Changing tire with lift
Discussion in '1st Gen Tundras (2000-2006)' started by fighthedude, Mar 19, 2021.
  1. Mar 19, 2021 at 7:13 AM
    fighthedude
    fighthedude [OP] New Member
    Whats up fellas. How are you all prepared to change tires with a lift? I put 3-4x4x12" with plywood top for a hunting trip last year. Never needed it. But was thinking of a better way. Any suggestions. I recently got a camper shell so can move some stuff the the bed. I will probably buy a small locking box for bed to keep items in... anyone running a hi-lift? Seems like those can only be used if you have armor to lift from. Side note...i have wiring for the shell brake light. Where should I tie into? Trailer harness or brake light? I am going to get it bed lined soon so I will wait til thats done. Also want to run led strips under bed rails to a switch... let me know what you guys think! Cheers
  2. Mar 19, 2021 at 7:19 AM
    Lake.Life24
    Lake.Life24 New Member
    Shawn
    Upstate, NY
    2021 GMC Sierra 3500HD Gasser
    I use a 6 ton bottle jack and a 2' 6x6 laminated post. And my cap is tied into the break light with its own inline fuse
    fighthedude[OP] likes this.
  3. Mar 19, 2021 at 7:21 AM
    DSLKSL
    DSLKSL New Member
    Don
    I keep a bigger jack and a piece of 4x4 in a box in the bed, with gloves, pressure gauge, breaker bar, and spare lugs:)
    BravoDeltaRomeo likes this.
  4. Mar 19, 2021 at 7:27 AM
    Professional Hand Model
    Fred
    Hand Protectors
    Custom cut a few 2x6 blocks for stacking purposes and have them neatly wedged into the rear under seat storage on both sides with the other emergency stuff.
    des2mtn and BravoDeltaRomeo like this.
  5. Mar 19, 2021 at 8:14 AM
    I put the Stock jack under the rear axle, or the front lower control arm. Otherwise I have an "SUV" 3.5 ton floor jack that I use in the shop. It has a higher reach to jack the truck up using the frame.
    Festerw likes this.
  6. Mar 19, 2021 at 8:50 AM
    jerryallday
    jerryallday New Member
    Jerry
    Pasadena, Ca
    2006 DC SR5 V8 Grey
    For emergency’s I have the stock jack and I carry a piece of 4x4 and 2x6 for stacking.
    Saw this last night, and I will be doing this once I get a shell.
  7. Mar 19, 2021 at 8:53 AM
    Fred
    Hand Protectors
    Nice idea.
  8. Mar 19, 2021 at 10:47 AM
    fighthedude
    Thanks for replies.
  9. Mar 19, 2021 at 2:41 PM
    Barabajackel
    Barabajackel New Member
    Pittsburgh
    06 double cab
    Heres what I did
    I took power from the drivers side rear brake light for the topper brake light and power from that running light to a switch for topper utility light so it can’t be accidentally left on and built box with drawers for storage
  10. Mar 19, 2021 at 2:42 PM
    Barabajackel
    Pittsburgh
    06 double cab
    65439828-C088-4578-AC04-F85A5F9AD95F.jpg Heres what I did
  11. Mar 19, 2021 at 2:58 PM
    fighthedude
    So there is constant power available in the rear tail light? Perfect! Those boxes you have look great.
  12. Mar 19, 2021 at 5:21 PM
    Barabajackel
    Pittsburgh
    06 double cab
    Appreciate it Thanks Not constant power I wired it so the key has to be in the on position to get the lights in the cap yeah the drawers have been great I made the side fillers removable so I can store stuff in them as well I got a bottle jack in there with some wood cribbing and a bunch of other things highly recommend the drawers cost me about 275ish to build Hear is the lights o.n 4F5F68B7-CA9C-4458-8205-797A829D4204.jpg
  13. Mar 19, 2021 at 10:34 PM
    jerryallday
    Jerry
    Pasadena, Ca
    2006 DC SR5 V8 Grey
    Can you post more photos of the drawer set up, I would like to replicate your system
  14. Mar 20, 2021 at 12:09 AM
    jimf909
    jimf909 Battery almost dead...
    Washington or Idaho
    '03 Tundra SR5 AC 4.7 TRD w/LSD
    Dead stock with oem 16" starfish wheels. We'll see how long that lasts. :) Topper of unknown origin.
    hi-lift jacks have a number of tire/wheel slings that will work.
