DC Fold Down Rear Seats
Discussion in '2nd Gen Tundras (2007-2013)' started by JMB, Aug 4, 2014.
Which do you prefer?
  1. Cut
    37 vote(s)
    48.7%
  2. Bend
    32 vote(s)
    42.1%
  3. Tastes Great
    16 vote(s)
    21.1%
  4. Less Filling
    9 vote(s)
    11.8%
Multiple votes are allowed.
  1. Apr 9, 2021 at 5:30 AM
    #181
    619Tundra
    619Tundra New Member
    San Diego, Caifornia
    2017 Black Tundra Double Cab SR5
    Your whole truck is bent metal.
    gacosta153 and Jeff_1974 like this.
  2. Apr 9, 2021 at 5:31 AM
    #182
    619Tundra
    Can you post a pic?
  3. Apr 9, 2021 at 5:37 AM
    #183
    I'll take one this afternoon.
    619Tundra[QUOTED] likes this.
  4. Apr 9, 2021 at 5:37 AM
    #184
    619Tundra
  5. Apr 9, 2021 at 10:54 AM
    #185
    Toyoman2
    Toyoman2 New Member
    I bent and cut. Works perfect!
    Drainbung[QUOTED] likes this.
  6. Apr 9, 2021 at 10:59 AM
    #186
    Barrett50
    Barrett50 New Member
    Barrett
    Wisco
    2015 DC silver
    Why both? Can you explain?
  7. Apr 9, 2021 at 11:00 AM
    #187
    JMB
    JMB [OP] Not new, just a little old.
    Chesapeake, VA
    2013 Super White Tundra DC
    Understand, but it's fabricated in a controlled manner, ensuring no stress related damage.
    mtucker and Drainbung like this.
  8. Apr 9, 2021 at 11:36 AM
    #188
    Drainbung
    Drainbung Some days you are the show...
    Bob
    Oasis of NV
    2019 Cement DCLB 4X4
    TRD Fleshlight
  9. Apr 9, 2021 at 11:43 AM
    #189
    Barrett50
    Barrett
    Wisco
    2015 DC silver
    Yeah, trying to decide myself. Or shim. Where does a sub sound best under the back seat or behind? Any opinions welcome.
  10. Apr 9, 2021 at 12:24 PM
    #190
    JMB
    Chesapeake, VA
    Added.
  11. Apr 9, 2021 at 12:38 PM
    #191
    Barrett50
    Barrett
    Wisco
    2015 DC silver
    I'm thinking about going this route to fit a sub under the seat. Any issues since you've shimmed up an inch? Anything you'd do different? Thanks
  12. Apr 9, 2021 at 2:30 PM
    #192
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    Problem with bending the hooks is it causes the seats to recline back just a little. And then the sliding glass hits the headrest. Not so bad if you have a manual slider as you can pull on the headrest and get the window open. But it doesn’t work if you have a power slider. I cut on my first truck. Bent on my second truck. Then had to bend them back and cut again.
  13. Apr 10, 2021 at 5:47 AM
    #193
    Barrett50
    Barrett
    Wisco
    2015 DC silver
    How did you raise the back part of the seat and still bolt it to the back wall? Mine has one tapped hole and if I raise it, it obviously won’t match up anymore. I’m trying to get more clearance for a sub like you mentioned.
    619Tundra likes this.
  14. Apr 10, 2021 at 4:04 PM
    #194
    Toyoman2
    Toyoman2 New Member
    Just tried to meet in the middle with both. A little more work, but I made the time. I'm very happy with the mod.
    Barrett50[QUOTED] likes this.
  15. Apr 10, 2021 at 4:08 PM
    #195
    Barrett50
    Barrett
    Wisco
    2015 DC silver
    Thanks for the reply. I’m in the process now. Looks like shimming a little and bending a little is gonna work for me. Need a little more room to put a sub under the seat.
  16. Apr 11, 2021 at 6:23 AM
    #196
    619Tundra
    Can you post pics? Thanks.
