1st Generation Tundra parking brade adjustment
Discussion in '1st Gen Tundras (2000-2006)' started by Toyota lover, Feb 6, 2019.
  1. Feb 6, 2019 at 1:09 PM
    Toyota lover
    Toyota lover [OP] New Member
    2003 Tundra SR5
    Looking for a manual or video showing how to adjust the parking brake.
  2. Feb 6, 2019 at 4:15 PM
    6ixofone
    6ixofone New Member
    Greenville, SC
    2001 sr5 ac 4.7
    hammeron and artsr2002 like this.
  3. Feb 6, 2019 at 6:24 PM
    Toyota lover
    2003 Tundra SR5
    Thanks for posting this video!
  4. Jan 11, 2021 at 9:13 AM
    SouthPaw
    SouthPaw The headlight guy
    2000 Limited 4x4 AC
    Bringing this one up from the dead. My parking brake only grabs at the very end of the pedal towards the floorboard. I don’t recall if the pedal ratchets but can someone point me in the right direction on what to look for first? I’ll check the cables but like I said, it grabs at the very end but it’s pretty weak. I can put it in Drive with the parking brake on it and it barely holds itself in place.
  5. Jan 11, 2021 at 2:36 PM
    rock climber
    rock climber New Member
    2001 Sequoia 4X4, 2000 AC 4X4
    The brake should be self adjusting if everything's working. The attached pdf has a lot of good tips. Also, try this video.
    https://www.youtube.com/watch?v=rXMGzdA4aKM
  6. Jan 11, 2021 at 3:06 PM
    robabeatle
    robabeatle New Member
    AZ
    2002 Tundra 4x4 LTD AC
    Bilstein 6112 & 5160, Katskinz, audio upgrades
    Mine was not self adjusting. I had to take up slack from underneath the driver's side cable connection thingy first. Greased all moving parts. Then adjusted the star adjusters via the peep hole. Finally adjusted the forward/rear braking bias towards the rear a bit. Now braking is much more solid and the parking brake engages.
    FrenchToasty, lc69hunter and SouthPaw like this.
  7. Jan 11, 2021 at 4:15 PM
    Professional Hand Model
    Fred
    Hand Protectors
    Important and often overlooked. Not in FSM. Equalizer has two plastic bushings. Mine were torn up. Inspect, lube, replace bushings if needed.
  8. Jan 11, 2021 at 9:42 PM
    tunyota
    tunyota Wrenching w/ the beautiful wife.
    Phantom Gray 2006 Regular Cab Long Bed 4WD V8 4.7L
    Front Hitch Receiver, Bilstein 5100s, Denso 130A alternator, LED interior and exterior lighting, Kicker 46CSS674 Car Audio 6 3/4" Component Full Range Stereo Speakers, Pioneer AVHX2700BS w/Pioneer NDBC8 Backup Camera, Transcend Drivepro 550 Dual Lens Dash Camera, and much more!
    @SouthPaw this seems this is a fairly common issue reported by many of us Tundra owners. My parking brake when depressed to the floor would not keep the vehicle from rolling on a slight hill in neutral. For this reason I recently inspected, disassembled, cleaned, and re-lubed appropriate areas as the previous owner/mechanic who serviced the rear drum brakes didn't do a proper job. I found there was a decent gap between the bellcrank and backing plate on the drive side, and return spring was located in the incorrect hole/position causing interference with the adjuster.
    Consider checking out these 2 threads I recently discovered when researching how to properly inspect and adjust the rear drum brakes as you may find them insightful as I did.
    2006 Tundra E-Brake Slack
    E- brake cable slack
    Here is another link to some documentation I found in another thread here but can't remember or else I would give them credit.
    https://drive.google.com/file/d/10zh-bA9jFd-T5XxbKRhGXfSf29dRT2fS/view
    SouthPaw likes this.
  9. Jan 12, 2021 at 2:34 AM
    w666
    w666 D. None of the above
    Maryland
    04 Access Cab SR5 V8 4WD
    1. Make sure the shoes are adjusted correctly
    2. Make sure the Bell Cranks are not seized, and adjusted per the FSM
    then...
    3. Lubricate and adjust the cables and pivot points
  10. Mar 26, 2021 at 6:08 PM
    01tunder
    01tunder New Member
    Ca
    2010 4x4 trd tundra
    My cables are hanging loose
  11. Mar 27, 2021 at 6:23 AM
    Fred
    Hand Protectors
    There are a few other Parking Brake Adjustment Threads on here in the 1st Gen Section. Seek those out and follow the directions per the Factory Service Manual Guide. Basically, the PB is responsible for resetting and maintaining your rear drums tolerances. You’ll crawl under the truck and follow the directions. Might take a few trial and errors, but you’ll figure it out and be glad you did. Often overlooked is the ‘Equalizer’ in the picture above and is not listed in the FSM Guide for ajustings.
  12. Mar 27, 2021 at 8:08 AM
    01tunder
    01tunder New Member
    Ca
    2010 4x4 trd tundra
    Would this make my brakes hit the floor?
  13. Mar 27, 2021 at 8:09 AM
    Fred
    Hand Protectors
    I don’t understand. Please explain more.
  14. Mar 27, 2021 at 11:08 AM
    01tunder
    01tunder New Member
    Ca
    2010 4x4 trd tundra
    Sorry English is my 3rd language. Would the loose cables cause my brake pedal to be soft?
  15. Mar 27, 2021 at 1:04 PM
    terrward
    terrward New Member
    2004 DC SR5
    Are you talking about your emergency brake pedal or your regular brake pedal.
  16. Mar 27, 2021 at 1:16 PM
    01tunder
    01tunder New Member
    Ca
    2010 4x4 trd tundra
    Both
  17. Mar 27, 2021 at 2:48 PM
    SouthPaw
    2000 Limited 4x4 AC
    Sounds like you have a leaking wheel cylinder
  18. Mar 28, 2021 at 6:25 AM
    Fred
    Hand Protectors
    Loose Cables will make your truck NOT allow the Rear Drum Brakes to self adjust. The self adjustment is critical to keeping the rear brakes in tune/optimized for its best braking.
    Your Soft Pedal could be from air in brake lines, old brake fluid, worn pads on all brakes, etc.
    Its really hard to diagnose over the internet.
    Are you able to work on your vehicle or do you take it to somebody?
    Most mechanics can fix the old brake fluid and pads, but they get lost on the Tundra Rear Drum Adjustment. Maybe print that Manual Page for them if thats where you are taking it. Remind them about the Equalizer.
  19. Mar 29, 2021 at 10:22 AM
    rock climber
    Yes, the parking brake adjusts the rear drums and that impacts how the pedal feels and how quickly it engages.
  20. Jun 18, 2021 at 3:54 AM
    bewildered
    bewildered New Member
    blue 2006 tundra sr5 v8
    Thanks much !
    tunyota[QUOTED] likes this.
