  1. Apr 2, 2021 at 10:50 PM
    18" TRD Off Road Wheels
    Yup. As long as 3rd gens don't post here, it's all good. :p
  2. Apr 2, 2021 at 11:21 PM
    MrDirtjumper
    MrDirtjumper Ol’ dickhead
    Josh
    Slam Angelo, Texas
    06 DC TRD, 2wd to 4wd Conv.
    Well we kinda lost our shoo guy... when @bmf4069 stoped showing up so umm.
    Here’s all I have:
    Outbound, chrisb, MNtundra and 2 others like this.
  3. Apr 2, 2021 at 11:35 PM
    MrDirtjumper
    Josh
    Slam Angelo, Texas
    Honestly, I am slightly concerned about @bmf4069. From his forum persona, his only hobbies were Tundras, Taurussssesss, and electricity.
    He was all hard up on doing good work on Iron man before he ghosted.
    Anybody got some good google-fu in an SHO forum and maybe see if he’s still active there?
    NUDRAT[OP], CodyP and GODZILLA like this.
  4. Apr 2, 2021 at 11:43 PM
    He was last on here Dec. 30 2020.
  5. Apr 2, 2021 at 11:46 PM
    I'm kinda worried as well. He's gone quiet before, but not this long.
  6. Apr 2, 2021 at 11:50 PM
    People are allowed to move on. He has been on other forums recently.
  7. Apr 2, 2021 at 11:58 PM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    yea... i don't think moderation is my cup of tea. been there, done that (on something nothing like a forum.. but yea). i deal with enough drama at work. but I appreciate you guys thinking of me lol
  8. Apr 3, 2021 at 12:02 AM
    empty_lord
    05 rollover special
    That being said, I’ll be around for questions as long as I’m tagged.
    Ive got all of TIS at my disposal for as long as I’m working here at the dealer
  9. Apr 3, 2021 at 3:23 AM
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    Uhhh...no they aren’t.
    #1stgen4life
  10. Apr 3, 2021 at 8:05 AM
    @des2mtn i believe you linked some struts for camper shells,
    My closed length is 11.5” ball to ball, but when I’m opened I’m only around 18”, is it ok to be under the max length and they still function properly? Thanks again
  11. Apr 3, 2021 at 8:45 AM
    des2mtn
    SW
    2004 Black DC Limited 4x4
    Tonto cover
    I think that should be okay. Your rear window looks curved like mine so I have a feeling they will work. Take your time, don't force the window shut, and return 'em if it doesn't work. The main thing is that the compressed length shouldn't exceed the closed ball-to-ball length, that's when you run into trouble trying to shut the window. The compressed length can be shorter than your closed ball-to-ball length, that just means there will be part of the shaft exposed when the window is latched shut.
    This link has some part numbers and measurements too.
    https://truckoutfittersplus.com/store/topper_parts_gas_props_toppers.html
  12. Apr 3, 2021 at 8:46 AM
    onesojourner
    SW MO
    06 DBLcab LTD 4x4
    My rear leaf springs suck so bad. It's bordering embarrassing.
    chrisb likes this.
  13. Apr 3, 2021 at 8:49 AM
    Ok, that makes sense, just wanted to make sure.
    I’m redoing pretty much all the rear hardware; just noticed one of the hinges is shot, on top of someone using regular hardware thru the glass with no seals. The lock strikes are toast, the rods going to the rotary locks are janky and missing the clips holding into the center lock, and no key for current lock. Deep in a rabbit hole of parts searches!
    des2mtn[QUOTED] likes this.
  14. Apr 3, 2021 at 8:56 AM
    Lil Steve
    Lil Steve Living the dream
    Gilbert, AZ
    I've only driven locally on my new springs for about 200 miles but I can confidently recommend a set of HD replacement springs for everyday driving duties. The ride is better than before, not stiff or harsh. I have not put weight in the bed or towed yet but I expect it can only improve from the weak stock springs. You'd be looking at roughly $530 shipped for HD springs on a 4WD. Totally worth it IMO. https://www.tundras.com/threads/wha...t-gen-tundra-today.2558/page-905#post-2171032
  15. Apr 3, 2021 at 9:05 AM
    des2mtn
    SW
    Tonto cover
    After poking around it seems like the website I linked might be a good source for a few things. Any of these look like they'd work on yours?
    https://truckoutfittersplus.com/truck_topper_parts/Topper-Door-Hinges.html
    You could also consider going to a twist handle with cables to the latches instead of rods. You can open it from inside by just pulling the cables; that's what I have.
    I need to get these along with some strikers eventually, mine are getting tired after years of service.
    https://truckoutfittersplus.com/tru.../leer-100xl-xq-rotary-latch-with-bracket.html
  16. Apr 3, 2021 at 9:20 AM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    Its not made in China he says :D
  17. Apr 3, 2021 at 9:23 AM
    I might get struts from the place you linked but I found a more specific Snugtop site for some of the other pieces; just trying to decipher what parts I need and what will work with what they’re selling
    https://mysnug.com/
  18. Apr 3, 2021 at 10:04 AM
    My blue Loctite arrived in a red container. Makes sense.
    chrisb and CodyP like this.
  19. Apr 3, 2021 at 10:07 AM
    An Epi isn’t that bad IF you find the right one. Usually you have to go through a few of them to find one with a decent low action setting that doesn’t buzz. If you do, replace the pups with Burstbuckers or Custombuckers and you have a decent instrument.
    I’ve got a Les Paul Studio I bought used but unboxed for $800 and put in Burstbuckers. Sounds great!
    The next acquisition on my list is a used PRS in good shape.
    Darkness[QUOTED] likes this.
  20. Apr 3, 2021 at 10:11 AM
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    IIRC they're all in red containers but yes doesn't make sense.
  21. Apr 3, 2021 at 10:30 AM
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    Yeah, I have checked out a few and they seem to be good for the money. From what I have heard the older ones have bad pickups like you say. I'm just browsing for now, I started playing acoustic 2 months ago and made the mistake of playing a friend's 70's Gibson Les Paul, now I'm itching for an electric but not a $7k electric.
  22. Apr 3, 2021 at 10:37 AM
    chrisb and FirstGenVol[QUOTED] like this.
  23. Apr 3, 2021 at 10:59 AM
    Woah. This is interesting.
  24. Apr 3, 2021 at 12:03 PM
    You can find usually find a good deal on a new Les Paul Standard at Guitar Center during Christmas season for around $2k on sale. I’m not that lucky since I play lefty.
  25. Apr 3, 2021 at 12:14 PM
    onesojourner
    SW MO
    06 DBLcab LTD 4x4
    I am definitely planning on contacting them. Did you discuss any lift options with them?
    Let me know when you add some weight to them. I rarely run empty. My shell is a pig by itself.
  26. Apr 3, 2021 at 12:23 PM
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    Thats different. Long ago a different guy built the first short bed single cab, it looked so cool. Interestingly it was the same color.
  27. Apr 3, 2021 at 12:31 PM
    Wasn’t it rockmup or something from t4r that did that? I didn’t know it when that single single cab was done
  28. Apr 3, 2021 at 1:44 PM
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    The one I saw was named superluigi on socaltundras.com he was running long travel as well.
  29. Apr 3, 2021 at 1:52 PM
    Sirfive
    Sirfive Master Procrastinator
    ‘02 Limited AC TRD
    Bassani cat-back
    a tundra 2500?
  30. Apr 3, 2021 at 1:58 PM
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    was excited to get my new Kenda tires today....but Fedex dropped one tire off and left. Haha, guess the other 3 will come monday. Still waiting for the wheels to be shipped so I guess it doesn't matter anyways
