2020 Differential needle bearing failure
Discussion in '2.5 Gen Tundras (2014-2021)' started by CreekDweller, Dec 30, 2020.
  1. Mar 21, 2021 at 8:38 AM
    #121
    rockmup
    rockmup New Member
    Todd
    Greenwell Springs LA.
    Kings, 5:29's, E-lockers on 37's
    I'd insist they send a rollback and deliver it when its done
  2. Mar 21, 2021 at 8:43 AM
    #122
    Ruggybuggy
    Ruggybuggy Seasoned Veteran
    Dave
    NW ON, CANADA
    2016 Tundra OR
    It should be the same on the Tacoma. It's design is identical but just smaller. The needle bearing is only used when the truck is in 2WD because the carrier is stationary and the CV axle is turning from tire rotation. In 4WD the carrier is rotating with the needle bearing and CV axle shaft so no noise.
    Edit... I stand corrected. The needle bearing on the Tacoma is installed in the diff housing and not the carrier. The noise would be the opposite of the Tundra.
  3. Mar 21, 2021 at 3:00 PM
    #123
    NWPirate
    NWPirate Tesla kool-aid connoisseur
    Zach
    WA
    2017 SR5 TRD CM 2004 TRD Snow Goat
    All good man, thanks for sharing your experiences.
    Ruggybuggy[QUOTED] likes this.
  4. Mar 24, 2021 at 12:36 PM
    #124
    Wallygator
    Yeah that is how it was in my 4Runner also.
  5. Mar 25, 2021 at 8:59 AM
    #125
    azTony
    azTony member since sept, 2017 and over 1,600 messages
    Tony
    Sun Lakes, AZ
    I have to pull my front diff so I am replacing the needle bearings with a better solution.
    Edit: The Harrop Elocker eliminates and replaces the faulty needle bearings so I am good
    Wallygator and Ruggybuggy like this.
  6. Mar 25, 2021 at 9:37 AM
    #126
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    Yup, that will fix it permanently.
  7. Mar 25, 2021 at 11:43 AM
    #127
    CreekDweller
    CreekDweller [OP] Not so new ...
    2020 MGM 1794 TRD Off-Road
    Thanks for that. Sounds similar to what I'm hearing. As I wrote before, the dealer says it's "normal" and sure enough another one on the lot sounded the same. Anyone else reading this hearing this sound when 4WD high is engaged?
  8. Mar 25, 2021 at 12:27 PM
    #128
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    The noise is only in 2WD. When you put it in 4WD the noise goes away. The only cause for this is the left CV axle needle bearing. If your hearing it in 4WD it's not the needle bearing.
  9. Mar 25, 2021 at 12:29 PM
    #129
    CreekDweller
    Oh - my mistake. So not the same at all.
  10. Mar 25, 2021 at 12:33 PM
    #130
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    When the 4WD is selected the needle bearing isnt rotating. The CV axle is turning with the differential carrier so no noise. When 2WD is selected the CV axle is turning and the differential carrier is stationary so the needle bearing is turning and makes a noise if defective.
  11. Mar 25, 2021 at 12:36 PM
    #131
    CreekDweller
    Yes, I understand that and it was corrected when they replaced my front differential. The sound I get when 4WD high is engaged is different.
  12. Mar 25, 2021 at 12:44 PM
    #132
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    Only in 4WD?
  13. Mar 25, 2021 at 12:45 PM
    #133
    CreekDweller
    Yes.
  14. Mar 25, 2021 at 12:50 PM
    #134
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    Possibly coming from the transfer case. You could confirm it by running it a hoist and engaging 4wd and listening to where the noise is coming from. Mine is so quiet I can't tell if it in 2wd or 4wd without looking at the switch or light.
    Wallygator likes this.
  15. Mar 25, 2021 at 12:56 PM
    #135
    CreekDweller
    That's interesting - mine hums or something like that in 4 high. The dealer denies that it is a problem and believes he proved that with the test drive of the new one on the lot which had an identical 'hum' to it in 4WD high. Also, I have no access to a lift outside of the dealer's with which to independently diagnose the sound. Even if I did, and found the sound came from the transfer case, the dealer has already pronounced it as normal.
  16. Mar 25, 2021 at 3:13 PM
    #136
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    Maybe some others could chime in if their trucks make a hum noise in 4WD?
  17. Mar 25, 2021 at 5:05 PM
    #137
    azTony
    Tony
    Sun Lakes, AZ
    No noise at all when in 4WD, no difference from 2WD
    Ruggybuggy likes this.
  18. Mar 26, 2021 at 5:58 AM
    #138
    CreekDweller
    Thanks for the feedback.
  19. Mar 28, 2021 at 11:11 AM
    #139
    General Motors
    General Motors New Member
    2021 Tundra SR5 SX
    2021 tundra I have it . Was very intermittent,but now more consistent have appointment at stealer-ship tomorrow
  20. Mar 28, 2021 at 11:25 AM
    #140
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    When I bought my 2020 I could here the noise slightly after I bought it. We went on holiday with a RV and started hearing it more but it was still faint. I decided to wait until the noise could be heard clearly so I wouldn't be charged to diag it.
  21. Mar 28, 2021 at 11:28 AM
    #141
    General Motors
    2021 Tundra SR5 SX
    Stellar ship will charge diag change ? I hope not 8,000 miles
  22. Mar 28, 2021 at 11:31 AM
    #142
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    They will. If they can't hear the noise and there isnt a problem they have to get the time spent on it somewhere. If there is an obvious problem they still could charge you but most dealers wont and will hide it in the repair cost under warranty. Ask before you agree and sign for service.
  23. Mar 28, 2021 at 11:32 AM
    #143
    General Motors
    2021 Tundra SR5 SX
    Thanks,Great web site !
  24. Mar 29, 2021 at 4:58 PM
    #144
    General Motors
    2021 Tundra SR5 SX
    Today Stealership shop foreman took truck for spin and verified growl howl harmonic.Toyota rep asked foreman to keep truck for a few days so they can do some digging on the problem. I was told it was a issue on Taco’s but they are now seeing it in Tundras . Gave me a loner car .
  25. Mar 29, 2021 at 5:05 PM
    #145
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    Good news that they acknowledge there is a problem.
  26. Apr 6, 2021 at 10:35 AM
    #146
    General Motors
    2021 Tundra SR5 SX
    Tundra truck repair completed replaced carrier assembly and differential all covered under warranty 500531F1-6395-4707-A0FD-8564E6276380.jpg
    blackoutt and LarryDangerfield like this.
  27. Apr 6, 2021 at 11:33 AM
    #147
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    Nice and no diag cost!
  28. Jul 13, 2021 at 10:26 AM
    #148
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    Well my truck is back at the dealership. The new replacement differential is making noise. This time it is only making noise in 4WD and the noise is most noticeable between 50-60mph when coasting with no throttle. The noise is bad enough you can feel the vibration in the steering wheel. The service manager just came to me and confirmed they heard the noise. My opinion is the only cause for this is a bad ring and pinion pattern on the coast side of the gear.
  29. Jul 13, 2021 at 1:12 PM
    #149
    General Motors
    2021 Tundra SR5 SX
    Hmm keep us posted
  30. Jul 13, 2021 at 1:25 PM
    #150
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    Tech said he thinks it's the transfer case because he only drained 1.5l out of it. I told him that's all that's in it and if the transfer case was making noise why on deceleration only. No answer.
    I've got a headache.
    LarryDangerfield likes this.
