen into it. I beat the crap out of it trying to get the 10mm in there. The T55 slid all the way in and seated perfectly with no resistance. It's most definitely a T55. Maybe someone replaced it at some point, who knows?
  20. Apr 16, 2021 at 3:09 PM
    #80
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
    Maybe someone will replace it again at some point....you'll thank your self later :D
  21. Apr 16, 2021 at 3:12 PM
    #81
    Glock 40
    Yukon Cornelius
    Way up thar
    Deadpool Edition
    If I replace it... it'll be attached to a solid axle. :rofl:
    KNABORES and BubbaW[QUOTED] like this.
  22. Apr 18, 2021 at 12:26 AM
    #82
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    So for future replacement. I’ve found a couple gallons of gasoline is the absolute best way to clean out the grease.. when find I dump it In the oil containers at work...
    using gas made boot replacement SO much quicker
  23. Apr 18, 2021 at 12:29 AM
    #83
    empty_lord
    05 rollover special
    If you know anyone with an air hammer, that’s how I remove seized ones (you will need to replace the plug). Air chisel a Nick into the plug, then use the air hammer in the direction to loosen it and it’ll come out fine. Just can’t be too aggressive or you’ll damage the housing (in 6 years of doing it that way I’ve never seen one damaged)
  24. Apr 18, 2021 at 4:13 AM
    #84
    Glock 40
    Yukon Cornelius
    Way up thar
    Deadpool Edition
    The bearing assembly should be cleaned out with a "non-petroleum based product" as advised by other yota gurus, not sure why. Dawn detergent was highly recommended so I went that route. Gasoline or other solvents would have certainly been faster but I decided to err on the side of caution and use Dawn. I wasn't in a hurry. Worked well, just took a little longer.
  25. Apr 18, 2021 at 8:26 AM
    #85
    empty_lord
    05 rollover special
    Non petroleum is probably preferred because you do need to make sure all the gasoline’s out of the joint before reassembly.
  26. Apr 18, 2021 at 8:59 AM
    #86
    NWPirate
    Zach
    WA
    Mine was seized. This was from "What have you done" first gen thread.
  27. Apr 19, 2021 at 10:37 AM
    #87
    fytedapowr
    fytedapowr New Member
    Jake
    Austin TX
    '15 1794 4x4
    Bilstein 6112/5160, CB +2 shackles, SPC UCA's, CB bumper shims, 35's
    I went to stealership first and picked up a couple replacement plugs after realizing mine were stripped and torqued to 3 tons by previous mechanic. drilled out existing and replaced with clean new ones and crush washerrs. Cost <$10
    NWPirate and Glock 40[OP] like this.
