T100 Brake Booster Upgrade
Discussion in '1st Gen Tundras (2000-2006)' started by Thrussn, Mar 31, 2021.
  1. Apr 1, 2021 at 12:48 PM
    FirstGenVol Brake Czar
    2002 AC
    I wanted to call you out. 4x4 swap awaits you.
    ***That's supposed to be a GIF
    Thrussn[OP] and Darkness[QUOTED] like this.
  2. Apr 1, 2021 at 12:51 PM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    It does! Its just gonna keep waiting for now. Two Beetles come first but I might start collecting the parts to do the swap. I told myself before my next set of tires I will be 4x4.
    Thrussn[OP], des2mtn and speedtre like this.
  3. Apr 1, 2021 at 12:51 PM
    speedtre
    speedtre New Member
    Inland Northwest
    It is now...:thumbsup:
  4. Apr 1, 2021 at 1:32 PM
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    Hey hey hey, I might have to do this T100 swap this year. The replacement booster I put in last year has been leaking vacuum occasionally. To add insult to injury it cost 3x as much as the T100 kit.
  5. Apr 1, 2021 at 1:56 PM
    Thrussn
    Thrussn [OP] Plastidip Hoe
    Gabe
    NM
    Silver 2005 4.7L 4WD Access Cab
    Bilstein 5100s, SickHIDs projector housings, Plastidip everything, TRD Pro style rims, LEDs everywhere, SUPERBUMP bumpstops. Firestone Riderite air bag springs, Deaver G57s, Onboard VIAIR system, Backup Camera, light bar behind the bumper, CGS catback, Exhaust cutout after cats, JBA Shorty headers, JBA Y-Pipe, pioneer deck, pioneer speakers, kicker 10" sub w/ amp, door sound deadening, Dirtydeeds 12 pin injectors, UniChip, Skid Row Skidplate, EZ Oil Drain valve (Better than Fumoto), Oil Catch Can, & 4WD Conversion
    What are symptoms you're experiencing when the vacuum leaks? I'll definitely be sure to update this thread if I run into any issues since I'm using more budget focused parts.
  6. Apr 1, 2021 at 2:19 PM
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    Sometimes at a stop light I can hear hissing. If I tap the brake pedal while it is hissing the pedal firms up and the hissing stops. Similar when I park it, I hear hissing and tapping the brake stops it. I'm guessing the diaphragm might be leaking. If I understand correctly when the pedal is super hard its because the booster isn't helping you.
    AR 02 TUNDRA likes this.
  7. Apr 1, 2021 at 2:59 PM
    Professional Hand Model
    Fred
    Hand Protectors
  8. Apr 1, 2021 at 4:25 PM
    rock climber
    rock climber New Member
    2001 Sequoia 4X4, 2000 AC 4X4
    This is awesome, thanks for the write up!
    Maybe dumb question, but is this the part you had to trim?
  9. Apr 1, 2021 at 5:03 PM
    Thrussn
    Gabe
    NM
    Yes that is exactly what I had to cut
  10. Apr 1, 2021 at 5:50 PM
    daveeasa
    So, $120 + tax/ship and you have superman strength brakes? Sounds perfect to me.
  11. Apr 1, 2021 at 6:15 PM
    Thrussn
    Gabe
    NM
    They don't necessarily bite harder, but the travel is significantly reduced and they're much more touchy. They are about as stiff and have as much travel as when you pump the brakes with the engine off. They actually brake though!
  12. Apr 1, 2021 at 6:23 PM
    speedtre
    speedtre New Member
    Inland Northwest
    This makes sense....with what you've done I'd expect less pedal travel to create the same hydraulic pressure and I would not expect the "bite harder" untill the caliper/rotor/pad update and the corresponding increase in braking surface area. So far so good...:thumbsup:
  13. Apr 2, 2021 at 5:29 AM
    Fred
    Hand Protectors
  14. Apr 2, 2021 at 5:30 AM
    Fred
    Hand Protectors
  15. Apr 2, 2021 at 5:31 AM
    Fred
    Hand Protectors
  16. Apr 2, 2021 at 5:33 AM
    Thrussn
    Gabe
    NM
    It's very interesting that a T100 brake booster and master cylinder are an upgrade from the first gen Tundras.
