  1. Apr 17, 2021 at 12:45 PM
    El Two
    El Two I’m only talking to my dog today.
    Lisa
    2018 SR5 Crewmax TRD Off Road
    How much time do you have? . . . . . . . . . . . . . . . . . . . . .......... Eaton rear eLocker, Camburg 1.5” shackles, Rear Seat Delete, S&B CAI, sPOD, Air Bag Helpers w/ Daystar Cradles, RCI engine & fuel tank skid plates, ABS Guards, Job Box Storage, Tailgate Power Lock, Desert Eagle Offroad tranny/cat security skid plate, Added Driver’s Side Grab Handle, VLEDS Footwell & Step Lighting, Anytime Front Camera, Illuminated Ignition Ring, Console Molle Panel, Sound Dampening in Ceiling/Doors/Floor, Yakima Rack, Paracord Grab Handle Wraps, BD Underhood Light, Tuffy Console Safe Insert, WeBoost System, Midland GMRS Radio, Console Interior Lighting, Power Inverter, Custom Center Switch Panel, and Dual Air Compressors
    A bit of fun this past Thursday - 3rd diff member with Eaton eLocker preinstalled by East Coast Gear Supply (ECGS). My local shop only had to drop in the new 3rd and connect the power cable. I did the wiring to save a couple hundred $ on labor. Switching is controlled through the sPOD.
    Side note: ECGS does sell 10.5” 3rds but it’s not on their web site. You’ll have to contact them directly if interested.
    Before:
    During:
    After:
    The eLocker came with two wiring harnesses - one with the switch and the other with the relay. I didn’t use the switch harness and left it with the shop. The harness with the relay is connected as shown in the pic below:
    While the truck was up on the lift, Camburg 1.5” shackles were also installed.
    ElNopal, NIOSH, AZ Red Nek and 14 others like this.
  2. Apr 17, 2021 at 12:49 PM
    French Avocado
    Utah / Wyo
    Found some take off power folding mirrors to replace mine that were broken and got them installed. Now have 2018 mirrors on my 2008 - with the added aerodynamic molding. Should improve gas mileage!
  3. Apr 17, 2021 at 1:00 PM
    daveeasa
    Chrometastic!
  4. Apr 17, 2021 at 1:04 PM
    Barrett50
    Barrett50 New Member
    Barrett
    Wisco
    2015 DC silver
    How long does each coat take to dry? Curious how long 5-6 coats take. And did you do the front yet? Thanks
  5. Apr 17, 2021 at 1:10 PM
    Punisher29073
    Punisher29073 New Member
    White Knoll, SC
    2019 Tundra TRD Pro
    Clearance lights, Light bar in front bumper, Ditch lights, CB Radio, AGM Battery, SLEE Sliders,
    that is great. Can I ask what the pre set up hoghead run with the locker?
    ryan
  6. Apr 17, 2021 at 1:15 PM
    Piki
    Piki New Member
    2017 Tundra crewmax 1794 TRD
    Just finished airbags install. Time to go for test ride
  7. Apr 17, 2021 at 1:23 PM
    French Avocado
    Utah / Wyo
    Never dechromed the 2008. But the 2020 is well underway.
    daveeasa[QUOTED] likes this.
  8. Apr 17, 2021 at 1:24 PM
    El Two
    Lisa
    After the $550 core charge is refunded, figure $3k (not including installation done by my local shop). That includes the 3rd, eLocker installed, wiring, and shipping.
  9. Apr 17, 2021 at 1:29 PM
    El Two
    Lisa
    Nice. Clean install on the gauge and paddle switch.
    Piki[QUOTED] likes this.
  10. Apr 17, 2021 at 1:40 PM
    equin
    equin Texarican Tundra
    Ed
    DFW, TX
    Nice! Let us know how the elocker works when you get to try it out.
  11. Apr 17, 2021 at 1:43 PM
    cp44
    cp44 New Member
    Aaron
    NoVA
    Tundra TRD Pro
    Finally got around and installed the TRD RSB.
    cjmay13, Clemshady, GODZILLA and 14 others like this.
  12. Apr 17, 2021 at 1:46 PM
    2020Platinum
    2020Platinum www.youtube.com/NitroZ18Fishing
    Patrick
    Northeast PA
    2022 TRD Pro (Lunar Rock)
    A lot. See my channel for all installs/mods!
    Awesome job man, that’s part of the reason I went Platinum over Pro...great install!
    AggiePhil likes this.
  13. Apr 17, 2021 at 1:46 PM
    El Two
    Lisa
    Will do. There is a 500 mile break in period where I have to take it easy.
