  1. Apr 2, 2021 at 10:04 AM
    jImmegart
    Jonah
    California
    2003 Tundra TRD Sport
    Its a Lamin X sticker. Super cheap and easy
  2. Apr 2, 2021 at 10:05 AM
    jImmegart
    Jonah
    California
    I went with a morimoto elite from retrofit source. Im about to go to work but I will add up my total later
  3. Apr 2, 2021 at 11:04 AM
    jImmegart
    Jonah
    California
    day time picture
  4. Apr 2, 2021 at 3:04 PM
    Outbound
    Aaron
    Northern Alberta
    First wash of the year.
  5. Apr 2, 2021 at 3:16 PM
    jerryallday
    jerryallday New Member
    Jerry
    Pasadena, Ca
    2006 DC SR5 V8 Grey
    theblurry1, Voss, SouthPaw and 3 others like this.
  6. Apr 2, 2021 at 3:21 PM
    NWPirate
    Zach
    WA
    Also you dealing with Plump Virus Finger at the Yoda store. :annoyed:
  7. Apr 2, 2021 at 5:20 PM
    SouthPaw
    SouthPaw The headlight guy
    2000 Limited 4x4 AC
    Same ones as always, nothing new. When they are aimed properly, they really shine!
  8. Apr 2, 2021 at 5:29 PM
    SouthPaw
    2000 Limited 4x4 AC
    I have 33x10.50R17’s on 0 offset 8.5” wide wheels with no rubbing at all. I keep debating on spacers to give it a little wider stance. Thanks for posting these pics, gives me an idea on what to look for.
    speedtre likes this.
  9. Apr 2, 2021 at 5:34 PM
    06tacomadc
    06tacomadc New Member
    Motor City
    Tundra
    De- baged? Looks good, do you have a side shot
  10. Apr 2, 2021 at 5:36 PM
    06tacomadc
    Motor City
    Tundra
    What lift do you run?
  11. Apr 2, 2021 at 5:36 PM
    SouthPaw
    2000 Limited 4x4 AC
    Toytec boss coil overs set at 2.75”
  12. Apr 2, 2021 at 5:37 PM
    MrDirtjumper
    MrDirtjumper Ol’ dickhead
    Josh
    Slam Angelo, Texas
    06 DC TRD, 2wd to 4wd Conv.
    My reaction every time I hear “light bar”
  13. Apr 2, 2021 at 5:38 PM
    06tacomadc
    Motor City
    Tundra
    Thx UCA’s?
  14. Apr 2, 2021 at 5:42 PM
    Glock 40
    Glock 40 I'm here to break shit
    Yukon Cornelius
    Way up thar
    2000 AC Limited 4X4 4.7L
    Deadpool Edition
    Got under there and found some stuff today.
    [​IMG]2021-04-02_06-08-55 by GhostCreekMine, on Flickr
    Replaced the power steering line that comes from the reservoir and connects to steel line, it was leaking.
    [​IMG]2021-04-02_06-13-33 by GhostCreekMine, on Flickr
    Split on the reservoir end. I had trimmed it back previously but still leaked. Gnar.
    [​IMG]2021-04-02_06-14-08 by GhostCreekMine, on Flickr
    [​IMG]2021-04-02_06-13-55 by GhostCreekMine, on Flickr
    And discovered it had even worse gnar.
    [​IMG]2021-04-02_06-14-21 by GhostCreekMine, on Flickr
    [​IMG]2021-04-02_06-14-33 by GhostCreekMine, on Flickr
    I could not source this section of formed line without buying the whole line assembly. So, instead I bought a couple ft of 3/8" ID of line rated for trans fluid... total cost: $1.78
    [​IMG]2021-04-02_06-15-03 by GhostCreekMine, on Flickr
    Fixed. I think I used less than a foot.
    [​IMG]2021-04-02_06-13-15 by GhostCreekMine, on Flickr
    Yoke... dry as a popcorn fart
    [​IMG]2021-04-02_06-15-24 by GhostCreekMine, on Flickr
    Fixerated
    [​IMG]2021-04-02_06-15-39 by GhostCreekMine, on Flickr
    While I was under there, I couldn't help but notice this... mothertruckin CV on the RH side. Sumbitch.
    Going to suck it up and upgrade to the NAPA HD CVs with more articulation. Knew this was coming since I lifted it a little bit ago.