  17. Apr 2, 2021 at 8:58 AM
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    Knowing this I'm gonna go for the throat. Who wants to see me use a booster/MC from a '60s Stout?
    :D @empty_lord can I get a part number please?
  18. Apr 2, 2021 at 9:24 AM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    dude.. i cant look up parts that old anymore lol. i dont think most of those trucks even had power brakes. and their master would be tiny because 4 wheel drum
    Darkness[QUOTED] likes this.
  19. Apr 2, 2021 at 9:25 AM
    empty_lord
    05 rollover special
    now please do a rear disc swap and report back how it handles it.. this may change my plans for a sequoia master and go to the t100 setup
  20. Apr 2, 2021 at 9:31 AM
    #50
    Fred
    Hand Protectors
  21. Apr 2, 2021 at 9:43 AM
    #51
    speedtre
    speedtre New Member
    Inland Northwest
    :thumbsup:
  22. Apr 2, 2021 at 9:58 AM
    #52
    Fred
    Hand Protectors
    I’m cross referencing the 2002 Tundra with the 1995 T-100 (for rear brake cylinders) right now to see their cross fitments per the websites.
    Not jiving, but the 2002 Tundra description does say for ‘1ton’ along with LC, 4 Runners, etc for these rear drum cylinders.
  23. Apr 2, 2021 at 3:08 PM
    #53
    Thrussn
    Gabe
    NM
    I believe in you guys lol
    That's absolutely on my list. I can't remember which company it was that used the Sequoia brakes though. I'd like to be able to order higher quality brake parts when I send it
  24. Apr 5, 2021 at 1:08 PM
    #54
    rock climber
  25. Apr 5, 2021 at 4:44 PM
    #55
    Thrussn
    Gabe
    NM
    No, but I just discovered it says it uses parts off of the FJ cruiser, which is a good thing.
    This is the one I have saved. It uses brake components off a 2010+ 4runner which is also a great option.
    https://www.silverminemotors.com/to...e-upgrade-swap-kit-backing-plate-with-e-brake
    I just dropped my new calipers off at the machine shop this morning. Hopefully I'll have it together next week some time.
  26. Apr 5, 2021 at 4:48 PM
    #56
    Thrussn
    Gabe
    NM
    Update on the brake booster from ebay:
    I drove about 500 miles this weekend and the brakes worked fine. I have noticed a whistle I can hear from the cab coming from the booster. I believe it has a very slight vacuum leak, but the braking performance isn't hindered at all. I can only hear the noise when lightly braking as well. No noise is present when hard braking or off of them entirely. I'm reaching out to the seller and will provide an update if anything happens.
    #56
  27. Apr 6, 2021 at 10:04 AM
    #57
    Thrussn
    Gabe
    NM
    The seller got back to me and said they will send me a replacement
    #57
  28. Apr 6, 2021 at 3:07 PM
    #58
    Fred
    Hand Protectors
    I seen’t RockAuto has new boosters for sale (T100) when I was looking at other shtuff the other day (for anyone that cares).
  29. Apr 15, 2021 at 3:17 PM
    #59
    Thrussn
    Gabe
    NM
    Just installed my replacement booster. It's slightly different than the first t100 one I had. It's a larger diameter and the vacuum port is different. Here are part numbers you were interested in @Professional Hand Model
    Full replacement took me about 30ish minutes including the time to chop off that bit of the shaft. The brake is much easier to step on which leads me to believe I had a tiny vacuum leak from the beginning.
    The company was very polite and easy to communicate with.
    This is the newest booster after it's been installed.
  30. Nov 28, 2021 at 7:37 AM
    #60
    Punk1974
    Punk1974 former 2000 owner looking for a fg tunny project
    J.P.
    2019 Silver Limited CM TuRD
    Bak Flip MX4 Tonneau cover, Spray in Bedliner, Tube steps, stubby antenna, red rear sway bar, looking to get back into a first gen tunny
    got linked over here from another amazing thread you guys never cease to amaze
    Thrussn[OP] likes this.
