What do you TOW with your Tundra?
Discussion in 'Towing & Hauling' started by T-Rex266, Jan 29, 2014.
  1. Apr 14, 2021 at 1:52 PM
    #2671
    degs
    degs New Member
    2020 MGM Crewmax
    Thanks man, really. I owe you a beer for helping calm me down.
  2. Apr 14, 2021 at 1:54 PM
    #2672
    StrandedInIowa
    StrandedInIowa New Member
    2021 Cement Tundra Limited
    Total newbie question, just got my Tundra Saturday. Heading to pick up my boat soon, do I need to use S4? What about Tow/Haul mode?
    Prostar 190 and Njmike13 like this.
  3. Apr 14, 2021 at 1:59 PM
    #2673
    Jtundra81
    Jtundra81 Just a member
    Joe
    2019 cement tundra crewmax
    When towing , always keep it on s4 with tow haul on .
    Keep it between 55 and 60 mph and you will be fine .
    S4 with the higher rpm will keep torque c locked most of the time and provide higher cooler circulation to the what is called warmer / cooler .
    I tow 4000lb travel trailer and manage to keep my temps around 215 on pan average .
  4. Apr 14, 2021 at 2:00 PM
    #2674
    frichco228
    frichco228 Valued Member
    Frank
    Virginia
    2016 Crewmax 4WD, TRD Offroad
    Yes, read your manual- towing is covered there. S4 or S5 will help keep the trans locked up so you are not gear hunting and generating extra heat. Your 2021 does not have a trans cooler. Should be no problem to tow that boat, that Tritoon and trailer would weigh about 5500lbs, well within what your truck and handle. Just take it easy, 65MPH or less. If you do a lot of towing, consider adding a trans cooler. Lots written about that here, just search upper right.
  5. Apr 14, 2021 at 2:03 PM
    #2675
    szabo101
    szabo101 New Member
    ED
    2018 MGM Platinum 4WD
    Your door sticker says 7000lbs towing capacity on a 2020? Is that Gross Vehicle Weight Rating (GVWR)? I thought the lowest towing capacity on any 2020 Crewmax was 8,800lbs. And my 2018 sticker does not show towing capacity on it anywhere.
  6. Apr 14, 2021 at 2:19 PM
    #2676
    frichco228
    Frank
    Virginia
    All you need to do is pay attention to your payload numbers. If you are within the payload- passengers, gear, hitch weight all combined, you can tow it. Your available payload for your particular truck is on the sticker in drivers door.
    Sure you can go over payload and the truck will pull it, but there some considerations and I will not go into the deep hole about all that. With towing- Can and should are two different things.
    Check out the stickies in the tow forum here, is some good info about towing, payload, etc.
  7. Apr 14, 2021 at 2:37 PM
    #2677
    Catmann1972
    Catmann1972 New Member
    Greg
    Rhode Island
    2020 TRD Sport
    So, open your owners manual to the capacity section. There is a vehicle code on your door sticker. Use that code on the sticker and compare it to what is in the manual. That code will tell you tow capacity, and cargo weight. Thats it, it's that easy.
  8. Apr 14, 2021 at 3:44 PM
    #2678
    SchnauzerMan
    SchnauzerMan New Member
    Southern New Mexico
    2019 SR5 CM 4x4
    Sumo Struts, Tiger Steps, Bed Rug, Undercover Flex Hard Folding Tonneau Cover
    First thing is to never believe a salesman - always verify. A few know, but many don't, and some just lie.
    Two things you need to look at:
    GCWR for your truck, less cargo and passengers is your towing capacity.
    GVWR, less the actual weight of your truck and everything in it, is your cargo capacity. Many people completely ignore this one.
    Your truck probably has a cargo capacity of around 1,200 lb. It's real easy to get 1,000 lb of people and cargo in your truck before you even hook up your trailer, and then if your hitch weight is over 200 lb, you've already exceeded the cargo capacity your truck, and no tires, struts, air bags, etc can change that. On top of all that, you should ensure that your tongue weight is 10%-15% of total trailer weight for stability.
    Cpl_Punishment and degs[QUOTED] like this.
  9. Apr 15, 2021 at 4:39 AM
    #2679
    Jtundra81
    Joe
    lot of threads implies that payload capacity includes 150 lb driver and full tank of fuel .
    I am positive about the full tank of fuel but not so sure about the driver
  10. Apr 15, 2021 at 6:15 AM
    #2680
    Melikeymy beer
    Melikeymy beer No cooler for you!
    Muscogee Nation
    2019 Platypus Tundra
    A trucks GVWR minus the weight of the unloaded, unoccupied truck with a full gas tank will equal your payload. Simple as that. The standard driver weight is used to determine towing capacity, not payload. It's super easy to drive on the scales and confirm this.
    Now someone please post a picture of your trailer or boat so we can get back on topic, lol.
    D3Tundra, BGoodiE, degs and 3 others like this.
  11. Apr 15, 2021 at 6:26 AM
    #2681
    eick
    eick New Member
    2020 CrewMax TRD Off Road
    I'm not so sure of finding a 150lb driver.....I haven't weighed 150lb since high school
    Branden likes this.