    The stock jack should work well on the rear axle jack point even with a lift but may need a block for the front frame jack point with a lift. Give it a try, the stock jack rises up to nearly 20".
    A629EE7A-B3B9-46CF-8A72-B20055AFC2C7.jpg 7FAFC9DE-4092-4F35-A58A-427AF7D81766.jpg
  15. Mar 20, 2021 at 6:23 AM
    Barabajackel
    Pittsburgh
    06 double cab
    Check out third coast craftsman on youtube I went with his idea and ran with it 37D7E66B-6CAA-45F5-AB23-BCBB7EDA40AC.jpg
    Black Wolf and jerryallday like this.
  16. Mar 20, 2021 at 7:09 AM
    This is the way. I too have a 6 ton jack and a few accessories from Safe Jack. https://safejacks.com/collections/
    All of it fits nicely in the storage pocket below the rear seat.
  17. Mar 20, 2021 at 8:34 AM
    coTony
    Tony
    Montrose, CO
    The stock bottle Jack with a High Lift base (orange square pad for the Jack in sand) works well. The fit is tight but will slide in with some assistance
  18. Mar 20, 2021 at 10:17 AM
    jimf909
    Washington or Idaho
    Safe Jack stuff has caught my eye a few times but I've never pulled the trigger. Thanks for the reminder.
    What is it that the jack is sitting on. Have you removed the rear seat and added storage? Do you photos of it. I'm curious what you have there.
  19. Mar 20, 2021 at 10:19 AM
    That metal thing is a slide my fridge sat on. I've since removed it and I'm reconsidering my setup. I haven't added any storage yet.
    jimf909[QUOTED] likes this.
  20. Mar 20, 2021 at 12:59 PM
    Lake.Life24
    Shawn
    Upstate, NY
    I need some of those extensions and accessories
  21. Mar 21, 2021 at 5:09 AM
    Barabajackel
    Pittsburgh
    06 double cab
    Man that’s one clean jack
    I’m definitely fabricating myself
    A set of those jack accessories never new they made um
  22. Mar 21, 2021 at 9:09 AM
    Glock 40
    Glock 40 I'm here to break shit
    Yukon Cornelius
    Way up thar
    2000 AC Limited 4X4 4.7L
    Deadpool Edition
    Excellent jack setup! I was going to get a widow-maker for my Tuna but you've changed my mind. Kudos on the purifier and 9s too, good things to have in the stash. :thumbsup:
  23. Mar 22, 2021 at 8:54 AM
    des2mtn
    Shady Grove
    2004 Black DC Limited 4x4
    Tonto cover
    This is what I do pretty much every time I have a flat away from home and I am not on pavement. If you have a slow leak you can put some air in it and drive it off pavement into dirt/ softer surfaces.
    Place a piece of plywood or a block under your jack to keep it from sinking. Jack the truck up enough where the truck's weight is primarily resting on the jack. Next, take your FULL SIZE (not the cute little foldable shovels) and spend some time shoveling that dirt out from around/ beneath the tire. Once you get the bad tire off, dig the whole even deeper where you can get the spare on without issue. Once it's on, lower the jack, tighten the lugs, and you are on your way.
    The hit happens around 1:45.
    https://www.youtube.com/embed/YShAKLSb8BM?wmode=opaque
  24. Mar 22, 2021 at 8:57 AM
    @des2mtn That is a great approach in that type of soil. If I tried that here the TN rocks/clay would just laugh at me. :)
    des2mtn likes this.
  25. Mar 22, 2021 at 9:04 AM
    des2mtn
    Shady Grove
    Tonto cover
    Yep, it really depends all on the terrain. The longest part of this tire change was finishing my beer. With some soils you might be able to dump a bit of water to loosen it up a bit but solid rock... nope!
  26. Mar 22, 2021 at 9:07 AM
    You can loosen up and even dissolve solid rock with enough water and enough time. Just ask the Grand Canyon.
    des2mtn likes this.
  27. Mar 22, 2021 at 9:13 AM
    des2mtn
    Shady Grove
    Tonto cover
    Or a jackhammer. :rofl:
  28. Mar 22, 2021 at 11:58 AM
    2006Tundra
    2006Tundra Financially Irresponsible
    Lou
    Long Beach, CA
    2006 Toyota Tundra Double Cab SR5, 4.7L V8
