Ask the Detailer
Discussion in 'Detailing' started by T-Rex266, Nov 13, 2017.
  1. Mar 30, 2021 at 12:57 PM
    #3601
    Ckatz53
    Ckatz53 Newish
    MD
    www.fouroneodetailing.com
    They are very comparable except for their drive design. Flex being gear driven and Rupes free spinning (except for their "new" Mille). I am very comfortable with Lake Country pads and a mixture of Meguiars and 3D polishing products, hence why I like the idea of flexibility of the 3401. Rupes is engineered as a system and works best with all Rupes products (polishers, backing plates, pads, compounds, polishes). This article from Mike Phillips explains it best:
    https://www.autogeekonline.net/foru...s-question-i-get-asked-lot-mike-phillips.html
  2. Mar 30, 2021 at 4:45 PM
    #3602
    Taco-Blender
    Taco-Blender Old Guys Rule
    AZ
    2010 DC 4x4
    Well, 3 months into the CeraKote and I'm a believer. This stuff ROCKS!
    War Machine, Fotnot, 81 TOY and 2 others like this.
  3. Mar 30, 2021 at 4:46 PM
    #3603
    HighonFirewood
    HighonFirewood Everything can be fixed with a hammer.
    Stage Left. Colorado
    2019 Tundra
    That’s cheaper than I paid! Thanks
    ToyoMafia likes this.
  4. Mar 30, 2021 at 4:46 PM
    #3604
    ToyoMafia
    Magic carpet.
    Cool slaps and plastiDip
    Yep. Stuff is legit.
    War Machine likes this.
  5. Apr 1, 2021 at 5:17 AM
    #3605
    Boerseun
    Boerseun MGM XP-Series
    Ferdie
    Sarasota Florida
    I am very impressed with CeraKote. I was skeptical when I saw it was 'wipes' but I have to say that it works better than just about any detailing product that I have ever used. My unpainted black door handles were getting bad from the Florida sun, and they look better than they were when new; almost look like they are painted. The wiper cowl area was also grey, and is now 'blacker than a new one'.
    IMPORTANT: Read the instructions and warnings! I almost screwed up by doing it in the sunlight on hot parts; was able to save it, but it could have been bad as it started to bead up and formed big droplets. Any screw-ups will be permanent.
  6. Apr 1, 2021 at 5:19 AM
    #3606
    Fotnot
    Fotnot SSEM #69; LRCS#1
    Andy
    SW Louisiana
    Swimmers gonna swim
    i'm still in disbelief of how easy and how well it works. i kinda wanna use in on my daughters' slide, but last time i slightly waxed it the kids flew too fast and hit their ass on the ground. wife wasn't happy.
  7. Apr 1, 2021 at 9:59 AM
    #3607
    drewpweinerMD
    drewpweinerMD MPG’s are for your moms Prius.
    Jeremy
    2024 Limited TRD OR
    RB20 Slims, BAK X4s, Fabtech Level, Cooper 35's
    @War Machine
    What is the best method and product to clean the stock BBS Forged wheels on my 21' Pro?
  8. Apr 2, 2021 at 3:55 AM
    #3608
    War Machine
    War Machine SSEM # 5 3MW
    I haven’t really discovered a “magic bullet” for cleaning wheels. Just a good cleaner and elbow grease. I haven’t found one wheel cleaner that really breaks away from the pack. P&S Brake Buster is decent, with the advantage of being safe for all types of wheels.
    My go-to is Shine Supply Wise Guy. It’s always been the best tire cleaner on the market in my opinion, but a year or so ago they reformulated it to clean wheels also. It cleans the wheels about as well as any other product, but since it’s so great at cleaning the tires it makes it convenient to use for both.
  9. Apr 2, 2021 at 10:04 AM
    #3609
    ToyoMafia
    Magic carpet.
    DONT BUY FROM AUTOGEEK!!
  10. Apr 2, 2021 at 10:32 AM
    #3610
    tundrasportinMA
    tundrasportinMA New Member
    Western Mass
    2019 Tundra Sport DC
    6112/5160 , SCS Ray 10's, Cooper Discover AT3 -295/70/18, Dirty Deeds 8inch, N-Fab Podium
    I saw you mention Shine Supply Wise Guy in another post and was going to pull the trigger and get some but then I saw on their site the Shine Supply Cool Guy should be used for ceramic coated wheels. I had friend do some detailing on my truck last November and he didn't ceramic coat it, but he used Graphene ( I don't know what specific product he used) and I believe he said he coated the wheels with it as well.
    So my question is in your opinion do you think I would be ok using the Wise Guy product ( about 1/2 the price of the Cool Guy) ? I assume they recommend the Cool Guy as not to remove the ceramic coating? If that is the case I am thinking that what ever he put on in November probably has worn off to some degree already.
  11. Apr 2, 2021 at 11:08 AM
    #3611
    War Machine
    I honestly wasn’t even aware of the Cool Guy product. I assume it’s newer. I wish I could give you a solid answer, but I’m just not sure.
    I’m also unsure about how quickly graphene will wear off of wheels. I have zero experience with it, and have barely messed with coating wheels.
