2020 LandCruiser comes with transmission cooler, why not Tundra?
Discussion in '2.5 Gen Tundras (2014-2021)' started by sabet, Mar 14, 2021.
  1. Apr 11, 2021 at 9:20 AM
    #271
    Worthy of today's internet trophy....
    Alex38 and hagrid like this.
  2. Apr 11, 2021 at 9:21 AM
    #272
    Mad Max
    Mad Max New Member
    Max
    2021 Tundra Limited
    Article I read #1 vehicle or highest percentage making it to 300k miles. It was Landcruiser. Cooler must contribute to that success.
  3. Apr 11, 2021 at 9:40 AM
    #273
    Terndrerrr
    Terndrerrr 923000 miles to go
    Music City
    6UR-FE
    I love my truck. I don’t regret my purchase, and I don’t regret installing a cooler to bring it to 2018 specs. :notsure:
    I lean toward agreeing with the Toyota engineer who said it was a poor decision. I take the failed trucks Toyota has seen due to high trans temps as actual data points. I’m not emotional about it, and I’m not going to try to sue Toyota, but I do think we’ll see more issues down the road (likely after the 2019-2021 trucks’ warranties expire). For most, I'm sure it's fine. Toyota will fix the few that fail under warranty and still come out way ahead.
    A Toyota engineer who worked directly on the Tundra speaking candidly under the condition of anonymity carries more weight for me than one speaking in a public relations capacity on behalf of their employer. Others disagree. That's fine.
    In @blanchard7684's hypothetical legal situation, is there a slight chance that the prosecution could show that the puck is so ineffective based on its observed performance under the stress of higher (but within spec) loads that to call it a "cooler" in the same sense they called the previous system a cooler is intentionally misleading or negligent? I would think that case would have the best chance.
    At any rate, the highly emotional posts on both sides of the issue are entertaining.
  4. Apr 11, 2021 at 10:04 AM
    #274
    Roborob70
    Roborob70 New Member
    Robert
    18 Toyota Tundra TRD
    Damn skippy, too many whiners....buy an 18
  5. Apr 11, 2021 at 10:30 AM
    #275
    marshmellow
    marshmellow New Member
    San Diego
    2021 Toyota Tundra CM
    I don’t tow much (yet) but I do hang out in the deserts a lot and didn’t want to chance it. I’ll have this truck until I die so the setrab kit was worth it to me.
    Terndrerrr likes this.
  6. Jul 18, 2021 at 12:23 PM
    #276
    1UP
    1UP Truck Gang
    2019 Red CM TRD sport 4x4
    https://youtu.be/V7fJuunzC2g
    Worth noting what Ford is also doing. Only 2 coolers in their entire line up. Bet you can't guess both models.
  7. Jul 18, 2021 at 12:49 PM
    #277
    Clemsonman14
    Clemsonman14 New Member
    2020 SR5 Crewmax 4x2
    Also apparently they test at Davis Dam at 45 mph
