[NOW CLOSED] APRIL GROUP BUY - TeraFlex Falcon Sport Tow/Haul 2.25" Leveling Kit - Tundra
Discussion in 'Deals & Group Buys' started by French Avocado, Apr 1, 2021.
Thread Status:
Not open for further replies.
  1. Apr 15, 2021 at 6:16 PM
    #331
    Tundra-in-Cement
    Tundra-in-Cement Truck Chump
    2021 Tundra CM-OR
    Scanguage-II, Decked Systems, Leitner Rack, CaliLED lights, Firestone Air Bags, Trans-cooler kit, 2017 Pro grille and bulge, S-Tech 6 way switch, Corse Evo Darks w/ Stock Tires, 17-inch Alpha Equip Delta w/ Wildpeaks, Falcon Suspension, Coachbuilder +1 Shackle, Valhalla Cat Protectors.
    French Avo: I am just starting to think about the spring swap. I have done spring work on sports cars but never a truck. I am thinking of having a shop do it rather than trust a rental tool. Don't want to have a mishap. I do have Coachbuilder CB+1 shackles and still undecided if I will install those. Most likely I will. I am really glad that the shipment is delayed. I just don't have the time right now and it would eat away at me if they were sitting in the garage. I am on the wait list for some SCS wheels, and whenever those become available (in the next 10 years), I will be looking for some tires also.
    GODZILLA and French Avocado[OP] like this.
  2. Apr 15, 2021 at 6:17 PM
    #332
    French Avocado
    French Avocado [OP] Double Entundra
    Utah / Wyo
    Thanks. I am converting from 20" because I want the BBS forged wheels - making it a "Platinum Pro". Your suggestions are insightful and helpful. I will not be doing crazy off-road driving but some. Your list left off the strain on the vehicle gear boxes and the need to re-gear if you go big. I am fine with the 275 width but was thinking of going to the 70s instead of the stock 65s just to add an inch to fill the giant wheel wells a little and only slightly tempted by the 285/70s for that same reason.
  3. Apr 15, 2021 at 6:25 PM
    #333
    French Avocado
    Utah / Wyo
    With a spring rate of 700 #/in that is a LOT of pent up energy and if the tool pops then you might too. 4 Wheel Parts told me $260 to remove two springs which is ridiculously high. I get the impression that they do not want to do work for others. I got a second quote from a small independent shop for $36 per coil for each removal/installation. I can live with $72.
  4. Apr 15, 2021 at 6:28 PM
    #334
    Black
    2014 Tundra Limited CrewMax
    I had 275/70/18 Falken Wildpeak (awesome tire for the most part) that I pulled off my Expedition when I sold it for my Tundra and was going to use those. I had planned to buy an SR5 but a nice Limited popped up.
    Should have bought 18” wheels and sold the 20s but I bought 20” tires 275/60/20s essentially the 275/70/18 equivalent. I miss the extra sidewall did not really think I would.
  5. Apr 15, 2021 at 6:30 PM
    #335
    Tundra-in-Cement
    2021 Tundra CM-OR
    I could live with that too.
  6. Apr 15, 2021 at 6:33 PM
    #336
    Tundra-in-Cement
    2021 Tundra CM-OR
    Hey @Black, what did you decide on your CB+1, diff drop, and sway bar relocation? BTW, where did you get the sway relocation?
  7. Apr 15, 2021 at 6:35 PM
    #337
    French Avocado
    Utah / Wyo
    Do you have to relocate the rear sway bar with the Falcons?
  8. Apr 15, 2021 at 6:54 PM
    #338
    Black
    I did the sway bar relocation it was cake.
    Got it on Amazon.
    Readylift 67-5008 Sway Bar Drop Bracket https://smile.amazon.com/dp/B00IOYV..._glt_fabc_XHAN04E7VYXWT8ZZV3G1?_encoding=UTF8
    CB +1s will go on when ever I get a chance.
    I spent about 30 minutes trying to figure out how on earth I would get the drivers side nut back on when installing the diff drop.
    My time is limited and I did not want to risk not being able to get it back on. So I said screw it.
    With this kit the CV angles aren’t bad and I don’t see much of an issue coming from not installing it.
    If I loose a CV guess I’ll take the opportunity to upgrade and then will add the diff drop.
    Skid plates were the first thing I ordered for this truck back in June (though arrived in September) and really wanted to get them on.
  9. Apr 15, 2021 at 6:55 PM
    #339
    Black
    No. But I wanted to be sure I have as much articulation as possible.
    So for $40 and a super easy install seemed like a no brainer.