  17. Apr 11, 2021 at 6:30 AM
    #197
    Barrett50
    Barrett
    Wisco
    2015 DC silver
    I can when the rain breaks. I used a piece of metal I had laying around and some washers to shim. About an inch worth and I was able to line up the back to original holes. I gained about 2” underneath. I banged on the U rings a few times with a rubber mallet so they moved down maybe 1/4” so the seats will go forward. Did not cut the brackets cuz I only had to bend the U’s a tiny bit with it shimmed.
    I will say, like posted earlier, if I was to cut the brackets I would loosen the seats so they go forward and use a sawzall.
  18. Apr 11, 2021 at 6:34 AM
    #198
    619Tundra
    I need about 1" to clear my subs.
  19. Apr 11, 2021 at 7:02 AM
    #199
    Barrett50
    Barrett
    Wisco
    2015 DC silver
    The “shims” measure 7/8” and I gained about 2” underneath. I’m going to see how it works for a bit and then replace with a cut piece of steel or aluminum. A24FC057-5AAA-4C42-88F0-6F18C777652E.jpgB6E4FE8A-EB58-4D13-B030-A1FCA3D709E5.jpg
  20. Apr 11, 2021 at 7:04 AM
    #200
    Barrett50
    Barrett
    Wisco
    2015 DC silver
    First ones upside down obviously, sorry. Hard to get a pic and didn’t notice
  21. Apr 11, 2021 at 7:31 AM
    #201
    619Tundra
    So 7/8" will give 2" more clearance on the bottom?
  22. Apr 11, 2021 at 7:42 AM
    #202
    Barrett50
    Barrett
    Wisco
    2015 DC silver
    I just measured again, shims are more like 3/4”. Under the seat back to the jack mount is 6” to where it will touch upholstery. Front edge is now 7.5”. Not sure if pic helps but here ya go
  23. Apr 11, 2021 at 7:44 AM
    #203
    Barrett50
    Barrett
    Wisco
    2015 DC silver
    Upside down again sorry. Raining out.
  24. Apr 11, 2021 at 7:45 AM
    #204
    619Tundra
    Thanks for the pics. I know it's a pita to measure.
  25. Apr 11, 2021 at 7:56 AM
    #205
    Barrett50
    Barrett
    Wisco
    2015 DC silver
    No problem. Trying to do same as you, fit a sub and have bonus of seats going forward. Going to the shop tomorrow and see how one fits. I’ll keep you posted and let me know how yours goes.
    You’ll need longer bolts btw. Pretty sure they were M10x1.5 and 1.25” that I used and had plenty of thread engagement with the shim.
  26. Apr 12, 2021 at 8:40 PM
    #206
    Barrett50
    Barrett
    Wisco
    2015 DC silver
    Sub fit. Ended up cutting out the jack hold and laying carpet over it. I can measure the 10” sub enclosure tomorrow if it would help you. It would not have fit with jack holder.
  27. Apr 17, 2021 at 3:23 PM
    #207
    Brimaster
    Brimaster New Member
    2017 Magnetic Gray Metallic DC TRD
    Just did this mod this afternoon. It took a bit but all good. I went the remove the brackets and use cutting wheel and hand file for edge clean up. OP thanks for starting the thread and others for adding tips!! :cheers:
    MTRock likes this.
  28. Apr 17, 2021 at 5:32 PM
    #208
    MTRock
    MTRock 1889
    Montana
    2024 Tacoma TRD Off Road
    Katzkin Leather seats, JRI shocks, Rival aluminum skids, 285/70/17 outpost nat, Berger catch can, icon rear +.5 springs, gator trifold bed cover, Perry parts bump stops, switchback turn signals,
    https://www.tundras.com/threads/dc-10inch-sub-and-keep-under-seat-storage.81416/
    Seats still fold down..
  29. Apr 18, 2021 at 5:39 PM
    #209
    619Tundra
    How much for the ABS Panels?
  30. May 9, 2021 at 7:34 PM
    #210
    Aught16TSS
    Aught16TSS New Member
    J
    Tuckasee
    2016 TSS - Magnetic Gray Metallic
    Dual Flowmasters, hidden LEDs in hood bulge, 3.5" lift and Ridge Graps
    I did the bend on my 16 DC. Love it. Great mod for freesies!
    619Tundra and MTRock like this.