  12. Apr 15, 2021 at 6:50 AM
    #2682
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    We don't own a scale so I'm going to keep thinking I still weigh 140 until proven otherwise. :D
    BGoodiE, Jtundra81 and eick[QUOTED] like this.
  13. Apr 15, 2021 at 6:51 AM
    #2683
    Jtundra81
    Joe
    That’s the spirit
  14. Apr 15, 2021 at 6:57 AM
    #2684
    Jtundra81
    Joe
    Here’s mine , not totally leveled , got a gen-y drop hitch, will be testing it soon
  15. Apr 15, 2021 at 8:14 AM
    #2685
    Melikeymy beer
    Muscogee Nation
    I kinda want one of those tent canopies. How much time/trouble is it to set up? Can I do it alone?
    Jtundra81[QUOTED] likes this.
  16. Apr 15, 2021 at 8:21 AM
    #2686
    Jtundra81
    Joe
    These are awesome , takes 5 min with me and the wife to put it together , you can do it alone but it is much easier with 2 persons . I believe I payed 60 for it and an additional 25 for the net , got it form job lot , totally worth it especially on those rainy days
  17. Apr 15, 2021 at 8:23 AM
    #2687
    degs
    degs New Member
    2020 MGM Crewmax
    Well, since I started the derailment... Here's the new one that caused it all... Keystone Hideout 27RLS
  18. Apr 15, 2021 at 8:50 AM
    #2688
    Nightshade Tundra
    Nightshade Tundra New Member
    Alex
    2021 Ram 2500 Laramie
    Nice trailer man, how long is it?
    degs[QUOTED] likes this.
  19. Apr 15, 2021 at 9:06 AM
    #2689
    degs
    degs New Member
    2020 MGM Crewmax
    Thanks! 31' 11" total. It has a killer layout inside. We traded in one with bunk beds because the kiddos never slept in them.
    https://my.matterport.com/show/?m=9rBadxVM8C1
  20. Apr 15, 2021 at 9:27 AM
    #2690
    knoxville36
    knoxville36 New Member
    Knoxville, TN
    2024 GMC Sierra 1500 Elevation w/3.0 Duramax
    Just curious of what sleeping arrangements you have for the kids in that layout?
  21. Apr 15, 2021 at 9:28 AM
    #2691
    degs
    degs New Member
    2020 MGM Crewmax
    The sofa turns into a bed, as well as the dinette. There's also plenty of room to put down an air mattress if needed. (or with us of course, they're still little)
    Jtundra81 likes this.
  22. Apr 15, 2021 at 9:38 AM
    #2692
    Jtundra81
    Joe
    Got the drop hitch , should get the trailer leveled
    Explorer, Nightshade Tundra and degs like this.
  23. Apr 15, 2021 at 10:51 AM
    #2693
    Red Dragon
    Red Dragon New Member
    Pocatello, Idaho
    2015 Barcelona Red Limited TRD
  24. Apr 15, 2021 at 5:01 PM
    #2694
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    stupid question, but wouldn’t it be better to get a hitch shank with more adjustment for the WD hitch as opposed to the separate attachment?
  25. Apr 15, 2021 at 5:05 PM
    #2695
    Jtundra81
    Joe
    Yes ,but I got another utility trailer that I will be also using the drop down hitch for , was cheaper for me
    YeeYeeTundra and Hbjeff[QUOTED] like this.
  26. Apr 15, 2021 at 6:08 PM
    #2696
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    My TT has such a short tongue one of those would be a benefit to get more clearance for the bikes hanging off the back of the truck!
    Jtundra81 and WAtundra4x4 like this.
  27. Apr 15, 2021 at 6:37 PM
    #2697
    Mad Max
    Mad Max New Member
    Max
    2021 Tundra Limited
    If you tow in s6 and 75 mph your torque converter will stay locked as your rpm are up. I seen huge trailers in this thread towing 70 mph then I see stay under 60 and S4. you will get run over at those speeds, pull at 65-75 and roll on.
  28. Apr 15, 2021 at 6:37 PM
    #2698
    greggm
    greggm New Member
    Gregg
    Los Gatos, CA
    2019 CM TRD 4x4
    I just picked up my new Rockwood Mini Lite 2403KS last weekend its specs are 4600lbs dry, 6600lbs max, I had added Firestone airbags and found that I really didn't need them with the included weight distribution hitch she towed like a beauty. Now to load it up with 1900lbs of junk and try again!
    TOYOTARIG, degs, jtwags and 8 others like this.
  29. Apr 15, 2021 at 7:00 PM
    #2699
    Jtundra81
    Joe
    To each their own , 55 - 60 mph is how I tow especially when I have my kids with me.
    I believe I have a far better chance stopping should anything come up , I prefer to get where I am headed 20 min later then not getting there at all.
  30. Apr 15, 2021 at 7:13 PM
    #2700
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    The owner's manual says not to exceed 65 when towing.
