Wont shift out of park
Discussion in '2.5 Gen Tundras (2014-2021)' started by Sumo91, May 14, 2020.
  1. May 14, 2020 at 4:22 AM
    Sumo91
    Sumo91 [OP] Busy with projects
    TN
    2014 MGM Tundra Platinum 4x4
    Hey all! Got in my truck after work today and it wouldn't shift out of park. I hit the manual release button by the shifter and shifted into drive just fine, and got back home. Checked the brake, tail, reverse, and hazard lights, and they all work. Checked a few fuses as well but then it started pouring down rain so I had to get back inside. Any ideas?
  2. May 14, 2020 at 6:28 AM
    ddact
    ddact New Member
    2019 5.7L 4WD SR5 DC FFV - Black
    Have you tried turning the steering wheel side to side while you try to shift. Not sure on the tundras, but older cars could get in a bind and not let it shift unless you turned the wheel to take the bind off of the steering lock.
    Other than that, I'd guess something in the brake interlock isn't working. Not sure how to test that though.
  3. May 14, 2020 at 6:36 AM
    fundratss
    fundratss Send it!
    Joe
    Colorado Springs
    2016 Magnetic Grey Tundra TSS
    Toytec 2.5” Coilover boss suspension 3/1 lift w/camburg uca’s Morimoto xb headlights Morimoto fog Rough country grill 2 RC blacked light bars Volant air intake system Rear air bags (for towing) I’m sure there’s more but I’m lazy
    If your brake lights and everything works. And cruise control work. Then I’d start looking at the shifter. But I’m not sure if bcm controls it or not. For example on dodge/Chrysler/fiat. The vehicle gets put into park if you are in drive and open the drivers door. I don’t think Toyota does fancy stuff like this yet but who knows.
  4. May 14, 2020 at 6:43 AM
    Sunnier
    Sunny
    San Diego, CA
  5. May 14, 2020 at 7:06 AM
    Stig
    Stig New Member
    Did it happen just that one time or is it still stuck without manually releasing?
  6. May 14, 2020 at 3:15 PM
    Sumo91
    TN
    It's still stuck in park, i have to manually release it still. had to run a few errands today and came to work. Still stuck in park. Thinking it might be my third brake light because it's kind of dim and it may not let it complete the circuit. I'll keep everyone updated
    Sunnier and Black Wolf like this.
  7. May 14, 2020 at 3:34 PM
    blackdemon_tt
    blackdemon_tt Battery Slayer
    Could it be the neutral control switch going bad??? When you press the brake it should communicate to the transmission/ shifter that its OK to release from Park and shift out.
    Have you tried engaging the ebrake and shifting out of Park this way without pressing the regular brake??
    Sumo91[OP] likes this.
  8. May 14, 2020 at 3:35 PM
    Sumo91
    TN
    Havent tried that yet but I'll give it try when I get off work in the morning.
  9. May 14, 2020 at 3:42 PM
    blackdemon_tt
    I've done it before, so I'm pretty sure it should work for you at least in the mean time until you resolve the issue....
    Sunnier likes this.
  10. May 17, 2020 at 7:02 PM
    Sumo91
    TN
    Tore apart my center console today, a mouse chewed both wires to the brake interlock switch, had just enough left to solder them and heat shrink them back. Got to clean everything inside of there really good too. Sprayed peppermint oil all throughout the center console area to prevent the mouse from chewing anymore wires. Put a sticky trap down tonight hoping to catch him.
    blackdemon_tt and Sunnier like this.
  11. Apr 2, 2021 at 1:48 PM
    Gas
    Gas New Member
    2015 Grey Tundra TRD
    I have a 2015 Tundra TRD tht had 128 000km on it when I purchased from Mitsubishi Dealer.
    Got in truck after work one day and would not shift out of park.
    Brought it to the toyota dealer, turns out the after market trailer break switch tht was installed by previous owner and butchered mind ya malfunctioned and burned up wires in my break solenoid switch and blew fuses in panel box.
    Once tht was all by passed, truck shifted out of park.
  12. Apr 2, 2021 at 2:02 PM
    PKFan
    2018 Inferno! DC SR5 4x4
    Bastages!
