More Locker Questions
Discussion in '1st Gen Tundras (2000-2006)' started by Wes_heppy, Apr 14, 2021.
  1. Apr 14, 2021 at 6:57 PM
    Wes_heppy
    Wes_heppy [OP] Trucks...Dirtbikes... Guns...
    Weston
    2003 tundra 4x4 4.7
    TC UCA Radflo coilovers Long Tubes LSD
    I have found out for sure that i have an LSD in my rear end, but as i do (or attempt) the rather gnarly Jeep trails in my area i want a locker. I think the way to go is the Harrop e-locker, but i think i will go with a lunchbox (auburn, nitro, powertrax etc) because it is 1/3 the price and based on what pretty much everyone says, they work well. So as i was researching what one to get, i saw that most say “for open carrier” Will these still fit if i have a lsd? Can I just take out the factory lsd and proceed or what? Do i need a special one or does this type of locker not work for factory lsd rear ends? Thanks any help is appreciated!
  2. Apr 14, 2021 at 7:23 PM
    KarmaKannon
    KarmaKannon Master of None
    Utah
    2006 Double Cab w/long travel
    Some junk
    Likely need an open diff third member to install it. They usually aren't joking when they say it doesn't fit an lsd carrier.
    Shouldn't need any special tools. The couple that I've done just required fitting the parts together until you find the angle of the dangle and cram it all in. A vice would be a big help and a torque wrench too. Then again I don't really remember the toyota pickup lunchbox locker I did so maybe it required something and I just blocked all memories. The d44 and Ford 8.8 I did were easy peasy.
  3. Apr 14, 2021 at 7:23 PM
    assassin10000
    assassin10000 New Member
    Andrew
    Northern CA
    '05 SR5 AC 2wd
    You will need an 'open' diff carrier to use that style. The one with visible spider gears.
    They do NOT fit into LSD rear end carriers.
  4. Apr 14, 2021 at 8:36 PM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    Everybody beat me to it and they are correct.
  5. Apr 14, 2021 at 8:52 PM
    Wes_heppy
    Weston
    2003 tundra 4x4 4.7
    Alright thanks for the in-tell. Replies are appreciated. Well, I guess no locker for me! Should i somehow acquire the funds, the Harrop e locker works with lsd right?
  6. Apr 15, 2021 at 3:05 AM
    KarmaKannon
    Utah
    Some junk
    Harris replaces the carrie so it shouldn't matter what you had in before that. You could always try to find an open diff third member. Might even get one cheap that has the same gear ratio as you currently have.
    des2mtn likes this.
  7. Apr 16, 2021 at 7:34 AM
    Wes_heppy
    Weston
    2003 tundra 4x4 4.7
    Would it be a good idea to buy a locker for the front diff because it is open? (Just a lunchbox locker that is) Or is that a bad idea for some reason?
  8. Apr 16, 2021 at 10:57 AM
    KarmaKannon
    Utah
    Some junk
    There was just a thread on that subject. I'm not familiar with the strengths of the front diff and axles in comparison to the spider gears. If the spiders are the weak link then a lunchbox locker might make sense. Your street driving also matters. Maybe driving in the snow with a front locker isn't a good idea and maybe it is. Maybe driving slow in snow with a front locker is alright.
    Voss and Darkness like this.
  9. Apr 16, 2021 at 11:02 AM
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
  10. Apr 17, 2021 at 8:46 AM
    Voss
    Voss Not a new member
    2003 AC TRD 4x4
    An auto locker sure sounded good to me at first. May still be a decent option solely based on the one member who had them without issue.
    I ended up with a Eaton selectable locker in front. One thing that just hit me... does a selectable locker also replace the spider gears like the auto lockers do?...
  11. Apr 17, 2021 at 9:21 AM
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    Yup. Its a whole carrier, your gear and (new?)bearings will be moved to the new carrier and that gets rid of the spiders.
  12. Apr 17, 2021 at 9:39 AM
    Voss
    2003 AC TRD 4x4
    Sweet thanks