  14. Apr 17, 2021 at 1:47 PM
    SpooledReel
    SpooledReel Insufficient Funds
    RickyP
    Spanish Fort, AL
    2015 Tundra CM Limited 4x4
    Very nice! Do you have a parts list? Particularly the compressor and gauge section?
  15. Apr 17, 2021 at 1:48 PM
    Flyinryank
    Flyinryank New Member
    Las Vegas, NV
    White 2015 CM 4x4
    Leafs are looking pretty flat to me.
    The overload spring(thick bottom one)is supposed to be flat and it looks like it’s arc’d toward the ground. Maybe it’s just the camera lense
  16. Apr 17, 2021 at 2:00 PM
    JerryH
    JerryH Gravy Boatin, I don’t park I dock.
    SOMD
    2020 Crewmax Limited Cement
    Haha, as is got us!
  17. Apr 17, 2021 at 2:03 PM
    coTony
    Tony
    Montrose, CO
    I ended up removing my BSM sensors with the new high clearance rear bumper install. Got all my stuff in the garage
  18. Apr 17, 2021 at 4:40 PM
    dkahs05
    dkahs05 New Member
    2020 Tundra TRD PRO
    Added a little bling today.
  19. Apr 17, 2021 at 4:44 PM
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    Another milestone... pardon the dust
  20. Apr 17, 2021 at 4:51 PM
    Kung
    KG, VA
    They ASSEMBLE stuff??
  21. Apr 17, 2021 at 7:21 PM
    French Avocado
    Utah / Wyo
    Finally installed the VLEDS puddle lights on my 2020. Need more VLEDS - when is the next 25% off sale?
    jhardy1979 likes this.
  22. Apr 17, 2021 at 8:38 PM
    pvn.beluga
    pvn.beluga New Member
    Phuc (Phooc)
    Connecticut
    Cant wait!
  23. Apr 17, 2021 at 9:28 PM
    Jr3volution
    Jr3volution New Member
    Johnnie
    DFW TX
    2022 Tundra Platinum
    You wanna sell it?
    coTony[QUOTED] likes this.
  24. Apr 17, 2021 at 10:15 PM
    Seffagus
    Seffagus New Member
    Seth
    Colorado Springs
    2021 Lunar Rock TRD PRO
    Center console safe Blind spot monitor ReadyLift TRD Pro plus 4 BF Goodrich 35X12.5 KO2
    I can finally call myself a real TRDpro owner
  25. Apr 18, 2021 at 3:44 AM
    Piki
    Piki New Member
    Hey great job.
    How much was the locker and 10,5 3rd ?
    Thanks
  26. Apr 18, 2021 at 3:48 AM
    Piki
    Piki New Member
    Just found you answer.
    Sorry for double asking.
    Let as know how it works after brake in period
    El Two likes this.
  27. Apr 18, 2021 at 6:05 AM
    coTony
    Tony
    Montrose, CO
    I would be interested unless my wife finds out I am selling. LOL She wants it back the way it was before, it helped her she says
    Jr3volution[QUOTED] likes this.
  28. Apr 18, 2021 at 6:20 AM
    PNW_Husky
    PNW_Husky New Member
    Great Pacific Northwest
    2018 MGM CM Platinum
    @Piki What (3) switch panel are you using? I like that it doesn’t have any exposed fasteners. I want.
    Seffagus likes this.
  29. Apr 18, 2021 at 7:09 AM
    UTAHRTK
    UTAHRTK New Member
    SOCAL
    2017 MGM Tundra TRD CM
    Dirty Deeds 8" standard exhaust, King 2.5's/Bilstein 5160's, Built Right UCA,s, Method 701's, TOYO ATIII 35x12.5x17, TRD LED headlights, Pro Grill
    Tires balanced and rotated at Discount Tire. I had a wobble in the steering wheel at about 50mph; suspected/hoped a tire was out of balance and it appears that was the issue as the wobble is no more. I clearly explained that I want lugs torqued to 95 ft-lbs (Methods/ 85-95 ft-lb at a min 7.5 turns), pressure increased from 32 to 34 (going on road trip), balance weights placed on outside edge (Method 17s) and tires rotated in X patter (countering slight cupping). As Im watching the techs torque the lug nuts I ask him- "what did you torque them to?" He replies "100". I tell him that is a no go and please set to 95 and that I clearly told the admin guy at the desk... he got pissed however, I established dominance and reminded him why he was there. Not heading back to that DT....
    Wallygator likes this.
  30. Apr 18, 2021 at 7:15 AM
    ohreary
    ohreary Party!
    2020 Platinum
    First time towing my FD. No issues with transmission temps. 215F the whole trip and about 13MPG with the car on the trailer.
