Which rims to get for my 2021 Tundra TRD Sport Premium (20")?
Discussion in 'Wheels & Tires' started by AlohaTundra22, Apr 15, 2021.
  1. Apr 15, 2021 at 10:27 AM
    AlohaTundra22
    AlohaTundra22 [OP] New Member
    Hi All - I am picking up an all black TRD Sport Premium on Saturday and want to online order a set of black matte rims to go with it. What should I be looking for when selecting the wheels?
    The website CanadaWheels.ca asks for PCD, Diameter, Width, Min. Bore, Min. Offset, Max Offset -> I dont know anything about wheels other than my Sport comes with 20" wheels.
    Are there brands that I should look for that are better than others? I appreciate the help here since I am a complete truck and wheel newbie.
  2. Apr 15, 2021 at 10:39 AM
    TexAggie
    TexAggie New Member
    Eric
    2017 CM
  3. Apr 15, 2021 at 11:54 AM
    frichco228
    frichco228 Valued Member
    Frank
    Virginia
    2016 Crewmax 4WD, TRD Offroad
    You could just have your stock rims powder coated or painted black and be done with it.
  4. Apr 15, 2021 at 11:58 AM
    cctxquicksand
    cctxquicksand IG - TRDistheWrd
    There are a lot of options but it sounds like all you have made up your mind is with the color.
    Next I’d be thinking size you want to go with, followed by offset and tires size. There are several threads on there about wheel size and offset, check out the tire and wheel section of this forum. Also customoffsets.com has a rather larger photo gallery you can use as a reference. Good luck.
