Excited then Unexcited .....
Discussion in '2.5 Gen Tundras (2014-2021)' started by geno0506, Apr 4, 2017.
  1. Apr 11, 2017 at 10:41 AM
    #121
    geno0506
    geno0506 [OP] New Member
    Michael
    Made my day,
    LMMFAO thanks joonbug
  2. Apr 11, 2017 at 12:43 PM
    #122
    geno0506
    Michael
    For %$#%'s sake, I cant get the LCA CAM bolts loose to drop the LCA?
    I have an old sears phonemic air impact wrench Guess I'll try, also can I spray that break free lubricant there or is that a no no!
    GNTundra likes this.
  3. Apr 11, 2017 at 1:00 PM
    #123
    FlashCulprit
    FlashCulprit ColoradoTJ's whipping boy/Gino's illegitimate son.
    Joe
    Salt Lake City, UT
    2010 Super White SR5 TRD 5.7 4x4
    You shouldn't need to break the LCA Cam bolts... Try putting a pry bar in the LCA and pulling down to make clearance. You can use PB/Liquid Wrench etc no problem on it if you are pulling it out.
  4. Apr 11, 2017 at 1:07 PM
    #124
    geno0506
    Michael
    thanks, so those cam bolts don't need loosened on the LCA, just spray them and use pry bar! Its ok that I loosened and tightened them on the 1st one right?
  5. Apr 11, 2017 at 1:10 PM
    #125
    FlashCulprit
    Joe
    Salt Lake City, UT
    Yes. Just make sure that you tell the shop when you go in for alignment.
    You shouldn't even need to PB the LCA bolts honestly. It's just extra alignment work if they are loosened.
  6. Apr 11, 2017 at 1:15 PM
    #126
    geno0506
    Michael
    Thanks for the tips, waiting on the rain to stop then back to the grind, :frusty:
  7. Apr 11, 2017 at 1:25 PM
    #127
    FlashCulprit
    Joe
    Salt Lake City, UT
    If you are still having issues with getting the strut to fit into the strut tower remove the top bolt from the top ball joint so the Upper and lower control arms are not connected. This will cause the lower to drop significantly though so be prepared to catch and prop it up so you don't put strain on your CV's or tie rods.
  8. Apr 11, 2017 at 3:03 PM
    #128
    J4RR3N4
    J4RR3N4 New Member
    South east Texas
    14 Tundra
    3” lift on 35’s
  9. Apr 11, 2017 at 4:53 PM
    #129
    geno0506
    Michael
    OK,
    We have a BINGO, crossed the finish line about a hour ago! So much prying with the bar, didnt even have to loosen the LCA cam bolt, I tried but wouldn't budge! I put a long pry bar and sat on it while I finagle all the bolts and 6112 in! Was better then yesterday, just that I used muscles I hadn't in years and even my hair hurts, lol!
    Had to make a temporary cover to work in the rain!17800292_10211972509326658_5614717668701216682_n.jpg17883537_10211972507846621_6724200877838361076_n.jpg17883719_10211972508766644_589149990660094363_n.jpg17884035_10211972509566664_8426761095703186460_n.jpg17903493_10211972508246631_6791510582268986928_n.jpg
    My shoulder feels like it was beating with a bat! Any way, I'll take it in tomorrow and get the alinement and have the check the drivers side UCA CAM bolts I loosened and the service manager I knew from a past dealer that used to work on my 2010, he said once I finished bring it in for a aliment and he'll have them check the torques!
    Ill do the 5160's and CB #2 shackle later this week and I'll just get it realigned once I get the new tires! I'm hoping the #2 shackles don't give me a big rake being I want no more then 3/4" rake rear, minimum but traction control still stays happy!
    thanks every one for you big help, been an inspiration and great knowledge form you all!
    1UPPER, GNTundra, Newm and 5 others like this.
  10. Apr 11, 2017 at 5:01 PM
    #130
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
  11. Apr 11, 2017 at 5:01 PM
    #131
    BlueFalconActual
    BlueFalconActual Field Day Inspector Extraordinaire
    Kevin
    29 Palms, CA
    Tundra-less
    SWEET! Good job brother! Man, that beastly coilover looks so much better in there
    GNTundra and geno0506[OP] like this.
  12. Apr 11, 2017 at 5:03 PM
    #132
    geno0506
    Michael
    LMMFAO, love it!
  13. Apr 11, 2017 at 5:04 PM
    #133
    geno0506
    Michael
    Thanks, they do look sweet!
  14. Apr 11, 2017 at 5:10 PM
    #134
    Voyagermike
    Voyagermike New Member
    California
    Awesome job! Looks great! :thumbsup: :thumbsup:
  15. Apr 11, 2017 at 5:10 PM
    #135
    geno0506
    Michael
    Thanks J4,
    I did do it!