    [​IMG]2021-04-02_06-09-25 by GhostCreekMine, on Flickr
    [​IMG]2021-04-02_06-10-07 by GhostCreekMine, on Flickr
  15. Apr 2, 2021 at 5:48 PM
    SouthPaw
    2000 Limited 4x4 AC
    JBA off-road. Alignment came out straight as an arrow and it rides nice.
    fighthedude likes this.
  16. Apr 2, 2021 at 5:51 PM
    Professional Hand Model
    Fred
    Hand Protectors
    Did you heat and bend your new hose or just finesse it? Big saving$$$ as that other adjacent hose is $65 OEM!
    Looks like you slathered your shaft heavily. You grease the zerks? Must be nice having a lift to work with! :thumbsup:
    NUDRAT and Glock 40[QUOTED] like this.
  17. Apr 2, 2021 at 6:02 PM
    Glock 40
    Yukon Cornelius
    Way up thar
    Deadpool Edition
    I just ran it fairly straight taking care not to kink it... just enough slack. I'm gonna keep an eye on it, hot PS fluid can effect things. I couldn't even find that section anywhere. I'll pay $65 if this experiment fails. You gots a link?
  18. Apr 2, 2021 at 6:04 PM
    Glock 40
    Yukon Cornelius
    Way up thar
    Deadpool Edition
    aaaahhh, adjacent... meaning it's sister hose coming from the res. (the one on the left in the pic). I already replaced that with OE. That one had a larger OD and runs to the PS pump.
  19. Apr 2, 2021 at 6:11 PM
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
    Rotated Tires and changed oil after 5K and Mobil still looked good. Working on Sunroof lubrication, some more cleaning to do. Having to pace myself.
  20. Apr 2, 2021 at 6:29 PM
    If you can find a spring or make shift a wire the same size and slide it over the bendy area, and that will keep it kink free. I’ve never used one, but old school refrigeration guys have “spring benders” that you would put soft copper in and bend a 90 or whatever, the spring pressure all the way around the pipe keeps it from kinking while bending it. I assume the same principle would work here, a lot of high end vacuum hoses are imbedded with a spring/wire to prevent collapsing
  21. Apr 2, 2021 at 11:32 PM
    jImmegart
    Jonah
    California
  22. Apr 3, 2021 at 5:57 AM
    Fred
    Hand Protectors
    Couldn’t find the little hose anywhere even with a deep search. The bigger one is $65 and available.
  23. Apr 3, 2021 at 6:21 AM
    Fred
    Hand Protectors
    I believe you mentioned its only available with another assembly which is only how I can find it via Toyota. Seeing how gnar your hose is it might be time to replace the rest of the assembly (same wear rate) but its Ric Flair pricing. Maybe aftermarket?
    Voss and Glock 40[QUOTED] like this.
  24. Apr 3, 2021 at 6:26 AM
    Fred
    Hand Protectors
    RockAuto has an aftermarket set up for about $110. Buy it and replace the whole thing as you know you’ll need to soon probably.
    hammeron, Pearl-snap and Glock 40 like this.
  25. Apr 3, 2021 at 6:43 AM
    Glock 40
    Yukon Cornelius
    Way up thar
    Deadpool Edition
    You found the exact same offerings as me for that PS line. Full line overhaul not necessary. Glad I fixed it for $1.78.
    Jack McCarthy likes this.
  26. Apr 3, 2021 at 6:43 AM
    Or just replace the return line with $7 of pneumatic hose spliced into the hard line at the steering rack like I did. :D
    if the high pressure source line is failing, that’s the time you want to do it right with an OEM or good aftermarket assembly.
    Glock 40 likes this.
  27. Apr 3, 2021 at 6:47 AM
    Glock 40
    Yukon Cornelius
    Way up thar
    Deadpool Edition
    I'm good with the $1.78 fix... worthwhile. If I need to replace all the lines in the future (doubtful) it'll be rockauto.
  28. Apr 3, 2021 at 7:15 AM
    Fred
    Hand Protectors
    Just providing options guys. No need to argue!:rofl:
    Yeah. I’ll do a combo fix on mine when needed. Probably go Full Organic and heat bend vulcanize my $1.78 rubber and add some of those French Toasty Artisan Crafted Copper Coils. Make a day out of it. :thumbsup:
  29. Apr 3, 2021 at 7:20 AM
    Glock 40
    Yukon Cornelius
    Way up thar
    Deadpool Edition
    I may still do this. I have the old line so I could bend a line to match. Need to see how the $1.78 fix performs first.
  30. Apr 3, 2021 at 7:24 AM
    Fred
    Hand Protectors
    Good idea on saving the line for future templating.