    Sorry, but I’m not going to be much help on this one. All I can advise is that if Shine Supply says not to use it, then I wouldn’t unless I knew that coating was already worn off.
    P&S Brake Buster claims to be safe for all wheels, but not sure if it’s comparably effective to Cool Guy. In theory, if the coating is good then you shouldn’t need a very strong cleaner for them.
  12. Apr 2, 2021 at 11:13 AM
    #3612
    tundrasportinMA
    Western Mass
    No problem, I appreciate the reply. If they cost the same I would have gone with the Cool Guy but since its double I have held off.
  13. Apr 2, 2021 at 12:47 PM
    #3613
    drewpweinerMD
    Jeremy
    2024 Limited TRD OR
    Thanks much!
  14. Apr 2, 2021 at 4:28 PM
    #3614
    Azblue
    The Dirty T ( ^_^)_且
    What happened?
    GODZILLA, Oey12 and ToyoMafia[QUOTED] like this.
  15. Apr 2, 2021 at 4:50 PM
    #3615
    Oey12
    Oey12 New Member
    Joey
    New York
    2020 SR5 TRD OFFROAD
    Questions in regards to Cerakota...
    #1. I don’t have a garage big enough to fit my Tundra so I have to do it outside. When is the best time to apply it; early morning before the sun really gets going or at dusk?
    #2. Is it safe if the wipe hits my ceramic coated paint, glass, or chrome bits? I will try my best to avoid it but just in case...
  16. Apr 2, 2021 at 5:11 PM
    #3616
    ToyoMafia
    Magic carpet.
    Yes early or late just make sure it won’t rain or sprinklers.
    Tape off your paint. Don’t get it on it.
    Oey12[QUOTED] likes this.
  17. Apr 2, 2021 at 5:20 PM
    #3617
    Oey12
    Oey12 New Member
    Joey
    New York
    Thanks...is there a special tape for that or you think the 3M blue painters tape sufficient?
    ToyoMafia[QUOTED] likes this.
  18. Apr 2, 2021 at 5:27 PM
    #3618
    ToyoMafia
    Magic carpet.
    Blue will work. Yellow is the shiz
  19. Apr 2, 2021 at 5:33 PM
    #3619
    Oey12
    Oey12 New Member
    Joey
    New York
    Awesome! Thanks again, I will buy the yellow.
  20. Apr 3, 2021 at 7:36 PM
    #3620
    jwatt
    jwatt I heart men
    Jack
    Oregon
    Salsa Red 2007 Tundra DC @91k.
    7" BDS Coilover Suspension Lift/BDS UCAs/XB LED Headlights/Nitto trail Grappler tires on Black Rhyno Armory wheels
    I think I ve neglected these rock chips long enough. I got them all over the hood. (From the previous owner). Is this something a detail shop can fix? If so I m wondering how they would address it so I can be ready when I do take it in.
  21. Apr 3, 2021 at 7:46 PM
    #3621
    ToyoMafia
    Magic carpet.
    Touch up paint will be the cheapest approach otherwise a respray is in order.
    Saltyhero13 likes this.
  22. Apr 3, 2021 at 7:53 PM
    #3622
    briarpatch
    briarpatch New Member
    The pic on top is concerning....looks like surface rust is starting.
  23. Apr 3, 2021 at 11:43 PM
    #3623
    jwatt
    jwatt I heart men
    Jack
    Oregon
  24. Apr 4, 2021 at 5:55 AM
    #3624
    Saltyhero13
    Saltyhero13 Throbbing Member
  25. Apr 5, 2021 at 4:14 AM
    #3625
    War Machine
    If it gets on your paint just wipe it off immediately. I’d do it at dusk. Early in the morning, dew tends to form even after drying, and you don’t want that anywhere near Cerakote.
  26. Apr 5, 2021 at 4:15 AM
    #3626
    War Machine
    Saltyhero13 and ToyoMafia like this.
  27. Apr 5, 2021 at 5:20 AM
    #3627
    Boerseun
    Ferdie
    Sarasota Florida
    I have fixed a few rust spots on my Tacoma and it worked good. Obviously still visible, but it stopped rust from growing under the paint. I used a Dremel to grind through the rust and clean it up, then applied the paint in thin layers until it was just above the surrounding surface, and then sanded it down very carefully with 1000 and 3000 grit sand paper.
    Oey12 likes this.
  28. Apr 6, 2021 at 7:16 PM
    #3628
    CNE0207
    CNE0207 New Member
    Arvada, CO
    2020 Cement CM Limited
    Any of the detailers here used the 303 Graphene spray? Claims one year of protection... thinking about using it in conjunction with griots 3in1
  29. Apr 6, 2021 at 7:42 PM
    #3629
    Saltyhero13
    Griots 3 in 1 is pretty heft on its own, why do you want to stack them?
  30. Apr 6, 2021 at 8:29 PM
    #3630
    CNE0207
    CNE0207 New Member
    Arvada, CO
    I was thinking do a good Decon with iron x, clay and polish then top it with the graphene to make it last longer... harsh winter and sun here in Colorado