  16. Apr 11, 2017 at 5:13 PM
    #136
    FlashCulprit
    Joe
    Salt Lake City, UT
    Probably should have mentioned how much easier it would have been with 2 peeps. haha But yeah. Taking out the LCA is unnecessary. Glad to see you got it in.
  17. Apr 11, 2017 at 5:18 PM
    #137
    geno0506
    Michael
    I meant loosen the LCA not take off but still worked without loosening the bolts, sat on the pry bar, lol As of 2 people, I'm kinda stubborn and finicky about that, lol!
  18. Apr 11, 2017 at 5:28 PM
    #138
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    Good work man. Always good to see someone saving money by doing it themselves.
  19. Apr 11, 2017 at 5:29 PM
    #139
    FlashCulprit
    Joe
    Salt Lake City, UT
    Agreed. Plus it's always cool to look back at your work when it's finished and say "damn I is good!".
  20. Apr 11, 2017 at 5:30 PM
    #140
    CM-LENNY
    CM-LENNY No Complaints
    San Diego, CA
    2015 4x4 CrewMax SR5
    PRO shocks, 37's Nitto G2's 4:88 diffs, few other mods
    Glad you got everything done on the front end ! Kinda strange those LCA bolts were that tight. You can sometimes get turned around when under the truck. You were doing lefty lucy righty tighty, correct ? Just checking........Also you have to look at what bolt or nut you are on because one comes loose and the other moves the cam. Also when you get a chance after alignment and before the rear work, let me know what you got for lift up front. This needs to be done after alignment because of the angle of the tire after lift. Thanks Geno and post some pics when it stops raining......
  21. Apr 11, 2017 at 5:39 PM
    #141
    MotoTundra
    MotoTundra The Ocho
    Don
    Great job!
  22. Apr 11, 2017 at 5:42 PM
    #142
    geno0506
    Michael
    thanks csuviper!
  23. Apr 11, 2017 at 5:45 PM
    #143
    geno0506
    Michael
    this is me when finished
    thanks and will do!
  24. Apr 11, 2017 at 7:47 PM
    #144
    Joeshaker
    Joeshaker New Member
    Amado
    Evergreen, Co
    13 dcsb trd4x4
    Bilstein 6112/5160 trd sway bar and ride rite bags. Black and burnt orange wet okole seat covers.
    You enjoying the show Joon? That dude's got some ears on him!
  25. Apr 11, 2017 at 8:57 PM
    #145
    J4RR3N4
    J4RR3N4 New Member
    South east Texas
    14 Tundra
    3” lift on 35’s
    Can't wait to see it on all 4's
  26. Apr 12, 2017 at 4:09 PM
    #146
    geno0506
    Michael
    DAY 2, Bilstein 5160 install
    I just finished the 6112's and 5160, did it in 2 days but took my time, came out great love the drive! I'll take in for the alinement next! I drove yesterday an it drove straight with no pulling right or left!
    The front appears about 1" higher then rear but I heard the front will settle and drop a bit!
    I still haven't done the #2 shackles but I have them just thinking wether I want to add them, I won't be towing or heavy hauling but still on the fence! But if it would help over all I would add them but don't know if CB #1, 0.65" lift may be closer to a minimal rake instead of the #2's which say 1.25" lift rear!
    now that I look at the 5160 install, I think I put the res on the wrong side, does it make a difference and if so do I have to take them all off again, :frusty: As it is now the res seems right at touching the frame hump where the shock top fit in, are these right and left specific shocks!
    17904231_10211982058965393_675107499647918599_n.jpg 17904349_10211982058365378_4909944904501937906_n.jpg 17883541_10211982060205424_656927925719728987_n.jpg 17884393_10211982059405404_5174758555037365946_n.jpg :burnrubber:
    J4RR3N4, 1UPPER and GNTundra like this.
  27. Apr 12, 2017 at 4:12 PM
    #147
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    Good job my man!!!! But it won't settle a whole inch. And isn't the rear shocks made for a certain height? Either with or without shackles, but not both?
  28. Apr 12, 2017 at 4:38 PM
    #148
    geno0506
    Michael
    Thanks
    I just realized the instructions on the 5160's say to mount the reservoir on drivers side and the rev on the pax side facing rear, damn it! I wonder if I have to take the shocks off or could I just loosen the top nut and twist the main shock and rev the other way, I think the hose and fittings have play and will twist, just want to do it right!
  29. Apr 12, 2017 at 4:55 PM
    #149
    CM-LENNY
    San Diego, CA
    Great job Geno..........The front will settle down once you get it aligned. I would wait and see where it sits before tackling the rear shackles. The rear shocks have a swivel banjo fitting on them. They are designed to allow you to remote mount the reservoir just about any where. Just don't kink the hose. Hope this helps........
  30. Apr 12, 2017 at 5:11 PM
    #150
    Joeshaker
    Amado
    Evergreen, Co
    13 dcsb trd4x4
    What Lenny said! As long as the hose doesn't kink and nothing is close enough to make contact, you can mount them however you want. Looking good!