  10. Apr 23, 2021 at 3:17 AM
    #340
    1UP
    1UP Truck Gang
    2019 Red CM TRD sport 4x4
    My order should show up 4/26. That was very quick.
    Dsptundra, GODZILLA and Asimov2025 like this.
  11. Apr 23, 2021 at 5:09 AM
    #341
    18" TRD Off Road Wheels
    That's awesome!
  12. Apr 23, 2021 at 7:48 AM
    #342
    French Avocado
    Utah / Wyo
    Fabulous - did Stage 3 send you a shipping confirmation?
  13. Apr 23, 2021 at 9:00 AM
    #343
    1UP
    1UP Truck Gang
    Yup
  14. Apr 23, 2021 at 6:56 PM
    #344
    cain0725
    cain0725 New Member
    any reviews a d pics ?
  15. Apr 23, 2021 at 6:58 PM
    #345
    Black
    GODZILLA likes this.
  16. Apr 27, 2021 at 3:14 PM
    #346
    Taco-Blender
    Taco-Blender Old Guys Rule
    AZ
    2010 DC 4x4
    Saw this on the "Pay it forward" thread.
    I'd you're in SoCal and need springs for your Falcons you may want to give him a shout.
    LarryDangerfield and GODZILLA like this.
  17. Apr 27, 2021 at 3:16 PM
    #347
    1UP
    1UP Truck Gang
    Mine showed up yesterday. Will be a few weeks before I install.
    HulkSmurf14 and RobertD like this.
  18. Apr 27, 2021 at 3:33 PM
    #348
    French Avocado
    Utah / Wyo
    Those are leafs not coils. Folks get an extra set of coils for the Falcons.
    EDIT - I now see there is also a set of coilovers.
  19. Apr 27, 2021 at 3:35 PM
    #349
    French Avocado
    Utah / Wyo
    Fabulous and unbelievable. Don't know how you ended up number one but you really 1upped us. Anxious to hear when you get them installed.
    HulkSmurf14, RobertD and GODZILLA like this.
  20. Apr 27, 2021 at 3:59 PM
    #350
    Dsptundra
    Austin TX Area
    2021 Silver Limited CM
    Pics?
  21. Apr 27, 2021 at 4:14 PM
    #351
    1UP
    1UP Truck Gang
    KnoxHog22, The Dude, SR5BRAH and 7 others like this.
  22. Apr 27, 2021 at 4:15 PM
    #352
    Dsptundra
    Austin TX Area
    Nice!:bowdown:
    HulkSmurf14 and LarryDangerfield like this.
  23. Apr 27, 2021 at 7:49 PM
    #353
    RobertD
    Robert
    DFW, Texas
    HulkSmurf14 likes this.
  24. Apr 28, 2021 at 11:32 AM
    #354
    SR5BRAH
    SR5BRAH New Member
    2020 Cement TUNDRA TRD OFF-ROAD PLUS
    JBA OFF-ROAD UCA, 3/1.5" 6112/5160, 33" TOYO C/T, KATZKIN'S LEATHER w/seat heaters, 4 JL C3'S, 2 JL 10W1V3-4, KAPPA FIVE amp, Tacotunes add an amp harness, LED's through out, OEM tow mirrors, BSM indicator relocated,
    That's awesome you got them already. If you can, can you take some shock length measurements from middle of eye to stem middle (approx)? Thanks
  25. Apr 28, 2021 at 10:05 PM
    #355
    1UP
    1UP Truck Gang
    SR5BRAH[QUOTED] likes this.
  26. Apr 29, 2021 at 4:33 AM
    #356
    1UP
    1UP Truck Gang
    Not quite sure what exactly your asking for but hopefully these and my other pic help.
    RobertD, akmerle and SR5BRAH[QUOTED] like this.
  27. Apr 29, 2021 at 9:16 AM
    #357
    SR5BRAH
    SR5BRAH New Member
    Thanks for opening them back up to get the dimensions for me. I’ll use to compare with my 6112’s/5160’s set up. Rears look like they’re longer than 5160s
    1UP likes this.
  28. Apr 30, 2021 at 10:23 AM
    #358
    FlipStyle54
    FlipStyle54 New Member
    Randolph
    2008 White Tundra TRD
    I definitely saw this too late. If there happens to be an extension or someone backs out. PM me @French Avocado
  29. May 2, 2021 at 10:21 PM
    #359
    French Avocado
    Utah / Wyo
    Might be a round two in the fall.
    Navi, KnoxHog22 and AggiePhil like this.
  30. May 3, 2021 at 5:43 AM
    #360
    FlipStyle54
    Randolph
    Awesome. Thanks for the update
Thread Status:
